• Wir sind dabei, den Suchindex des Forums neu aufzubauen. Bis ca. 6 Uhr morgens kann die Qualität der Suchergebnisse variieren.
[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Eine 7900XTX kann ja maximal 375 Watt ziehen oder? 2x 8 Pin = 2x150 + 75 Watt über PCI-E
Eine 6950XT war bei 335 Watt.
Laut CB liegt die 4090 FE bei Faktor 1,82 zu 6900XT Black (=6950XT?) bei normalem Rasterizer ohne RT
  • Wenn wir hilfsweise von linearer Leistungssteigerung ausgehen, dann würde eine 6950XT mit 375 Watt ca. 11,9% mehr Leistung bieten als mit 335 Watt. Realistisch wären eher 6%.
  • Ferner verspricht AMD 50% mehr Leistung pro Watte (Faktor 1,5)
  • Leistungsfaktor von der 6950XT (335 Watt) zur 7900XTX (375 Watt) Rasterizer
Realistisch: 1 x 1,06 (6% Watt) x 1,50 (50% per Watt) = 1,591 = 59% Mehrleistung zur 6950XT
Optimalfall: 1 x 1,12 x 1,51 = 1,691 = 69% Mehrleistung zur 6950XT
Damit würde die 7900XTX bei Rasterizer bei ca. 87% bis 93% der Performance einer 4090 liegen.
Aber nur wenn 50% per Watt immer eingehalten werden und die Karte Ihr 375Watt Powerlimit voll ausnutzt.
Könnte das so hinkommen?
Weißt du bei wie viel Durchfluss? Bis ~150l/h skalieren die Blöcke ja eigentlich noch ganz gut.
das war bei 120l/h und 60% Pumpenleistung, ich „könnte“ noch bis ca. 200l/h gehen, mach aber mit einer Steuerung über (delta Wasser/Luft)
Dann führt AMD einfach seine eigenen Stromanschlüsse ein - bestehend aus 14+2Pin gerollte Alufolie :ROFLMAO:
Klingt aber plausibel. Die muss nicht unbedingt 3 ghz schaffen.
Kannst eigl nur spannungsregler, power limit und mhz anheben. und natürlich kühlen, damit sie nicht runtertaktet.
Komme jetzt doch knapp über die 3 GHz und speicher ca 1,55ghz in timespy extreme bei max 574watt. Damit ist die obere Grenze ausgelotet. Als nächstes dann uv und alltagssetting finden.
Einbau war ein Krampf, 5000x case ist zu klein. Das nächste wird wieder größer.
Da muss man 1 mal rumrennen in der Firma weil plötzlich jeder ein IT Problem hat... und dann ist Drop xD, was solls hätte sowieso nur aus Jagdtrieb mitgemacht, bin ja zufrieden mit der TUF :d
Joh, deine Kollegen hocken alle vorm PC und kaufen den Drop, während du herumrennst :haha:
  • Haha
Reaktionen: hwk
Sagte AMD nicht etwas von 50% pro Watt? Wie kommst Du auf 100%?
Ich komme auf gar nichts. Ich sage nur, dass es alles in diesem Bereich sein kann. Diese 50% pro Watt Aussage ist halt sehr wage. Ich denke AMD kommt in Raster sehr nahe an die 4090 zu vermutlich etwas günstigerem Kurs.
Gut, aber das hilft auch nicht weiter.
Ja wie gesagt, es ist halt nix bekannt, kann also auch keiner wissen. Ich denke aber Nvidia weiß genau was kommt. Vermutlich eine Karte um die 1000 rum, die die 3080 12GB komplett alt aussehen lassen würde und eine Karte um die 1500-1700 die zwischen 4080 16GB und 4090 liegen wird. Das wäre zumindest mein Tipp. Dann würde der "Unlaunch" der 12GB auch Sinn machen.
Deswegen habe ich es ja versucht anhand der bereits vorhandenen Infos/Parameter herzuleiten. Klar kann man heuristisch sagen, nichts GEnaues weiß man nicht. Aber wie gesagt, dass hilft bei hypotehtischen Argumentationen eben nicht weiter.
ähm ich find das irgendwie extrem viel 574watt für 3ghz?
meine karte macht das mit 400-450?
Falls noch niemand gepostet hat :
Nvidia Treiber 526.61 Hotfix
This hotfix addresses the following issues:
  • Call of Duty: Modern Warfare II] Flashing corruption can be seen randomly while playing the game. [3829010]
  • VTube Studio may crash to black screen [3838158]
  • GPU stuck in P0 state after exiting certain games. [3846389]
Cooler Master MWE 1050 Gold V2, Modulares PC-Netzteil (EU-Stecker), 80 Plus Gold, 1050 Watt Netzteil mit Flachkabel, 140mm HDB-Lüfter, 0 RPM-Modus, Hochtemperaturschwelle
123,49€ https://www.amazon.de/dp/B09DQ655KX
Ist das Krieg der Schläuche und Kabel?
Nein bei seinem PC ist der Anfang ... dort hat es also begonnen .. wir erleben da die geburtstunde des Matrix Sentinels :d
Geburt : -------------------------------------------------------- 2tes Lebensjahr ------------------------------------------------------------------------------- 10tes Lebensjahr
P.S : @Aphexz ... nich böse gemeint aber das war nun leider zu einladent für diesen kleinen Scherz :d
Die 4090 FEs sind, abgesehen von den kleinen Stickern auf der Seite der Verpackung (die man abreißen muss), nicht weiter verpackt, da gibt's keine Folie, kein Papier, kein garnichts; dementsprechend ist es sehr schwierig, hier Versandrückläufer zu erkennen. Soweit die "neu" verpackt werden (Sticker erneuern oder neue Verpackung), hat da man (abgesehen von Spuren auf der Graka, die abgewischt werden können) - wenn keine Schäden dran sind - keine großen Chancen, sowas zu erkennen. Andere Grafikkarten sind von Werk aus verschweißt bzw. so zusammengepresst in der Schale, dass man die nie wieder ordentlich rein bekommt, ohne dass das auffällt - das ist bei der 4090 FE nicht der Fall. Die liegt einfach nur "nackt" in einer Kuhle.
An die, die eine 4090FE haben...
Wurde der FE-Karton in einen Extra-Versandkarton gepackt oder wie bei der 3090 FE im FE-eigenen Karton, der in der Regel total verranzt/verkratzt/verdellt ankam?
man willst dem postler ja nicht zu leicht machen beim "verlieren" *hust
Ähnliche Themen
