[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Auffallend viel ASUS Gedöns von dieser Armoury Crate Software, die ich mit der 3080Ti genutzt habe und eigentlich auch weiterhin nutze, um das LED im Gehäuse einheitlich zu synchronisieren. Ob es daran liegen könnte?
Versuch mal openRGB oder SignalRGB ;)
hab ich auch drauf, neben msi center.
Na wer will mal probieren, beim guten Teppich-Janning einfach mal ne Karte bestellen :fresse2::fresse2:
ich hoffe niemand^
Müsste Amazon bei Account Hacks nicht für Schäden aufkommen? Schließlich ist das deren Plattform und sie müssen die Sicherheit gewährleisten. Zumindest würde ich das erwarten, wenn ich darüber handeln würde.
Hatte eigentlich der eine Kuseng hier seine Kohle wieder bekommen, nachdem bei bei so einem "super" Angebot bei der 4090 zugeschlagen hatte?
Sind die günstig! Alle drei Karten gleich bestellt. Nen Perserteppich gab es obendrauf für lau. Super Laden für Technik! ;)
Also Lüftersteuerung bei der Gaming oc ist definitiv beschissen, manchmal laufen die Lüfter lautstark an obwohl keine hohe Temp anliegt
Bekomme es mit Afterburner auch nicht richtig gefixt. Ansich sind die Lüfter bzw die Kühlung echt stark aber die Steuerung... hwinfo zeigt auch nicht die richtige RPM teilweise an
Erstattung ist bei Amazon absolut nicht das Problem. Der Verkäufer ist ja in der Pflicht nachzuweisen den richtigen Artikel versandt zu haben etc. Diese Scam shops schicken dir nach "Kauf" eine Nachricht und versuchen die Bezahlung außerhalb von Amazon durchzuführen. Wer dort dann drauf rein fällt und denen das Geld außerhalb von Amazon sendet, sieht dieses natürlich nie wieder.
@Gurkengraeber
Ich habe heute meinen Rechner auch mal 15 Minuten im idle gelassen, direkt nach Start, so dass nichts im Hintergrund läuft:
Hatte sogar bis zu 5W und weniger als 12W im Schnitt. Ich bin immer noch überzeugt, dass die ausgelesenen Werte Blödsinn sind, aber in jedem Fall siehst du und auch @***** das die FE keine Special 4090 ist und da auch nichts im Treiber favorisiert wird... Die Werte sind schlicht unzuverlässig im idle... Monitor ist btw ein AW3423DW bei 175Hz gewesen...
Sind doch in Massen im Ersatzteilshop vorrätig? Hab mein BQ Kabel für 19.99 gestern gekauft.
@Gurkengraeber
Sorry ich diskutier hier nicht mehr weiter, da du nicht verstehen willst worum es geht. Es ging um die Vergleichbarkeit, und dabei ist die FE sparsamer als die PNY, bzw auch die meisten anderen Customs. Völlig egal ob 6W zu 20W oder 22W zu 35W. Wenn also HW Info diese Ungenauigkeit drin hat, dann gilt das für alle Karten und ist am Ende wieder vergleichbar.
Und ich habe sogar ein völlig unabhängiges Strommessgerät benutzt, dass den Unterschied ebenfalls nachweist. So und jetzt war das mein absolut letzter Kommentar zu der Sache. Soll hier bitte jeder nutzen was ihn glücklich macht. Für mich ist die FE der PNY im idle klar überlegen, daher geht dieser Punkt an NVidia.
Da bei der PNY ein Lüfter nicht funktioniert, ist das oben aber für mich alles irrelevant. Die PNY geht zurück und ich überlege ob ich nochmal eine bestelle oder erstmal mit der FE und dem Lüfter mod weiter mache. Wenn man irgendwann auch die Customs für <1.800 Tacken oder so bekommt, gebe ich denen vielleicht nochmal ne Chance.
Aber leise ist sie wie gesagt, das ist ein Traum.
FE Powerdraw:
3 Monitore (2x1440p@144hz; 1x1440p@60hz)2 Monitore (1x1440p@144hz; 1x1440p@60hz) 1 Monitor (1x1440p@144hz)
GPU 210 Mhz210 Mhz 210 Mhz
MEM100 Mhz50 Mhz50 Mhz
Verbrauch27 Watt15 Watt8 Watt
Na wenn wir uns einig sind, das keine 4090 6W im idle zieht, dann haben wir doch einen Nenner. Darum ging es mir doch die ganze Zeit. Ja, die Karten ziehen im idle unterschiedlich viel, aber der reale Unterschied liegt irgendwie um die 5-6W als reales Delta, egal welche Karte.
Das eine insgesamt 6W zieht und die andere dann 25W ist einfach Blödsinn.
Die FE ist eine tolle Karte und insgesamt für mich auch eine/die stimmigste Karte insgesamt. Hilft nur eben nicht wenn man sie permanent hört :/
Dachte immer das wäre Spaß hier mit der weißen Strix, aber die gibt’s ja nun tatsächlich:
Richtig Richtig schick die Karte 😍😍😍
Ja ist bei Equippr auch schon gelistet.....und Gerüchteweise soll die Weiße kein Schreihals sein ...die Hoffnung stirbt zumindest zuletzt :ROFLMAO:
Und paar FPS bringt die weiße Farbe sicher...
woher auch immer diese gerüchte wieder kommen :d
4090 FE
verbrauch auch net weniger
Ich verstehe es nicht, kauft man sich eine 2000€ + Grafikkarte um dann den Idle Verbrauch zu vergleichen?
Um Energie zu sparen, dimme ich meine Schreibtischlampe um eine Stufe, seitdem ich die Karte habe. Für mein grünes Gewissen^^
Naja stelle dir mal vor dein Standgas vom Auto wäre jetzt zu hoch da würdest du auch klären wollen ob das normal ist oder nicht? daher der Vergleich mit den anderen Besitzern
Wieso immer Autovergleiche bei Grafikarten? Aber davon ab, ich fahre einen FIrmenwagen. Ist mir egal wie hoch das Standgas ist. Kann das Beispiel nicht nachvollziehen.
Bist eh schuld wenn Deutschland einen Black Out bekommt :coffee3:
Ich werde hier nicht anfangen zu
diskutieren, habe nur meine Werte gepostet um dem einen Kollegen hier zu helfen der seit einigen Seiten hier scheinbar Probleme damit hat und vergleichbare Werte sucht.
Ich verdiene am PC mein Geld und der läuft fast den ganzen Tag und da ist es mir schon wichtig das der idle Verbrauch im non Gaming Bereich gut ist.
Ähnliche Themen
