[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Guck ma was die GPU auslastet glaube die idelt nicht wirklich
Ähemm sollte ich vielleicht mal den Dreizack sicherheitshalber mal rausnehmen und schauen, dass da nichts kokelt? 😭
Done! Immer noch 79 Watt.
Das mit dem Treiber wollte ich auch vorschlagen
Ausserdem mal das OS prüfen oder "frisch" machen
Halte zwar für ausgeschlossen, aber nicht unmöglich, dass irgendwas an der Karte nuckelt (ein Miner?) ;)
Die billigste und stromsparenste Mining-Hardware ist die, die man infiziert hat und für sich minen lässt :d
Frag mal "Julien Bam - Ich hab 8 Millionen Abonnenten verloren. Meine Youtube Kanäle wurden gelöscht" :ROFLMAO:
Aber wie gesagt, ein Miner halte ich für nahezu ausgeschlossen
Hast du nen 360Hz Monitor dran hängen?
Sowohl AMD als auch Nvidia haben schon über Jahre Probleme mit vielen Anzeigen (mehr als 2 mit hoher Auflösung) und/oder ein Monitor mit sehr hoher Bildfrequenz.
Wenn ja geh mal auf 144Hz und danach sollte die Leistungsaufnahme sich normalisieren :)
Absolut same mit TUF vs FE.
Ich kann es mir auch nur so erklären, dass Nvidia über den Treiber die FE begünstigt.
Diesen Verbrauch der TUF hatte ich über alle Treiber hinweg und ich hatte für Nvidia extrem viel getestet (black screen bei Multi-Monitor).
Die FE ist mit Abstand die beste 4090:
Die Leiseste, die Wertstabilste und die Schönste!!
#insider aus'm 3090er :o
Zumal ich es wie gesagt auch für die Steckdose bestätigen kann. Aber ist für mich auch durch das Thema jetzt, er hat sich ja für die PNY entschieden. Ich schicke meine auf Grund des kaputten ersten Lüfters zurück und überlege dann ob ich nochmal eine bestelle oder eben einfach den Lüfter Mod an der FE probiere. Alles abgesehen vom Brummlüfter macht die FE ja mit am besten von allen 4090ern.
Wenn die FE nicht so absurd laut wäre, dann hätte ich sie wohl auch behalten. Design und Spannungsversorgung sind schon wirklich am besten.
geforce experiene + desktop shadowplay aktiv?
Deaktiviert.
Ok, dann liegt es nicht an der Anzeige. Windows Höchstleistungsmodus irgendwie aktiviert?
Ausbalanciert.
Sehe aber gerade, dass im Control Panel GPU Energiemodus auf maximale Power steht. Mal auf normal stellen und schauen.
Edit: Nope, immer noch auf 78-80 Watt.
Kann es an den beiden Lüftern liegen, die beide konstant 1150 RPM laufen?
Deaktiviert.
Ausbalanciert.
Das hier? Hatte ich eben mal testweise auf max gestellt - ändert aber nichts am Verbrauch
Auf minimal belassen, oder einen anderen Punkt auswählen?
Minimal
Ok, stell den abgesicherten Start wieder ab und schaue beim normalen Start in der "Systemkonfiguration" was dort für Dienste laufen (unten MS-Dienste ausblenden). Zudem im Taskmanager gucken, was alles bei "Autostart" läuft
Ich bin mit der FE bei 8-15W im Idle. Gesamtsystem zwischen 90-100W. Das Asus Thor zeigt es ja direkt an
Auffallend viel ASUS Gedöns von dieser Armoury Crate Software, die ich mit der 3080Ti genutzt habe und eigentlich auch weiterhin nutze, um das LED im Gehäuse einheitlich zu synchronisieren. Ob es daran liegen könnte?
Edit: Ich sehe aber auch gerade, dass nach Beendigung des gesichterten Modus, der Idle Verbauch von 80 auf 40 runter ist. Schon mal ein großer Schritt in die richtige Richtung. Trotzdem verstehe ich die Logik dahinter nicht ganz. Was saugt im Idle soviel im System alter Schwede!
Edit II: Ich refresh mal den Treiber per DDU.
Steam offen + Browser + Youtube Video (1080p @30fps)
Nur ein Chrome Tab offen (diese Seite hier)
Fenster mit Maus bewegen bei 144hz Monitor (3840x1600):
PNY 4090
Absolutes Minimum war mal 6W aber tritt selten auf.
Edit wenn ich Chrome browser auch noch beende:
Wow so viel Malware. Direkt Windows frisch aufsetzen
Hatte meinen letzten Post gelöscht , weil ich derweil was interessantes festgestellt habe.
HWINFO offen und auf dem Desktop 28 Watt.
Mache ich Firefox auf und bin auf der HWLUXX Seite , dann sinkt der Verbrauch auf 20 Watt .
Habe hin und her geswitcht und immer das selbe Verhalten.
Wo ist da die Logik ?
Die Logik ist genau was ich die ganze Zeit versuche klar zu machen.
HWInfo ist besonders bei geringer Leistungsaufnahme sehr ungenau, da arbeiten Softwaresensoren und keine Hardwaresensoren.
Die Leistungsaufnahme wird über verschiedene Parameter errechnet und nicht wirklich gemessen. Der angezeigte Wert ist also lediglich eine errechnete Annährung und keine richtige Messung.
So betreibt etwa niemand eine 4090 jemals mit 6W, auch wenn das im HWInfo angezeigt wird… genau solche Szenarien wie hier beschrieben zeigen eben genau die Grenzen von Softwaresensoren.
Das ist übrigens auch der Grund warum zB im Rechenzentrum wirklich relevante Daten über echte Hardwaresensoren gemessen werden und nicht einfach auf Grundlage anderer vorhandener Infos errechnet werden.
Igor hat bei der 4080 FE 18 Watt Idle gemessen . Bei der 4090 waren es 35 Watt , aber das war zu viel , weil das x670 Brett noch kein BIOS Update hatte und der PCIE Bandbreite nicht abgesenkt wurde , aber bei der 4080 hatte alles gepasst soweit .
Denke die 4090 könnte dann im Bereich 22watt sein im Idle , weil bisschen zieht ja trotzdem der Speicher . Erwähne hier jetzt Igors Test , weil er sowas misst und das Equipment hat. Andere Hardware Seiten lesen auch nur von der Software ab .
Du hast den Core, den Speicher und auch die Verluste über die Spannungsversorgung selbst.
Ich denke auch ~22W ist das realistische Minimum, wobei selbst das sich noch recht optimistisch gedacht ist. Aber irgendwo zwischen 22-35W wird wohl im idle die absolute Wahrheit liegen.
@AzRa-eL
Ich hatte mit meiner TUF und Strix nach einbau immer 46-48 W.
Ich weiß nicht warum aber erst wen ich RBAR aktiviere im Bios von meinem X570 ging die Karte auf 12-22 W runter.
Und mach mal bitte ne statische Farbe oder Beleuchtung aus und schau dann. Hab ne Gaming OC und die idelt zwischen 9-18 Watt mit einem Asus pg42uq und minütlich wechselnden Wallpaper.
Ähnliche Themen
