[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Wenn du hier mitgelesen hättest hättest du eine kfa2 bestellt und keine gigaschrott ^^
Warum genau?
Im Sammelthread zu Coulwine/Fiepen/Rasseln schneiden die GB Karten meiner Meinung nach super ab :)
Lüfter interessieren mich nicht, und wenn es um etwas mehr Takt geht, das ist mir auch egal.
Was ich hier allerdings ganz klar rauslese ist, dass es mehr oder weniger mit allen Karten gerade ein Glücksspiel ist.
Sollte die Karte Störgeräusche produzieren, geht sie zurück, dann probiere ich ja vielleicht mal die kfa2 :)
Ich werde in jedem Fall berichten.
Hier gibt es weiterhin keine Infos von meiner Inno3D Frostbite - lief wirklich unauffällig, kühl, Hotspot auch top - alles wie es soll, auch Spulenfiepen hatte ich keines.
Aus dem Nichts dann Reboots / Bildfehler usw.
Caseking hat meine Reklamation bestätigt und geprüft und direkt mit dem Inhalt -> Weiterleitung an Hersteller belegt und im Kleingedruckten noch "Die Weiterleitung erfolgt aus Kulanz ohne Anerkennung einer Rechtspflicht" vermerkt.
Man steht leider sprachlos am Straßenrand nachdem der Bus durch die Schneematschpfütze direkt an einem vorbei fuhr.
Leider sind die Moneten nicht so locker das ich handeln könnte um Ersatz zu ordern, meine 3090 habe ich meinem sehr glücklichen Arbeitskollegen vermacht, habe nun übergangsweise eine 3080ti drin - auch leihweise. Alles extrem bitter.
Warst Du schon aus der Widerrufsfrist raus?
Ja, die Karte lief 6 Wochen einwandfrei. War stehts untervoltet, alles wirklich top.
Hätte vermutlich auf lange Zeit am Setup nichts mehr gedreht.
Na da ist ja schon die nächste Frostbite mit hohen Temperaturen :eek: oder ist das die selbe?
So der umbau ist erledigt :)
Sagt mal gibt es eigentlich sowas wie VRAM Takt degeneration ?
Ich konnte Wochenlang fürs Benchen den VRAM auf +2000 stellen aber seit Heute muss ich auf +1900 oder +1800 runter um bei Port Royal nen lauf durchzubekommen
kann es sein das der VRAM Max Takt darunter leidet wen man ihn zu oft am Limit betreibt und man dann nich mehr so hochkommt wie zuvor beim VRAM Takt ? ... ( ECC hab ich aus )
Hmm nun konnte ich grad wieder 2 Runs mit +2000 machen seltsam .. und dann wars wieder vorbei ... manchmal gehts manchmal nich obwohls vorher wochenlang jedes mal ging.
Also 4 Wochen liefen +2000mhz ohne Probleme bei meinen Bench Sessions und nun seit Heute muss ich auf so +1800 runter und schaffe die +2000 nur noch ganz selten mal
Ich glaube das ist die gleiche.
Nee, müsste ne andere sein :lol:
Laut @Youngtimer waren es ca. 100°C, hier haben wir aber 110°C!
Wird ja immer besser hier :popcorn:
(könnte natürlich die selbe Karte sein, da neuer User wegen Inno3D Support Forum)
Der Kollege ist auf meinen Rat hier weil Inno3D einen direkten Support hat. Der Inno Mitarbeiter hat es abgeklärt und der User kann erstmal selbst überprüfen, die Backplate annehmen und die Schrauben checken. Da ist aber wohl alles in Ordnung. Daher Empfehlung mit Händler (Galaxus) eine RMA anzustoßen. Falls irgendwelche Probleme auftauchen will man sich bei Inno3D direkt kümmern.
Ärgerlich, aber andere 4090 Karten sind ja auch nicht perfekt und werden wieder zurück gegeben. Mitarbeiter von MSI oder Asus die sich zu ihrem Schrott hier im Forum äußern habe ich bisher noch nicht gesehen.
Wer sich hier blamiert sind User wie @***** oder @MS1988 die sich über Probleme andere Luxxer amüsieren und stumpf gegen einen Hersteller haten.
Hat jemand Erfahrungen, wie das bei MediaMarkt mit Widerrufsrecht läuft?
Kriegt man da auch Zeitnah eine Gutschrift, wenn man online bestellt?
Irgendjemand meinte glaub ich hier mal, das wenn mans im Laden zurück gibt, die es erstmal zum Händler zur Überprüfung senden?
Wie ist das bei Online Bestellungen?
Meine Erfahrung damit ist: Hast du es online bestellt und im Laden geholt, dann im Laden zurückgeben. Hast du es online bestellt und liefern lassen, dann einfach online retoure ausdrucken und zurückschicken.
Bei mir wurde immer alles zeitnah bearbeitet, wenn man es im Laden abgibt wird es meine ich sogar direkt überprüft und man bekommt sofort die Gutschrift, so zumindest wenn man es im Laden bezahlt hat, da sie ja auf die selbe Zahlart zurückerstatten müssen mit der man gekauft hat. Grundsätzlich ist MM kulant, ich hatte nie Probleme, die erlauben ja sogar Rückgabe innerhalb 14 Tage wenn du was im Laden direkt gekauft hast.
Hab in den letzten halben jahr 3 retouren gehabt bei MM. Leider hab ich da nichts positives was die Bearbeitungzeit angeht erlebt.
längste bearbeitung waren 2 monate und ein bisschen.
@Brainscan1979 - Gerne Temps und Spulen Infos - bin gespannt.
@Dana_X hier zu finden :)
zum Spulefiepen kann ich dir nichts sagen da ich auf beiden Ohren "fast" Taub bin ( Tinitus und verringtes Höhrvermögen ), also ich bin einer der Kein / Nie spulenfiepebn hat(hört) ausser im Ohr selber :)
Welche Flutschinaut WLP haste drauf geschmiert?
Ich bin ja ehrlich, und bin "eigentlich" nen Thermal Grizzly anhönger, aber wirklich diesesmal habe ich die die dabei war genommen ( SubZero mit 16 w/k ) das ist zwar ne verdammt verk(a)ckte Zähe Paste aber die scheint zu fruchten ( Kühlen ).
Ich poste dann hier auch mal die Temps. Bin SEHR Zufrieden mit der Leistung des Blocks
Hatte ich auch das gefühl, aber meine 4090 vom Dezember die zurück geht hat meiner Meinung nach defekten VRAM. Oder VRAM der nicht verkaufswürdig ist.
+1000 ging 1 Tag lang. Jetzt geht +800 ohne crash, aber ruckelt mehr als mit stock. Also stock läuft besser.
Ich hatte einen zur Abholung bestellten 42C2 nach ein paar Tagen wieder im Markt abgegeben und die Rückzahlung kam noch während der fahrt nach Hause via Paypal :d
Hatte ich auch das gefühl, +1000 ging 1 Tag lang. Jetzt geht +800 ohne crash, aber ruckelt mehr als mit stock. Also stock läuft besser.
Is bei mir halt leicht anders .. bei mir gingen die +2000 ja nun so 4 - 5 Wochen lang easy durch aber seit Heute schaffe ich nur noch selten die +2000
sondern muss halt auf +1900 oder +1800 runter .. also bei mir war das ja schon länger als 1 Tag ... und ich bekamm auch immer mehr Punkte mit + 2000 als mit zb +1800
da hat der VRAM also auch nich gedrosselt
Und laut meiner Kenntniss sollte da eigentlicht nichts passieren wenn man halt nur mit dem mhz hoch geht da gibts halt höchstens mal artefakte aber die hatte ich in den 4 - 5 wochen
auch nie gehabt als ich mit +2000 gebencht hab und auch jetzt nicht .. gibt halt einfach nur n Bench Crash und der Bench läuft dann erst durch wenn ich den VRAM drossel
Ist ein komisches verhalten .. Temperatur soll ja auch ein Einfluss haben aber egal ob warm oder kalt das ändert grad nichts .. ist halt echt ärgerlich und ich finde die Ursache nicht
Meiner Meinung nach war/ist dein RAM bei +2000 einfach nicht Stabil. Bei mir läuft es auch gerne 1-2 Wochen bis es plötzlich crasht. (V)RAM dauert leider.
Das mag sein aber warum dauerte es nun 5 Wochen bis nun garnix mehr geht ? Wenn es nun generell nich stabil währe dann hätte ich doch innerhalb der 5 Wochen
nun schon ein paar Crashes gehabt aber die hatte ich nich zumindest nich bezogen auf VRAM Crashes und wenn crashes dann lags da am Core der zu hoch war.
Ist halt seltsam das es seit Heute nich mehr geht aber in den letzten 5 Wochen easy ging
Mit crash meinte ich auch artefakte im memtest. Benchmarks hatte ich nicht gemacht.
+1000 ging halt im gaming am Tag 1 und danach nicht mehr. Da hatte das game extrem geruckelt.
und ich nich memtest ... nutze bzw nutze die +2000 nur für Benches ... fürs Gaming bzw 24/7 bin ich auf +500 runter .. selbes Spiel auch beim Core wo ich bei Benches auf +255 gehe wäährnd ich beim Gaming bzw 24/7 auf + 90 gehe
Sprich die hohen Taktraten lagen immer nur ein paar Stunden an alle paar Tage mal aber eben nich 24/7 daher hab ich da auch kein Memtest gemacht da ich das nur für meine Bench Sessions so nutze
Bei mir ruckelt halt nix und ich hab halt auch mehr punkte in den Benches mit +2000 und eben weniger mit +1800 daher drosselt da der VRAM bei mir auch nich.
Ich mein ok kann ja sein das er nich stabil is aber die Frage is halt warum war er die letzten 5 Wochen Stabil bei meinen Bench Sessions und Heute bei meiner Bench Session nich mehr ?
Das is ja das seltsame ... währe er nich stabil oder sowas dann hätte ich doch in den letzten 5 Wochen dahingehend schon probs gehabt aber die hatte ich nicht erst Heute fing das nun an
Daher eben meine Vermutung das der VRAM vielleicht degeneriert is da ich ihn die ganze Zeit bei meinen Bench Sessions am Limit hatte und er nun "abgenutzt" is und ich daher nich mehr
so hoch komme wie in den letzten 5 Wochen ...aber soweit mir bisher bekannt geht das beim VRAM nich sondern das würde nur gehen wenn man nen Volt Mod macht .. also nur mhz hoch schadet dem VRAM nich
nur halt mehr Volt also sowas wie ein Shunt Mod würde dem VRAM schaden wenn man da zuviel Volt drauf ballert aber ich nutze ja nur den normalen Volt Regler von MSI Afterburner
.. aber ich kann mir das grad nich anders erklären
Also ich glaube auch an VRAM degeneration.
Meine Karte ist jetzt vll keine Referenzkarte, da meiner Meinung defekt. Aber wenn man sich den Fakt anschaut ging einmal und dann nicht mehr.
Ähnliche Themen
