[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Naja ich habe ja ein beQuiet Straight Power 11 1200W und das beQuiet 12VHPWR Kabel. Also wenn ich deswegen jetzt nicht höher ins PL komme dann kriegt beQuiet aber was zu hören. Denn das kann es ja nicht sein.
Wo genau sollen sich denn die Kontakte lösen?
Probleme über Probleme nur wegen einem dusseligen Adapter für knapp 50 Euro, der einem nicht das anzeigt, was man sehen will. :d
Das weiß ich leider nicht mehr so genau aber man konnte dann einzelne Adern einfach ab ziehen Steckerseitig ..... war aber wohl nur die erste Charge von betroffen ....
Wo am Netzteil hast du denn die PCIe Stecker angeschlossen?
Habe mal die Anleitung raus gesucht vom Netzteil.
Weiß jetzt nicht wie ich es angeschlossen habe. Muss ich mitgebracht mal schauen.
Hab das DPP 12
Ist das da anders? Ist aber auch kein ATX 3.0 oder?
Nein kein ATX 3.0, finde kein Bild mehr das NT ist ja auch schon EOL.
Ist bei dem total anders. Muss mir das morgen nochmal genauer anschauen.
Die Gigabyte RTX4090 und der Phantekkühler sind angekommen und werkeln bereits. Alter Schwede ist das ein Klopper. Dachte meine 3080ti ist groß, aber das Ding ist ja nochmal länger. Gut das ich das CaseLabs Mercury habe.
Mein like gibt es für das S8. Meins wartet seit 2 Jahren zusmmengebaut zu werden :fresse:
Und der Wasserkühler für die 4090 liegt auch schon seit einem Monat hier :fresse2:
Geht auf Grund des Kühlers bestimmt nur bei den "kleineren" Karten.
Optisch schon sehr geil, wie ich finde.
oder der gigabyte weg :)
Womit kann man denn die Karte mal so richtig auslasten?
Laut ATX Regelwerk darf die Backplate von Steckkarten nur sehr dünn sein. Das stammt noch aus alten Zeiten, wo die Kartensteckplätze fast immer alle voll belegt waren, und die CPU am meisten Abwärme erzeugt hat.
Mittlerweile hat sich das fast umgedreht. Kartensteckplätze werden praktisch nur noch für Grafikkarten genutzt. Und selbst wenn zwei Grafikkarten verbaut sind, haben sie deutlich mehr Abstand voneinander, als im ATX Regelwerk mal vorgesehen. Von daher wäre es ja problemlos möglich, den Backplates etwas mehr Platz zu geben. Und dann ist auch ne Stromversorgung über die Backplateseite kein Problem mehr. Dann könnte vielleicht sogar die komplette GPU Spannungsaufbereitung mit auf die Backplateseite. Das wäre auch für die Speicheranbindung von Vorteil, weil die Signalweg zur GPU kürzer gestalltet werden können.
Auch auf die Gefahr hin das mich alle CPU-Luftkühler Fanatiker an die Wand nageln, wäre das mMn ein logischer Schritt, hin zu besserer GPU SpannungsVersorgung und GPU-Kühlung.
@ThuNd3r1982
Deine GPU hängt irgendwie bei 2490mhz, kein Wunder das da keine Auslastung stattfindet.
Update, gerade mal OCCT angeworfen, mit offenem PT dann die maximal 520w bei mir.
(Aber Aua, der OCCT heizt ja dermaßen, so hohe Temps habe ich noch nie gesehen, 68GPU,74HS,74Mem)
@ThuNd3r1982
Und das ist auch genau der Grund warum bei ihm der Takt niedrig ist. Die Karte wird thermisch an die Kotzgrenze geführt und beginnt zu drosseln.
Interessanter wären Raytracing Sachen zu testen. IdR wird sich die Karte da ja auch nur kurzzeitig viel Leistung nehmen. Ich denke wenn sie dauerhaft über 500W zieht schafft das der Kühler nicht mehr vernünftig.
Mindestens den Kühler und die Gehäuselüfter auf 100% würde ich vorschlagen, wenn man solche Kühlertests fährt.
Du wirst die vollen 600 watt nur ausreizen können wenn du im Afterburner das Voltage Limit auf max setzt, sonst läufst du immer davor ins Voltage Limit und die Karte kann nicht die vollen 600 Watt ziehen, ist ganz normal
Hat er doch gemacht.
"Habe mit Afterburner das Power Limit auf 133% gesetzt. Trotzdem gehen nur 465 Watt."
Die Karte ansich müsste es können. Volle 600W habe ich noch nicht ziehen lassen, aber ich habe natürlich auch mal herumgespielt und deutlich über 500W habe ich schon gesehen. Irgendwann wird dann bestimmt auch mein kleiner 13700k limitieren. Aber sogar in Timespy extreme stoße ich deutlich an die 450W Grenze, also sollte mit sowas wie 3DMark auch schonmal ein erster Eindruck möglich sein anstatt immer nur mit diesen "Power Viren".
Die Corevoltage kann man ja auch noch erhöhen auf 1.1v per AB.
Die Karte ist nicht am Templimit. 81.4 Grad ist doch im Rahmen. Bis 88 Grad darf sie haben bevor sie runtertaktet.
ok aber bitte erhöhe per AB auch die Voltage mal auf 1.1v und teste mal.....
Jap werde heute Abend nochmal testen.
Ich habe nicht Powerlimit geschrieben sondern Voltage Limit ;)
Ich habe jetzt die Curve Einstellungen im Afterburner zurück gesetzt. Jetzt komme ich auf 560W. Hatte ja das Voltage Limit begrenzt so wie es @andi0138 schon gesagt hatte. Kein Wunder das es nicht funktioniert hat.
Ich hab seit kurzem was komisches Entdeckt. Bei bestimmten Programmen habe ich das Gefühl mein ganzer Monitor flackert wenn ich die Maus bewege, es trifft definitiv nicht den normalen Desktopmodus in Office usw, bei einem Tool bin ich mir ziemlich sicher (ein youtube dl tool) und bei Diablo 4 hab ich das Gefhühl das es auf der Map auftritt wenn ich mit der Maus über die verschiedenen Gebiete fahre. Ich kann es aber weder messen oder sonst was, kann mir aktuell noch absolut keinen Reim draus machen was das sein könnte.
Hast du DLSS3 aktiviert in Diablo? .. da kann es zu Artefakten kommen beim Scrollen oder verschieben von Text. Stell mal aus und teste ob es dann auch so ist. Wegen dem DesktopModus kann ich jetzt nichts sagen. Ich hab das soweit ich weiss, nicht.
Kannst auch bevor Du es ganz ausstellst erstmal mit der Schärfe spielen. Auf höchster Einstellung flackert bspw. das Gras in W3 ganz extrem. Mit der nächst niedrigeren Einstellung, wobei immer noch alles top aussieht, flackert nichts.
Muss ich mir anschauen wenn ich zuhause bin, danke.
So, hier nun die Antwort von Asus Deutschland zum Thema "neue Spulen auf der Strix":
Sehr geehrter Herr xxxx,
vielen Dank, für die Rückmeldung.
Uns ist dieses nicht bekannt.
Dazu haben wir keine Auskunft, die wir Ihnen geben können.
Es ist möglich das dieses kommt, da wir immer versuchen unsere Geräte zu verbessern, aber dazu haben wir noch keine Information.
Sollten Sie noch weitere Fragen haben, melden Sie sich gerne. Wir stehen Ihnen jederzeit zur Verfügung.
Vielen Dank, bleiben Sie gesund und kommen Sie gut durch diese Zeit.
Mit freundlichen Grüßen | Kind regards
Muss jetzt nix heißen, nicht immer erfahren alle Subdivisions weltweit von einer Maßnahme. Das Deutsch zeugt aber eher von einem Übersetzungstool, also wer weiß wo der Schreiber sitzt.
Daher sage ich erstmal Bullshit :hust: bis Roman in einem Video was anderes beweist.
Ähnliche Themen
