[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat eigentlich jemand eine Eiswolf 2 auf seiner 4090? Finde das eigentlich interessant, wobei die Luftkühlung ja ausreicht.
Hast du DLSS3 aktiviert in Diablo? .. da kann es zu Artefakten kommen beim Scrollen oder verschieben von Text. Stell mal aus und teste ob es dann auch so ist. Wegen dem DesktopModus kann ich jetzt nichts sagen. Ich hab das soweit ich weiss, nicht.
Kannst auch bevor Du es ganz ausstellst erstmal mit der Schärfe spielen. Auf höchster Einstellung flackert bspw. das Gras in W3 ganz extrem. Mit der nächst niedrigeren Einstellung, wobei immer noch alles top aussieht, flackert nichts.
Hab den neuen Treiber gestern installiert und in Diablo scheint es jetzt weg zu sein. Beim uTube DL ist es noch da, scheint somit aber eine SW Geschichte zu sein.
Gibt es inzwischen eig Belege und oder Bestätigungen das ein anderes Netzteil Spulengeräusche minimieren? Oder ist das nur Blabla?
Hab z.b aktuell ein 750 Watt Bequiet Netzteil und das ist schön extrem bei der Grafikkarte und überlege auf ein 1000/1200 Watt zu wechseln.
Kann damit zusammenhängen, muss aber nicht. Da gibt es einfach zu viele Variablen...
Ist wie mit den Karten: Du kannst 10 verschiedene probieren, aber am Ende ist es total random ob bzw. wie viel Besserung es bringt.
Manchmal hilft es auch, den Stromstecker 180° zu drehen.
@Shariela
Das ist eine Eselsbrücke...
Dabei geht es nicht um das Drehen der Netzsteckers selber, sondern um das Überprüfen der Kontaktierung der Netzstecker, oder auch NetzsteckerAdapter. Wackelkontakte an den NetzSteckern oder Adapterschalter, kann durchaus zu instabilen NT-Stromversorgung führen, und somit auch zu stärkeren Spulenfiepen der Grafikkarte.
@s.nase denke du hast da was nicht verstanden, es geht sich genau darum den stecker um 180 grad zu drehen. Gibt auch einen Grund wieso man Steckdosen richtig einbaut, Stichwort Phasengleichheit.
Teils Voodoo aber je nach verwendetem Gerät durchaus als Störquelle eine mögliche Ursache, primär bei Hifi Komponenten. Die Engländer haben es da einfacher.
Nur das der Phasenwechsel keinen Einfluss auf auf die Gleichstromversorgung eines PCs haben kann, weil im PC-NT sogar zweimal hintereinander ein Gleichrichter arbeitet.
Mal wieder zurück zu den wirklich wichtigen Fragen: Wer hat eigentlich den längsten? 🫵
Das erinnert mich an:
Meine Ohren bluten.....
Und was hässliches.
Ich finde es schon krass wieviel Ampere dadurch gejagt werden. bei 250 Watt sind es 20A und bei 600 Watt wären es 50 Ampere. Nur wie bekomme ich die Karte so stark ausgelastet? Mit Furmark auf der höchsten Auflösung mit 8xMSAA lande ich bei ca. 260W.
Och, naja… :)
Knapp 800A (Output Current) bei 1,13V ist eine andere Nummer :d
Ist das jetzt Super Saiyajin 3 gegen Master Ultra Instinct? :fresse2:
Moin,
ich plane mir eine 4090 anzuschaffen. Spricht etwas gegen die Founders, oder sollte man lieber auf ein Custom-Modell setzen? Keine WaKü, nur Luft. :)
Spricht nich viel gegen eine FE ausser das so manche custom bereits günstiger angeboten wird.
Und evtl. das man kein anderes Bios auf die FE flashen kann... was ja nicht wirklich notwendig ist.
Mensch diese Colorful hätte ich gerne. Aber nicht für's OC, sieht einfach nur gut aus. :fresse:
Ich plane mir eine 4090 anzuschaffen. Spricht etwas gegen die Founders, oder sollte man lieber auf ein Custom-Modell setzen?
Ich empfehle dieses geile Produkt, FE war gestern:
Hat sogar einen eigenen Sammelthread die Karte. 👌
Das sich ein Stecker, obwohl er verrastet ist, soweit bewegen lässt, wie hier in diesem Video:
hat mich doch sehr überrascht.
Ich habs dann zuerst beim CableMod 180°-Adapter an der FE ausprobiert: Ja, da ist echt viel Spiel, um das der Adapter aus der Buchse gezogen werden kann.
Da die Grafikkarte gerade nicht eingebaut ist, hab ich als nächstes ein Kabel für mein Corsair-Netzteil verwendet (von Corsair), was noch im Regal lag: Spiel ist vergleichbar groß.
Da mir so etwas bisher nicht aufgefallen ist, hab ich als nächstes den 4fach-Adapter von nVidia ausprobiert: Dort ist so gut wie kein Spiel vorhanden.
Dort muss man den Stecker aber auch richtig gut und fest andrücken, bis die Verrastung auch wirklich einrastet.
Für mich wäre gerade eine mögliche Erklärung die folgende:
Die Drittanbieter wollten ausschließen, das die Verrastung nicht einrastet und haben die Toleranzen bei ihren Steckern so ausgelegt, so dass es früher und damit auch sicher einrasten kann.
Das Dumme: Damit kann man den Stecker tatsächlich ziemlich weit rausziehen, bevor die Nase den Stecker am kompletten Abziehen hindert.
Beide Varianten haben somit ihre Vor- und Nachteile. Somit wäre eine Verschraubungssicherung des Steckers in der Buchse eventuell eine bessere Lösung.
Ich lasse meinen 180er erstmal verbaut. Denke das Risiko ist minimal.
Cool, dass die dir dann tatsächlich deine Karte ersetzen im Fall der Fälle.
Ich nutz wireview da gibt's keine wirklichen hohen Toleranzen es sitzt sehr straff , vielleicht ist das was für dich ist im Grunde ja auch ein Winkel
Danke für den Tipp. (y) Den hatte ich schon hier. Es sind aber leider einige Wasserkühler nicht kompatibel dazu.
Sofern man als Nutzer ein Auge darauf hat, was man da gerade macht, kann man imho mit allen Adaptern zurecht kommen.
Sofern man da aber nicht drauf achtet, kanns halt leider zu Problemen kommen.
Persönlich hab ich bisher eher ein Auge darauf gehabt, obs einrastet. Ob man den Stecker danach rausziehen kann, das hab ich aber nie geprüft.
Ähnliche Themen
