[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Bei Caseking
Hast mir vielleicht ein Link dazu, thx .
Ich finde es schon krass wieviel Ampere dadurch gejagt werden. bei 250 Watt sind es 20A und bei 600 Watt wären es 50 Ampere. Nur wie bekomme ich die Karte so stark ausgelastet? Mit Furmark auf der höchsten Auflösung mit 8xMSAA lande ich bei ca. 260W.
Selbst damit komme ich nur auf 450W.
Habe mit Afterburner das Power Limit auf 133% gesetzt. Trotzdem gehen nur 465 Watt.
Habe das Bios auch auf OC stehen. Kapier ich nicht.
Das ist ne gute Frage. Habe die Karte noch nie so ausgelastet :fresse:
Kann doch aber mit dem Wireview nichts zu tun haben.
Fan 1 Speed = 5190 RPM ^^
Glaub der Tee ist fertig...
Das ist der Lüfterschock Modus :d
OCCt ist echt extrem in der Auslastung, da gibt es nichts vergleichbares glaube ich ....
Vielleicht drosselt die Grafikkarte ihren Stromhunger, sobald ein zu hoher Spannungsunterschied zwischen dem PCIeSlot und dem 12VHPWR Anschluss entsteht, um den 12VHPWR Anschluss zu schützen.
Und das soll bei fast genau 100% sein?
@ThuNd3r1982
Am meisten Watt habe ich gesehen bei Quake Raytracing, alles voll aufgedreht in 4K.
Achja und bei PUBG, wenn ich alles auf minimal gestellt habe und den Framelimiter herausgenommen habe und dann im Menü über 1000 FPS hatte.
Vorteil ist beides ist kostenlos und somit zum Testen super geeignet.
Schon möglich, ich würde den Test noch mal ohne das WireView machen, nur um aus zu schließen, das es keine Fehler hat @ThuNd3r1982
Notfalls nochmal prüfen ob das WireView korrekt verkabelt ist!?
Habe den Wireview abgemacht. Ändert aber nichts am PL.
Übrigens erfreut sich die Strix LC Edition inzwischen an breiter Verfügbarkeit, nur ARLT scheint leer ausgegangen zu sein :fresse:
Ich habe den 12HPWR zu 12VHPWR. Ne Gsync habe ich aus. Spielt aber glaube ich bei OCCT keine Rolle.
Immer hin 0.3V bei 462W, also 11W Kontaktverluste/Wärmeverluste zwischen NT und Grafikkarte.
Wobei das ja nur gerundete Spannungswerte in der Telemetrie sind, und Spannungsspitzen garnicht mit aufgezeichnet werden. Ein Vergleich ohne WireView, und mit möglichst direkter Vebindung(Verkabelung) zum NT, wäre schon Mal ganz interessant. Dann könnte man auch sehen, ob das nur Messfehler in der GPU Telemetrie sind.
Lass dir doch wie hier beschrieben mal die NVSMI Daten anzeigen in Command Line Fenster:
Etwa so:
Bei mir sind es 0.2W unterschied.
Aber das kann es doch nicht sein.
Ein Nachteil der 12VHPWR-12VHPWR Verkabelung ist ja auch, das man nur eine der (eventuell vorhanden) zwei NT Rails nutzen kann. Wenn der PCIeSlot(Mainboard) an Rail1 hängt, und der 12VHPWR nur an Rail2, ist ein Spannungsunterschied nicht verwunderlich. Die beiden Rails werden dann ja unterschiedlich stark belastet.
Mit einer 12VHPWR-2x 8Pin Verkabelung, könnte man ja beide Rails zusammen schließen, und hätte am Ende mehr 12V Spitzenleistung (weniger SpannungEinbruch) am 12VHPWR der Grafikkarte.
Ähnliche Themen
