[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Geändert wird scheinbar sogar beides. Das betrifft vor allem auch die Seitenkräfte, da müsst Ihr schon mal alles lesen.
Denn da steht auch erkärt, warum es bisher vor allem immer die äußeren Kontakte getroffen hat. Klingt alles sehr schlüssig und plausibel und auch wenn ich sonst ungern Lob an Igor verteile, da hat er sogar von Anfang an Recht gehabt. Das GN Video genau einen Tag vor den Quartalszahlen war dann schon etwas sehr speziell. Alles auf die angeblich zu dummen User zu schieben, war eigentlich sogar frech. :(
Ja aber es ist ja trotzdem noch Kompatibel. Klar es gibt auch die Geschichte mit den verdrillten Kabeln und Zugentlastung etc. das macht ja alles Sinn, aber grundsätzlich kann man die alten Kabel noch verwenden.
Und selbst wenn, kostet das Austausch Kabel halt nochmal 30€, im Gesamtkontext ist das auch gerade egal und wird eh jeder gerne machen wenn man dafür seine Karte nicht grillt.
Naja aber was machen dann die NT Hersteller, die nun den neuen Anschluss direkt am Netzteil haben? Diese Netzteile sind ja dann nun zwar verwendbar aber haben die alte Buchse und sind somit wieder unsicher. Das alles kompatibel ist, sollte ja klar sein, weil die alten Buchsen ja nun bereits auf dem Markt sind aber ein unwohles Gefühl hat man dann ja durchaus schon. Wollte mir damals eigentlich das neue beQuiet NT kaufen aber bin nun froh, es nicht getan zu haben und warte dann mal, was von den Herstellern so kommt. Auch bin ich mal gespannt, welche RTX 40er Karten ein „Super“ Upgrade bekommen. Bei der 4090 wäre ja eher ein Titan/Ti Vollausbau sinnvoll.
Vermutlich wird es wieder neue NT Serien geben ATX 3.1 und für die alten Modelle neue Adapter.
jetzt haben wir alle mindestens 4 verschiedene Adapter für den Drecks-Anschluss und jetzt kommt was neues. :poop:
Läuft alles Tadellos mit meinem alten Corsair .
Wen die sich beim 3.0 Standard dann in den nächten 5 Jahren aus gekeckst haben dann Kauf ich mir auch erst ein neues.
Ich behalte mein aktuelles Cablemod Kabel auch für die nächste GraKa Gen. Habe da mittlerweile keine Bedenken mehr, das wurde jetzt schon ausreichend belastet.
Warum nicht, etwas Vaseline wird es schon richten. :sneaky:
Es gab auch schon User im Luxx die sich Knet in die Anschlüsse vom Board gestopft haben, legends never die.
Knet?
Also wenn dann mindesten Blu-Tack. Wer hart ist nimmt Butyl.
Was des Meisters Hand nicht ziert...
The fuck? Link bitte :fresse:
Und ich dachte schon ich hab teilweise blödes Zeug gemacht (Lüfter beim Testen fallen lassen oder den Finger oder ein Kabel reingekriegt, so dass einzelne Blätter abgebrochen sind o.ä.) aber Kalkreiniger in die Wakü ist hart.
Immer wenn man denkt man hätte schon alles gesehen.
Bis auf die versetzten SensPins sehe ich da jetzt noch keinen funktionellen Unterschied zum alten Standard. Und die versetzten SensPins helfen nur denen, die nicht erkennen ob der Stecker vollständig zusammengesteckt ist. Der neue Standard wäre nur ein Fortschritt, mit NTK Buchsen.
So sieht es aus. Werde mein ATX2.4 dann doch einfach noch etwas behalten und das Seasonic Kabel sitzt absolut sicher in der Buchse, da braucht es keine Revision.
@Slipknot hast du bemerkt, dass der Bug mit dem BlackScreen bei Multi-Screen seit fast einem Monat wieder vorhanden ist?!
Zwar nicht so dramatisch wie damals, aber dennoch ärgerlich.
Nein, da ist mir bis jetzt nichts untergekommen. Can mich nicht beklagen, Energiesparmodus habe ich laufend, sogar auf 5min eingestellt weil nun OLED am Start.
Ist aber natürlich nicht steif wenn die Shice wieder back in da hood ist. :rolleyes2:
@dante`afk ich habe keinen Twitter Account und kann deshalb derzeit nicht lesen was so gepostet wird. Was möchtest du uns da mitteilen?
Mal wieder Fotos vom Kühler einer 4090 Ti... Verpasst man nix
Ähnliche Themen
