[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Weiß ich nicht digga.
Mit deiner CPU läufst du schon hart ins CPU Limit der 4090.
4090 richtig eingestellt (DLDSR 2,25x /1,75x + DLSS), dann rennt da nix ins CPU limit. Der 8700k reicht da noch locker bis 2025. Vorallem werden die nächsten AAA games noch mehr GPUs fordern als jene die bisher rauskamen.
Kommt wirklich auf dem Anspruch an .
Habe selber halt gemerkt unabhängig von den FPS mit RPL wesentlich smoother anfühlt als mit Cometlake . Geil finde ich auch bei RPL und Alder natürlich auch es läuft auch mit den ganzen Energiesspar Modi einfach top . Mit Cometlake und andere ältere CPUs habe ich immer Mikro ruckler festgestellt wo ich dann die CPU auf Höchstleistung laufen lassen musste . Aber jeder empfindet auch anders .
Auch einen 8700K kann man übertakten.
Kann man, wegen dem alten zu kleinen Gehäuse hab ich aber nur ne Mini AiO drin, trotz das die CPU geköpft ist und nur mit 4,8 Ghz OC läuft, wird sie halt schon über 70°C warm. Aber wie gesagt, die CPU wird noch dieses Jahr ersetzt.
Mit etwas Aufwand, gäbe es schon Alternativen, um die Kleinsäugerbehaarung ab zu fangen, ohne die Lüfterleistung zu mindern. Nur macht das halt keiner, weil es scheiße aus sieht.
Na dann raus mit der Mini AiO. Platz sollte in deinem Case für was Größeres da sein.
Unterstützte Radiatoren: Front: bis 360 mm, Oben: bis 280 mm, Rückseite: bis 140 mm
Habe jetzt begonnen bei Aufbau oder Solo Kampagne Spielen öfters ohne Headset zu zocken und bemerke erst jetzt, wie schrecklich die 4090 TUF mit dem Wasserblock wirklich fiept/zirpt. Hört sich teilweise an, wie ein 56K Modem. :d Gibt es Lösungsansätze, die man testen könnte oder "muss" man damit leben?
Undervolting, Kùhler neu montieren, andere Pads nehmen und am effektivsten: Karte mit Referenz Layout und weniger Wandlern kaufen.
Hatte eine RTX 3090 TUF die Anfangs auch gezwitschert hat wie ein Vogelschwarm, nach einem viertel Jahr unter Wakù beim Bekannten war es deutlich vermindert nach einem weiteren viertel Jahr kaum noch zu hõren.
Was auch schon bei einigen zur Verminderung beigetragen hat: ein mehrstündiger Burnin mit sehr hohen fps, Futuremark Icestorm im Loop taugt z.B. dafür.
Interessanter Ansatz. Werde ich mal versuchen. Am besten gleich mit OC, damit der Stromverbrauch höher und die Spulen damit eher gefordert sind, oder?
Undervolting (irgendwo von 0,88v bis 0,95v)
Ich lasse die Karte schon mit ~2730 MHz @ 0.950v laufen und konnte den Stromverbrauch um fast 100W senken (Cyberpunk 450W -> 360W). Hilft auch ein wenig. Weniger Spannung empfiehlst du also. Habe ich bisher gemieden, weil ich keinen Leistungsverlust wollte. Werde ich auch versuchen.
Ich würde es mit Undervolting probieren… und dabei gleichzeitig übertakten.
Du meinst schon einen einfachen UV Curve in MSI Afterburner oder was anderes?
Hast du zufällig das Dead Space Remake zum Testen?
Hatte es schon mit der 3090 durchgespielt, aber kann es gerne wieder anwerfen. Die Karte fiep in jedem Game anders, da die Auslastung wohl nicht immer gleich ist. FPS Limitierungen helfen ein wenig. Selbst bei 120 FPS kann es je nach Spiel relativ laut sein. Aber die 240 Hz will man schon ausfahren, daher keine Lösung.
Neue Karte geht leider nicht mehr. :d Aber ich kann den Block schon mal im Wartungsfenster auseinander nehmen. Ergibt es Sinn die Pads auf den Spannungswandlern wegzulassen?
Nein, mehr Sinn macht es IMHO etwas dickere und besonders weiche Pads zu nutzen die den Raum zwischen Spulen bzw. deren Gehäusen fùllen kõnnen.
Besonders hohen W/mK müssen die Pads für die Spulen/Wandler nicht haben, denn theoretisch sind sie eher lauter bei geringerer Temperatur.
Und ein Netzteil mit mõglichst geringer Restwelligkeit auf 12V kann sich auch positiv auf die Intensität auswirken.
ich muss sagen, dass meine Strix bis vor kurzem auch vogelartige Geräusche von sich gegeben hat, aber dieses WE höre ich sie überhaupt nicht, obwohl sie direkt neben mir rechnet
Kann ich bestätigen, hatte mal ein Z590 Brett von Asus mit Spulenfiepen. Das war nicht penetrant, aber wenn man nah genug mit dem Ohr rangegangen ist, konnte man es dennoch deutlich vernehmen. Nach etwa einem halben Jahr in Betrieb verschwand das Spulenfiepen jedoch komplett.
Leider hilft UV halt nicht immer gegen das elendige Fiepen, auch wenn es (wenige) Ausnahmen gibt.
Meine 3090FE hat trotz massivem UV und allen anderen Tricks wie Framelimitierung trotzdem wie blöde geheult, da hat absolut gar nichts geholfen, außer halt einem Headset.
Bei der 4090 war ich diesmal nicht dazu bereit und wollte so lange tauschen bis die Karte Ruhe gibt und dann war’s gleich die erste.
Karma oder so, weil ich vorher so leiden musste 🤣
Manchmal bilde ich mir auch ein es ist Kopfsache. Wenn ich davon ausgehe, das alles garantiert einwandfrei sein wird, ist es das meist nicht. Wenn ich davon ausgehe, dass ich Probleme haben werde, gibt es dann meist doch keine. Daher tendiere ich oft das schlimmste zu erwarten, vielleicht hatte ich deswegen bisher so wenig echte Hardware Probleme. ;)
Achja, meine 4090 ist auch nur leise weil die Lüfter nicht zu hoch drehen, wenn sie das tun würde, wäre das Geräusch nicht ganz so angenehm. Meine alte Strix hat da primär nur Luftgeräusche produziert. Bei der jetzigen weiß ich nicht wie ich es beschreiben soll, es klingt nicht so richtig gleichmäßig. Hören tut man das aber erst so bei 70+%, so hoch muss sie normalerweise aber gar nicht drehen, von daher geht das in Ordnung.
Funfact: meine strix 3090 hatte übles fiepen (war extrem im Menü bei CODMW2) ingame wars ruhig.
Als ich die verkauft hatte, meinte der Käufer dann das er im Menü kein fiepen hat dafür aber ingame
Hatten beide ein limiter drinnen.
Soweit ich mich erinnere kann Spulenfiepen auch eine Kombi von Grafikkarte und Netzteil sein, bei einem anderen Netzteil kann das Ergebnis also ein anderes sein.
P.S. Was sich NVidia bei der Strombuchse gedacht hat die so zu platzieren... so ein unnötiger Designfehler, mal von der Buchse selbst abgesehen. Ich mein ich hab im Mai extra ein breites PC Gehäuse ausgesucht wegen dem. Da ist zwar genug Platz, dass die Kabel am Adapter nicht zu sehr gebogen werden, aber auch nur gerade so.
Zwar möglich, aber ziemlich selten. In den allermeisten Fällen, in denen berichtet wird, dass nach einem PSU-Wechsel plötzlich Ruhe ist, wird vermutlich eigentlich das Netzteil selbst gefiept haben und vorher hat mans nur nicht bemerkt, da am PSU weniger Last anlag.
Keine Ahnung, ist schon ein paar Jahre her, dass ich darüber gelesen hatte. Habs nicht weiter verfolgt, da ich das Problem so noch nie hatte.
Naja die Matrix ist der Strix sehr ähnlich bis auf paar Temp Sensoren.
Eigentlich ist die KFA 4090 HOF was besonderes , aber so eine Karte gibt es scheinbar im Handel nicht.
Bedeutet das neue PSUs, neue RTX 40xx Super Karten (Spoiler im Video von Igor) und doch keine Ti oder Titan?
Mein Verständnis ist, dass nur die Buchse auf der Karte aktualisiert wird, sodass sie mehr Leistung abkann (also die einzelnen Pins mehr Ampere abkönnen um bei ungleichem Kontakt von anderen Pins den Verlust bei schlechtem Kontakt ausgleichen zu können und dann nicht sofort abfackeln). Außerdem werden die Sense Pins etwas nach hinten geschoben damit der Stecker 100% drin sein muss damit überhaupt die Leistung anliegen kann.
Nö hat doch im Video und im Artikel gesagt , dass es kompatibel ist mit den jetzigen Kabel.
Ne die Buchsen werden verändert an den Karten die dann kommen werden . Die Kabel der NTs werden weiter funktionieren und müssen keine neuen gekauft werden . Könnt ja den Artikel selber lesen . Das Video ist bisschen anstrengend . Zumindest gilt das für 450/600 Watt . Da kommt noch was hinzu für Erkennung 150/300 Watt , aber gibt es aktuell noch garnicht .
Ähnliche Themen
