[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Genau das übliche eben.
Bin mal gespannt, ob sie diesen Klotz in der gleichen OVP verstaut bekommen, wie die, die auch bei der 4090/4080/4070/4060 Ti verwendet wird.
Wenn sich die Karte und das PCB Design bewahrheiten sollte - was ich bezweifle - freue ich mich darauf, ob und mit was für Ideen Aftermarket Kühler umgesetzt werden :d
Mal wieder Fotos vom Kühler einer 4090 Ti... Verpasst man nix
Danke dir. Klar, da verpasst man nichts. Aber es hätte ja auch irgendwas offizielles von nVidia oder sonstwas sein können. Wie gesagt: derzeit seh ich da garnix. Und neugierig ist man ja auch.
Also wenn so ein Ding wirklich kommen sollte, dann ist das das zweite Ding auf der Welt neben der F-35, das sich den Namen "fat Amy" wirklich verdient hat.
Die Namensänderung hätte nicht sein müssen. Im Gegenteil. Das liest sich im ersten Moment wie wenn die alten 6 Pin Stecker zurück wären. Die zurückgesetzten Sense-Pins sind aber wirklich sinnvoll. Und wenn sie wirklich noch die Federkontakte nehmen, die länger/besser greifen, dann ist das auch sinnvoll. Ob das so ausreicht, oder ob man nicht lieber etwas mehr hätte machen sollen wie z.B. eine zweite Klemme, oder Außenklemmen, das wird die Zeit zeigen.
Bei mir hält der Asus-Stecker (müsste Seasonic sein) recht gut und ich konnte ihn auch früher biegen als man sollte. Habe aber auch peinlich aufgepasst, dass die Klemmen alle gleich weit vorne im Stecker sitzen und nicht irgendwie herumeumeln.
Der alte Name ist eben mit zu viel Negativität verbunden, also bereits verbrannt. :LOL:
Die Änderungen an Buchse und am Stecker/Kabel klangen jedenfalls alle sinnvoll. Im Grunde hat man das Ganze nur DAU sicherer gemacht, wenn man beim Einbau eigentlich richtig auf alles achtet kann an sich nicht viel passieren.
Was regt ihr euch über den Namen eines Steckers auf?
Wie ich schon sagte, wäre die neue Buchse nicht nötig gewesen, nur weil so ein paar Experten nicht in der Lage waren einen Stecker richtig ein zu stecken. /:
Ich dachte das wäre schon lange widerlegt, dass es immer am User liegt? Davon mal abgesehen, dass es natürlich Fälle gibt wo genau das der Grund ist.
An wem es nun liegt, da gibts ja doch recht unterschiedliche Ansichten.
Ich fänds gerade spannend, zu wissen, wie hoch die von der Karte ermittelte Spannung bei den Karten gewesen ist, bei denen etwas geschmolzen ist.
Sofern die da wegen dem erhöhten Übergangswiderstand und der deswegen starken Erwärmung immer kleiner 12V gewesen ist, könnte einen der Treiber ja sogar warnen.
Das was die ganzen Tools auslesen, kommt ja eh immer über eine Schnittstelle im Treiber.
Nix ist widerlegt. In jedem Video dazu wird einfach das Spiel, dass der Stecker haben kann als Grund herangeführt, dass es eine schlechte Konstruktion sei. Wenn ich mir aber Steckdosen in den USA beispielsweise anschaue, ist das bullshit.
Die Leute bauen sich PCs zusammen aber können nicht darauf achten, dass ein Stecker richtig im Socket sitzt? Nee is klar.
Wie schon jemand richtig sagte, es wurde einfach nochmal DAU sicher gemacht.
Habe von Asus gehört das die auch beim Steckernamen mitreden wollten. Der Vorstand hat sich aber dann dagegen entschieden. Sperrspitze12V bzw. HolzmannConnect würden zwar eine Nähe zum Asus Portfolio aufzeigen, aber man hatte Befürchtungen das andere Hersteller hier nicht mitgezogen wären.
Wenn der Steckername ein Diskussionsthema wird, ist ein gut funktionierender Standard noch in weiter Ferne. Was für ein Armutszeugnis.
Weil der neue Name noch blöder ist als der alte.
Und Poka Yoke sagt dir was? Ich meine zumindest das Sicherstellen dass die Karte aus bleibt wenn einer "nicht in der Lage" war richtig zu stecken ist ein sinnvolles Prinzip. Lieber gibts Anfragen dass die Karte nicht läuft als dass der Stecker geschmort ist.
Und ich beziehe mich auf die Normalfälle, explizit nicht auf die Cablemod Fälle. Was da los ist habe ich bis heute nicht durchdrungen. Soll ja hier auch einen Fall gegeben haben der Stein und Bein schwört dass der Stecker richtig drin war. Und das möchte ich dann nicht in Abrede stellen. Dann wars u.U. was anderes. Ob es nun der Winkeladapter war oder ob es die 180° Buchse war ist mir dabei egal. Wie im richtigen Leben: Wenn der richtig drin steckt, muss da was gehen - und nicht nur Hitze als Ergebnis.
Ich denke mal die gehen paar Schritte auch weiter , damit das Dinge auch von den Herstellern vernünftig hergestellt wird und unter anderem bei Anwenderfehler die Karte nicht startet.
Die hätten sich im Vorfeld mehr gedanken machen müssen, aber heutzutage wundert mich garnichts mehr . Vielleicht denkt ja irgendwann eine KI an sowas :shot:
Gibt es hier im Luxx überhaupt jemanden bei dem der 12vhpwr geschmolzen ist?
Bei einem der aber irgendwann nichts mehr dazu geschrieben hat.
Müssten 2 sein, oder?
Der erste Reddit Fall überhaupt (damals, war sogar die 4er Peitsche an einer Gigabyte Gaming OC) und dann noch jemand mit einem Cablemod Adapter
So die 4090 FE kann bald ins Air Mini umziehen hab alle Löcher mit weißen Kunststoff ausgekleidet und in der Front den Metall Rahmen ersetzt gegen eine weiße Kunststoff Halterung sieht schön clean aus.
Die 140er gehen auf ca 215 Umdrehungen runter und die 120er bis auf um die 240Touren wo absolute Stille herrscht.
Auch Schotts für die Externe Wasserkühlung sind gesetzt .
Das 1000D kann dann jemand anderes schleppen.
Über was schreibt Igor eigentlich, wenn das Stecker Thema durch ist? :unsure:
Das Thema scheint ja nicht gerade wenig zu interessieren ;)
Vorab: ich hab keine Aktien an Igor W. allerdings muss man die Frage dann schon so fair gestalten, dass man fragt welche News und Berichte es denn mal geben wird wenn das Thema durch ist. Denn gefühlt ist das Stecker Ding der Aufreger seit Einführung der 4090.
Sicherlich schweinchen dumm für den den es erwischt. Insbesondere wenn sich der Hersteller dann noch zum Ferkel Verhalten hinreissen lässt. Aber sooooo schlimm scheint es dann auch wieder nicht zu sein, weil ja nun nicht täglich die Karten abfackeln. Da gibts in anderen Branchen noch viel teurere Zeitbomben (Ölpumpen die Sterben, AGR-Kühler die undicht werden etc.).
Warum sind denn nun eventuelle zukünftige Artikel und Themen eines anderen Portals hier Thema :confused:
Mich jedenfalls hat "Igor" auch schon vor dem Stecker-Gate gut unterhalten. Die Qualität und Fachkenntnisse seiner Artikel muss man erstmal besser machen. Room for improvement ist überall.
Hier wird generell jeder gehatet der auf Youtube Videos zu Hardware macht. Sind alle nur klickgeil oder gekauft und haben sowieso keine Ahnung.
Ähnliche Themen
