• Supports 512-Mb and 1-Gb DDR3 DRAM technologies for x8 and x16 devices.
• Using 512 Mb device technologies, the smallest memory capacity possible is
256 MB, assuming Single Channel Mode with a single x16 single sided un-buffered
non-ECC DIMM memory configuration.
• Using 1 Gb device technologies, the largest memory capacity possible is 8 GB,
assuming Dual Channel Mode with four x8 double sided un-buffered non-ECC or
ECC DIMM memory configurations. [B]Note: The ability to support greater than the
largest memory capacity is subject to availability of higher density memory
devices.[/B]
