eternety
wenn man wüsste was auf dem usb-stick drauf is könnte man sich selbst einen erstellen.![]()
Gibts auf ps3news.com zum Download.
und wer testet es mal ^^
Ich hab nur die alte 60gb und hab die seit Jahren nicht voll bekommen, immer noch 35gb frei. Kauf sie dir und schau einfach wieviel Speicher du brauchst , du kannst immer noch aufrüsten falls nötig
Hab leider keine PS3 Spiele mehr hier![]()
The product description and FAQ from various websites:
Q: What firmware version does PS JailBreak it work on?
A. It apparently works on a couple of old firmware verisons, but it was designed for the latest firmware version 3.41
Q. Does PS Jailbreak allow you to dump ps2 games, ps1 game, Blu ray movies?
A. No, just PS3 games.
Q. Does PS JailBreak allow every game to work?
A. Apparently 150 games have been tested, and they all work. If a game happens to have 1 file over 4gb the program will not be able to rip the game onto the harddrive. Apparently the worl around is to dump it on an internal hardrive
Q. Can I still play online with PS Jailbreak?
A. When today (19.08.2010) you can, we can't guarantee you will never be banned for using the 3rd party device.
Q. Can Sonly block this with firmware updates?
A. Probably. The have have the USb dongle firmware upgradable, but you can never predict the future. This is made to work with 3.41. If you happen to download an install an update which is higher then this then it is your doing. We will not accept stock back as "faulty" if you have upgraded your firmware.
The board is unavailable at the moment due to heavy traffic.
PS Jailbreak is a USB plug and play solution that installs in seconds, keeping your valid warranty seal in tact.
Easy to use installer and GUI takes you step by step.
Compatible with all production models FAT and SLIM. Supports all regions: USA, JAP, PAL and KOREA
PS Jailbreak disables forced software updates and will never brick your console.
Supports all games (it does not allow backups of bluray movies , dvd movies , or past consoles games)
Backup games to your internal hard drive or external hard drive through USB, and boot directly off GUI. Eliminating the need for expensive blueray burners and costly blank media.
Play backups off your hard drives 2x as fast as off the blueray drive. This eliminates lags and glitches to provide you with smoother game play.
Open up your console to a new generation of homebrew applications. Load homebrew apps/games off any USB hard drive/flash drive.
Fully updatable with new features/updates by connecting PS Jailbreak to any computers USB port.
Bräuchte man dann nicht USB Stick in der Größe von ner BR?
@eternetyGerüchten zufolge wird der Backup-Manager auch von Sony benutzt und auch daher stammen.
Nunja, mal schauen...wird ja dann wieder hochkonjunktur in den Videotheken geben
€: Naja wird von Hersteller (kA wer das genau ist) verkauft. Aber eine Quelle hat es eben geschafft den Stick zu kopieren![]()
@eternety
@DeadNade: Iwie funzt der Link nicht, ist der Server überlastet oder was ist da los?
Mal von dem "Raubkopierer"-BlaBlaBla abgesehen, finde ich den Punkt das die Spiele deutlich schneller geladen werden sollen sehr interessant.
Gerade das hab ich an meiner alten XBox so geliebt. Schade das Sony sowas nicht offiziell einführt.
weil dann keiner mehr ein SPiel kauft vielleicht?
@DeadNade:
Hab das jetzt aufm USB Stick geknallt, aber die PS3 zeigt nix an... Nirgends.
Schade.
Da das FAQ ja nicht geht, denke ich mal, man braucht eine bestimmte Ordnerstruktur, damit es die PS3 erkennt.
