Build 169 (9/3/12, Team Member +)
MUST START A NEW PROFILE WITH THIS BUILD
Adjust grid placement percentages to 80% performance, 20% random
Fix in weather system for restarting a race
Adjusted minimum AI defaults
Fixes for cockpit steering wheel/driver arms anims during AI control and replay playback
HUD display: Fixed rpm bar background colour, added fuel readout
Fixed up Badenring grids and opponent counts
Corrected opponent count for Derby and Wisconsin
Added overall AI difficultly range based on place on grid using 60% position and 40% random to bias the field to stronger drivers at the front.
Removed applinks and data from the profile for old AI sliders
Bumped version of all vehicles for Friday's stat reset
Reinstated use of phase 2 lighting data for trees - this allows headlights to cast onto them correctly
Caterham R500: LODA/B springs added
GUMPERT physics update
Constraint orientation of contact between vehicles is adjusted to help prevent scooping
Added a small range to AI driver minimum default sliders
New Caterham export
New Badenring historic export
New Belgium Forest export
New Loire exports
New Rouen export
Wisconsin Raceway added
Derby GP and National added
Build 168 (8/3/12, Senior Manager)
Input: Default menu centering spring strength reduced to 0.15 for Fanatec CSRE.
Random settings for AI settings based on min/max ranges
New ranges for AI character tweakers to allow a larger set of characterisations
AI opponents max set to 35 for new AIW. New AIW with working pitlane, 18 pit spots and 36 garage spots. New Line and corridor tweaking for AI at Bathurst
Belgian forest - performance update
Added updated tracklist and xmls for Rouen (raceline and trees)
New Badenring exports
New Bathurst exports
Rouen added
Badenring Historic added
Build 167 (7/3/12, Senior Manager)
Update tyre noise code defaults to match latest data
Remove HUD leading zero on lap time minutes and remove minutes from +/- times when zero
AI and Player Headlight mapping, default mapping is numpad 3. This can be changed in the controller config page
AI used random number to work when it should turn on its lights
Fix for bug with lights on restart and beams during the day
Shadows fix for black/clear patches appearing when shadows are very long
Static envmap convolve is now done on a seperate frame to the render, distributing the cost (gains about 8-10% overall fps)
Complete overhaul of UI centering spring implementation
Shadow FXAA only applied in high or ultra shadows
Build script : Added support for split installer ziping for patches
Asano X4: new LIGHTS material/textures for fully lit headlight case
Default day changed to june 22nd, daylight saving, location venice (nearest to bologna), new textures added for skies with higher sun
Reduced headlight spread a little.
Updates with 54 angles garage spots in theAIW. Set TRD to maxim of 53 AI at California Raceway
Added West Glencairn crowd placemt
Added new & up-to-date TRDs for the Badenring (GP, NAT, Short, Historic)
F68: more physics changes for stability
Badenring logo/temp map added
Formula A: Physics changes
New Asano X4 export
New Gumpert Apollo export
New Connecticut Hill exports
Badenring added to the game
Known Issue: Modern driver in the F68
Build 166 (6/3/12, Manager+)
HUD: fixed overlapping on laptimes element
Added 46 grage spots. Reset TRDs to suport 46 car grid at Connecticut Hill
Reset max participants to 32 until garage spots can be set at Bologna
Increase amount and volume of tyre noise
Bug fixing on ToD
Build 165 (5/3/12, Senior Manager)
Code to spread the generation of the emvmaps over time
Add ability to override gearstick animation use per view
Switch CNM driver mode to use 3PV animation but with gear-changes enabled
Fixes for spot shadow filtering (and directional shadow filtering on ATI)
Gumpert Apollo: physics update
Gumpert Apollo: skid multiplier adjusted for new tires. lowered turbo volume as it was overpowering the scene
Formula A: physics changes to improve low speed stability
New Belgian Forest export
New Bologna exports
