Known Issues: Ghost car seems to disappear in the rear view mirror. We have an issue with alt-tab in DX9 making the game crash, it crashes when used in race, and also if you do it in the menu it will crash the 2nd time you enter race.
Debug Keys:
* Moved debug key for "toggle dirt" from being "dev only" to being available in members build
* Disabled screen grab in DX11 mode, until full fix is ready (only in race, will still crash if used in the main menu)
Render:
* Updated call to use Base abstract BStrcpy
* Render the Skydome in phase 1 of the RVM - needed for the depth faded particles (tyre smoke etc) to ZBuffer correctly against the sky
* Bonnet envmap rendering corrected for carbon skinned parts (eye vector normalization added in fragment shader); well this will slightly affect more things on skinned parts, but this one was reported
* Bonnet envmap rendering corrected for skinned parts (eye vector normalization added in fragment shader); well this will slightly affect more things on skinned parts, but this one was reported
* ShadowMap lookup upgraded to 5x5 PCF
Ghost Mode:
* Ghost Rendering Tasks and related changes - makes ghost cars render translucently
Bug Fixes:
* (probable) Fix for cars disappearing in the rear view mirror
* White Edges Bug Fixed (both DX9/DX11)
* Fix for HUD cockpit dials (solid elements) receiving SSAO
* Fixes left key pressing in main menu affecting the camera choices
* Fixed ghost imposter shader to work within deferred renderer
* Depth faded particle shader fixed to correctly honour the viewport dimensions
Crowds:
* New sitting crowds for Milan tracks
Audio:
* Balancing tweaks
* Further balancing changes to Road tyres
* Surface fdp updated for non slick tyred cars (more road roll)
GUI:
* Pirault logo added to splash screen
Tracks:
* Connecticut Hill: Added revered kerbs, fixed csm and tearing issues, added missing fence poles
* Azure Circuit: Green neon lights added
* Azure Circuit: New texture map
* Azure Circuit: Finished to rework kerbs and cut the mesh under them, reworked wrong armco and added missing ones, reworked sidewalk in front of the hotel the paris, mirabeau-fairmont, added missing conc side kerb, fixed geometry and mapped where needed, merged latest from JanP, fixed csm, fixed conc barriers positio
* Milan: Fixed wet reflection on gravel materials
* Milan: Added racing line, skids, adverts
* Eifelwald: Added viewer placed lights , added cars and tents around track, lowered and narrowed Hatzenbach kerbs, fixed microgaps in the adenauer forest s curve, added more viewer placed lights tents and cars
Vehicles:
* Updated paint colours with rain effect
* Fixed shader code which made matte paint look glossy when rain support was enabled
* BMW M3 GT: Added liveries 03/04 names
* BMW M3 GT: Added 2 fictional liveries
* Caper Monterey (road): removed wedge and left weight bias from default setup
* Pagani Huayra: Fixed carbon material not getting rain effects
* Pagani Zonda R: Wiper animation and wiper mask added
* Ford Focus RS: fixed a typo causing asymmetry in the front suspension geometry
* Ford Focus RS: accurate gear ratios, default setup from Jussi's research into stock values
* Staro SRS: Idle throttle adjusted to allow stalling, downforce from reference article
* Staro SRS: Fixed cockpit animations
* Pirault Mega SR: Basic physics setup with accurate engine, gearbox and some suspension data
* Pirault Mega SR: Added audio
* Pirault Mega SR: Added runtime files
* Pirault Mega SR: Added textures
* Pirault Mega SR: Added collision export
* Pirault Mega SR: Added srcdata/physics files
* Pirault Mega SR: Added paint colours + cockpit display
* Pirault Mega SR: Alpha2 driver animations
* Pirault Mega SR: Added first export
