RC5-72 Offtopic Thread
ps. kanns sein dass ich nur halbe kraft fahre?
hab immer nur 3,000.000 keys/sec
und das proggi rennt immer
net idle cycles
komisch oder?
normal müsste ich doch so um die 6,000.000 haben oder?
...bei dir laufen doch 2 Prozesse... also jedes mal 3 mkeys/s... damit haste doch 6...du crunchst halt immer gleich 2 WUs....
[Dec 20 16:16:06 UTC] RC5-72: 117 packets (117.00 stats units) are in
buff-out.r72
.....10%.....20%.....30%.....40%.....50%.....60%.....70%.....80%.....90%....100
[Dec 20 16:59:52 UTC] RC5-72 #b: Completed CA:CD6C219D:00000000 (1.00 stats ...
0.00:43:45.03 - [1,636,183 keys/s]
[Dec 20 16:59:52 UTC] RC5-72 #b: Loaded CA:CD6C219E:00000000:1*2^32
[Dec 20 16:59:52 UTC] RC5-72: Summary: 76 packets (76.00 stats units)
1.06:37:10.37 - [2,906,066 keys/s]
[Dec 20 16:59:52 UTC] RC5-72: 93 packets (93.00 stats units) remain in
buff-in.r72
Projected ideal time to completion: 1.08:55:28.00
[Dec 20 16:59:52 UTC] RC5-72: 118 packets (118.00 stats units) are in
buff-out.r72
[Dec 20 17:00:29 UTC] RC5-72 #a: Completed CA:CD6C219C:00000000 (1.00 stats ...
0.00:53:10.03 - [1,346,391 keys/s]
[Dec 20 17:00:29 UTC] RC5-72 #a: Loaded CA:CD6C219F:00000000:1*2^32
[Dec 20 17:00:29 UTC] RC5-72: Summary: 77 packets (77.00 stats units)
1.06:37:47.39 - [2,944,041 keys/s]
[Dec 20 17:00:29 UTC] RC5-72: 92 packets (92.00 stats units) remain in
buff-in.r72
Projected ideal time to completion: 1.08:34:14.00
[Dec 20 17:00:29 UTC] RC5-72: 119 packets (119.00 stats units) are in
buff-out.r72
.....10%.....20%a....30%b
meine aktuelle seite
buff-out.r72
buff-in.r72
buff-out.r72
buff-in.r72
buff-out.r72
Teilweise nur 1.3k? das ist heftig damit bist du ja langsamer als der kleine XP von meiner Freundin. Der hat wenigstens 5.3k
[Dec 20 12:59:12 UTC] RC5-72: Completed CA:CAF581FE:00000000 (1.00 stats units)
0.00:08:06.64 - [8,825,893 keys/s]
[Dec 20 12:59:12 UTC] RC5-72: Loaded CA:CAF581FF:00000000:1*2^32
[Dec 20 12:59:12 UTC] RC5-72: Summary: 9 packets (9.00 stats units)
0.01:21:06.28 - [7,838,859 keys/s]
[Dec 20 12:59:12 UTC] RC5-72: 276 packets (276.00 stats units) remain in
buff-in.r72
Projected ideal time to completion: 1.13:15:36.00
[Dec 20 12:59:12 UTC] RC5-72: 15 packets (15.00 stats units) are in
buff-out.r72
[Dec 20 13:07:20 UTC] RC5-72: Completed CA:CAF581FF:00000000 (1.00 stats units)
0.00:08:06.85 - [8,822,086 keys/s]
[Dec 20 13:07:20 UTC] RC5-72: Loaded CA:CAF58200:00000000:1*2^32
[Dec 20 13:07:20 UTC] RC5-72: Summary: 10 packets (10.00 stats units)
0.01:29:13.13 - [7,928,280 keys/s]
[Dec 20 13:07:20 UTC] RC5-72: 275 packets (275.00 stats units) remain in
buff-in.r72
Projected ideal time to completion: 1.13:07:30.00
[Dec 20 13:07:20 UTC] RC5-72: 16 packets (16.00 stats units) are in
buff-out.r72
[Dec 20 13:15:27 UTC] RC5-72: Completed CA:CAF58200:00000000 (1.00 stats units)
0.00:08:07.01 - [8,819,188 keys/s]
[Dec 20 13:15:27 UTC] RC5-72: Loaded CA:CAF58201:00000000:1*2^32
[Dec 20 13:15:27 UTC] RC5-72: Summary: 11 packets (11.00 stats units)
0.01:37:20.14 - [8,002,573 keys/s]
[Dec 20 13:15:27 UTC] RC5-72: 274 packets (274.00 stats units) remain in
buff-in.r72
Projected ideal time to completion: 1.12:59:24.00
[Dec 20 13:15:27 UTC] RC5-72: 17 packets (17.00 stats units) are in
buff-out.r72
[Dec 20 13:23:34 UTC] RC5-72: Completed CA:CAF58201:00000000 (1.00 stats units)
0.00:08:06.84 - [8,822,267 keys/s]
da schickt mich , das war während ich @ work war , die kiste war nur unter muhkuh last , hat trotzdem schwankungen wie sau drinne ..
ja WISO?
warte poste mal meien config
habe aber immer volle auslastung
als das proggi rennt auch wenn ich surfe
also net nur idle
also surfen geht zwar ohne probleme aber das der kaum was reisst stresstwien sau
[parameters]
id=#########termis mail
[misc]
project-priority=RC5-72,OGR-P2=0
[rc5-72]
fetch-workunit-threshold=200
fetch-time-threshold=12
[buffers]
threshold-check-interval=0:01
[triggers]
restart-on-config-file-change=yes
[processor-usage]
priority=0
[display]
progress-indicator=relative
[logging]
log-file-limit=500kB
log-file=d-net.log
log-file-type=fifo
[networking]
autofindkeyserver=no
keyserver=*:2064;proxy.rc5team.de;teamproxy.dyns.net
stell ein das er nur eine wu cruncht dann hast du deine 6 Mkeys und dank HT hast du nur 50% CPU Auslastung;)
...:hmm:... ist wirklich extrem wenig... ich hab egal was ich mach... immer ~8,5 mkeys/s hier aufm Hauptrechner...
