RC5-72 Offtopic Thread
m0e schrieb:
stell ein das er nur eine wu cruncht dann hast du deine 6 Mkeys und dank HT hast du nur 50% CPU Auslastung;)
kann dir gerne mal nen taskmanager scren amchen mit rc5 daneben
hab bei beiden cpus volle auslastung
und dc´netc.exe hat immer zw. 95-97 cpu-auslastung laut prozessmanager
[Dec 20 18:09:47 UTC] RC5-72: using core #0 (SES 1-pipe).
[Dec 20 18:10:08 UTC] RC5-72: Benchmark for core #0 (SES 1-pipe)
0.00:00:17.53 [2,650,363 keys/sec]
[Dec 20 18:10:08 UTC] RC5-72: using core #1 (SES 2-pipe).
[Dec 20 18:10:27 UTC] RC5-72: Benchmark for core #1 (SES 2-pipe)
0.00:00:16.84 [3,967,850 keys/sec]
[Dec 20 18:10:27 UTC] RC5-72: using core #2 (DG 2-pipe).
[Dec 20 18:10:46 UTC] RC5-72: Benchmark for core #2 (DG 2-pipe)
0.00:00:16.64 [2,986,243 keys/sec]
[Dec 20 18:10:46 UTC] RC5-72: using core #3 (DG 3-pipe).
[Dec 20 18:11:06 UTC] RC5-72: Benchmark for core #3 (DG 3-pipe)
0.00:00:16.28 [4,407,312 keys/sec]
[Dec 20 18:11:06 UTC] RC5-72: using core #4 (DG 3-pipe alt).
[Dec 20 18:11:25 UTC] RC5-72: Benchmark for core #4 (DG 3-pipe alt)
0.00:00:16.93 [3,696,292 keys/sec]
[Dec 20 18:11:25 UTC] RC5-72: using core #5 (SS 2-pipe).
[Dec 20 18:11:44 UTC] RC5-72: Benchmark for core #5 (SS 2-pipe)
0.00:00:16.26 [3,125,085 keys/sec]
[Dec 20 18:11:44 UTC] RC5-72: using core #6 (GO 2-pipe).
[Dec 20 18:12:03 UTC] RC5-72: Benchmark for core #6 (GO 2-pipe)
0.00:00:17.04 [3,976,830 keys/sec]
[Dec 20 18:12:03 UTC] RC5-72: using core #7 (SGP 3-pipe).
[Dec 20 18:12:23 UTC] RC5-72: Benchmark for core #7 (SGP 3-pipe)
0.00:00:16.71 [5,826,587 keys/sec]
.....10%.....20%.....30%a....40%.....50%...b
oder eben core 7 ...:fresse:
[Dec 20 18:13:33 UTC] OGR-P2: using core #0 (GARSP 6.0-A).
[Dec 20 18:13:52 UTC] OGR-P2: Benchmark for core #0 (GARSP 6.0-A)
0.00:00:16.87 [12,288,854 nodes/sec]
[Dec 20 18:13:52 UTC] OGR-P2: using core #1 (GARSP 6.0-B).
[Dec 20 18:14:12 UTC] OGR-P2: Benchmark for core #1 (GARSP 6.0-B)
0.00:00:16.65 [11,274,371 nodes/sec]
wie genau? einstellen?
unter menu: 3 - cores : dort was schreiben? rc...7 ; o... 0
...ja und nein... nimmt dann allen anderen Prozessen die Power weg... d.h. du kannst auch nimmer gescheit zocken...
argh laut dem info fenster das auf geht wenn ich mit maus @ symbol @ statusleiste gehe sagt der immernoch ~ 3.000.000
:hmm:
buff-out.r72
[Dec 20 18:17:13 UTC] 2 crunchers ('a' and 'b') have been started.
.....10%.....20%.....30%.....40%.....50%.....60%.....70%.....80%.....90%....100
[Dec 20 18:33:29 UTC] RC5-72 #b: Completed CA:CD6C21A0:00000000 (1.00 stats ...
0.00:16:15.90 - [1,678,851 keys/s]
[Dec 20 18:33:29 UTC] RC5-72 #b: Loaded CA:CD6C21A2:00000000:1*2^32
[Dec 20 18:33:29 UTC] RC5-72: Summary: 80 packets (80.00 stats units)
1.08:10:47.85 - [2,890,517 keys/s]
[Dec 20 18:33:29 UTC] RC5-72: 89 packets (89.00 stats units) remain in
buff-in.r72
Projected ideal time to completion: 1.07:37:11.00
[Dec 20 18:33:29 UTC] RC5-72: 122 packets (122.00 stats units) are in
buff-out.r72
[Dec 20 18:52:19 UTC] RC5-72 #a: Completed CA:CD6C21A1:00000000 (1.00 stats ...
0.00:35:05.04 - [1,291,981 keys/s]
[Dec 20 18:52:19 UTC] RC5-72 #a: Loaded CA:CD6C21A3:00000000:1*2^32
[Dec 20 18:52:19 UTC] RC5-72: Summary: 81 packets (81.00 stats units)
1.08:29:37.42 - [2,885,855 keys/s]
[Dec 20 18:52:19 UTC] RC5-72: 88 packets (88.00 stats units) remain in
buff-in.r72
Projected ideal time to completion: 1.07:15:52.00
[Dec 20 18:52:19 UTC] RC5-72: 123 packets (123.00 stats units) are in
buff-out.r72
.a...10%.....20%.....30%.....40%....b
wiso hab ich immer noch nur ~3.000.000
buff-out.r72
buff-in.r72
buff-out.r72
buff-in.r72
buff-out.r72
weil dein pimmel so klein is :p
ne keine ahnung
[Dec 20 19:07:25 UTC] RC5-72: using core #2 (DG 2-pipe).
[Dec 20 19:07:45 UTC] RC5-72: Benchmark for core #2 (DG 2-pipe)
0.00:00:17.18 [2,981,899 keys/sec]
[Dec 20 19:07:45 UTC] RC5-72: using core #3 (DG 3-pipe).
[Dec 20 19:08:06 UTC] RC5-72: Benchmark for core #3 (DG 3-pipe)
0.00:00:17.67 [4,204,899 keys/sec]
[Dec 20 19:08:06 UTC] RC5-72: using core #4 (DG 3-pipe alt).
[Dec 20 19:08:25 UTC] RC5-72: Benchmark for core #4 (DG 3-pipe alt)
0.00:00:16.73 [3,597,670 keys/sec]
[Dec 20 19:08:25 UTC] RC5-72: using core #5 (SS 2-pipe).
[Dec 20 19:08:44 UTC] RC5-72: Benchmark for core #5 (SS 2-pipe)
0.00:00:16.51 [3,033,749 keys/sec]
[Dec 20 19:08:44 UTC] RC5-72: using core #6 (GO 2-pipe).
[Dec 20 19:09:03 UTC] RC5-72: Benchmark for core #6 (GO 2-pipe)
0.00:00:16.98 [3,976,830 keys/sec]
[Dec 20 19:09:03 UTC] RC5-72: using core #7 (SGP 3-pipe).
[Dec 20 19:09:23 UTC] RC5-72: Benchmark for core #7 (SGP 3-pipe)
0.00:00:16.65 [6,125,933 keys/sec]
[Dec 20 19:09:23 UTC] OGR-P2: using core #0 (GARSP 6.0-A).
[Dec 20 19:09:43 UTC] OGR-P2: Benchmark for core #0 (GARSP 6.0-A)
0.00:00:16.86 [13,088,258 nodes/sec]
[Dec 20 19:09:43 UTC] OGR-P2: using core #1 (GARSP 6.0-B).
[Dec 20 19:10:03 UTC] OGR-P2: Benchmark for core #1 (GARSP 6.0-B)
0.00:00:17.03 [11,568,369 nodes/sec]
das sin die benchs nun stell ich ein:
Core selection:
This option determines core selection. Auto-select is usually best since
it allows the client to pick other cores as they become available. Please
let distributed.net know if you find the client auto-selecting a core that
manual benchmarking shows to be less than optimal.
Cores marked as 'n/a' are not applicable to your particular cpu/os.
RC5-72:-1) Auto select 0) SES 1-pipe 1) SES 2-pipe
2) DG 2-pipe 3) DG 3-pipe 4) DG 3-pipe alt
5) SS 2-pipe 6) GO 2-pipe 7) SGP 3-pipe
OGR-P2:-1) Auto select 0) GARSP 6.0-A 1) GARSP 6.0-B
Default Setting: -1 (auto-detect)
Current Setting: RC5-72=7,OGR-P2=0
New Setting --> RC5-72=7,OGR-P2=0
und
1) Core selection ==> RC5-72=7,OGR-P2=0
2) Number of crunchers to run simultaneously ==> 2
3) Priority level to run at ==> 0 (lowest/at-idle)
setzt das mal auf 1!;)
Terminator schrieb:
...das bringt ja aber von der Performance nix...
doch .... also als ich noch nen P4 mit HT hatte war HT langsamer..... zwar nicht viel aber war so... ;)
evtl is es mit den neuen Versionen auch anders....
mfg m0e
mfg m0e
aber wenn ich keine 2 gleichzeitig mache dauerts doppelt so lange
