henniheine
Urgestein
Besser als Kino hier.
Das mit dem FOV ist mir neu. Habe einen 16:10 Monitor und werde dann mal das 83' probieren...
INSTALLATION
1) Reinstall your version of S.T.A.L.K.E.R. Call of Pripyat (retail and Steam supported)
2) Make sure that everything about the installation is clean on your harddrive.
3) Extract the mod data file (rar/zip) anywhere on your hardrive.
4) Merge the data parts if downloaded from a mirror where the mod is not “all-in-one”
3) Use the .exe installer provided with MISERY
4) Choose your FOV (Field of View).
FOV NOTION:
83′ or 85′ is recommended for 16:9 monitor formats.
75′ or below is recommended for 4:3 monitor formats.
90′ is un-recommended as some weapon anims are visually capping (not a bug).
STARTING THE GAME
IMPORTANT:
You must launch Call of Pripyat (Stalker-COP.exe) as an administrator.
This is obligatory for the mod to even start.
http://www.miserymod.com/?p=19
