[W2k]Shadow
Legende
ok, also nicht mit plug n Play, sondern eher plug n pray
DTS Connect is a blanket name for a two-part system used on the computer platform only, in order to convert PC audio into the DTS format, transported via a single S/PDIF cable.[11] The two components of the system are DTS Interactive and DTS Neo:PC. It is found on various CMedia soundcards and onboard audio with Realtek ALC883DTS/ALC889A/ALC888DD-GR/ALC892-DTS-CG and SoundMAX AD1988 chips, as well as several cards based on the X-Fi chipset, such as the SoundBlaster Titanium series and Auzentech's X-Fi Forte, X-Fi Prelude, X-Fi Home Theater HD and X-Fi Bravura cards.
DTS Interactive: This is a real-time DTS stream encoder. On the PC, it takes multichannel audio and converts it into a 1.5 Mbit/s DTS stream for output. Because it uses the original DTS codec to transmit audio, fidelity is limited to 5.1 channel at 48 kHz, 24bit. More than 5.1 channels, a higher sampling frequency or data rate are not supported, due to the lack of support for DTS variants such as DTS 96/24. It can also be found on some standalone devices (e.g., Surround Encoder). Nearly a dozen titles on the PlayStation 2 feature the "DTS Interactive" real-time stream encoder, such as Grand Theft Auto: Vice City and Terminator 3: Rise of the Machines.
DTS Neo:PC: This is a technology based on the DTS Neo:6 matrix surround technology, which transforms any stereo content (MP3, WMA, CD Audio, or games) into a simulated 7.1-channel surround sound experience. The 7.1-channel surround sound is output as a DTS stream for output via a S/PDIF cable port.
Was DTS connect ist wusste ich......
Aber dein Hinweis ob es wichtig ist weil du nur eine slot hast, beantwortet meine Frage.
Fax668 hat es ja schon sehr gut beantwortet.
Mein Senf dazu: wähle das mainboard nach dem was dir wichtig ist. Wenn es zufällig DTS-Connect hat, kann es ja nicht schaden.
Hm, der Hardware nach wohl am Internetzugang oder am (W)LAN.
Alao am Prozessor liwgt das nicht, da muss was anderes hängen.
Hdd, oder ssd? Bei hdd bitte mal defragmentieren.
Mit welchem Programm wurde der abgespielt? itunes?
Antivirus habe ich nur das Microsoft-Eigene.
Die Idee mit DTS-Connect (und Dolby Digital Live) ist folgende - du hast mehrkanaligen Ton auf deinem PC und einen S/PDIF Ausgang, der nur zwei Kanäle kann. Jetzt kannst du die Tonkanäle vom PC in ein DTS (oder DD) Signal verpacken und so über S/PDIF zu einem AV Receiver schicken, der DTS (oder Dolby Digital) kann.
Meines Erachtens ist das ziemlich witzlos für einen reinen HTPC. Du brauchst dann nämlich einen AV Receiver und wenn du den sowieso schon hast, dann kannst du das DTS oder DD Tonsignal gleich unverändert über HDMI mitschicken, anstatt es erst in mehrere Kanäle zu zerlegen, dann verlustbehaftet nach DTS zu wandeln und dann über S/PDIF zum AV Receiver zu schicken.
Nützlich wäre die Sache evtl. bei Spielen, bei denen der Ton oft wirklich über getrennte Kanäle kommt und nicht schon fertig als DTS oder DD Signal kodiert ist wie bei Filmen. Und das ist meines Wissens auch so ziemlich der einzige Verwendungszweck von DTS-Connect und DDL. Um einen AV Receiver oder sonst ein Gerät, das DTS dekodieren kann, kommst du dabei aber nicht herum.
Die HDMI-Verbindung unterstützt nur die Audioformate LPCM (Linear Pulse Code Modulation) und AC3 (Dolby Digital). Das Audioformat DTS (Digital Theater Systems) wird über HDMI nicht unterstützt.
OpenElec aufn Stick und selbst ausprobieren
(Davor die Windows HDD/SSD abklemmen sicherheitshalber)
