jor.
bis zu 3 120er/Kanal sind np.
3 Kaze Maru 140er haben allerdings nen Kanal gefraggt
Naja hab ja ne neue bekommen![]()
scythe schrieb:Wide range of fan controller:
The fan voltage can be independently controlled from 3.7 - 12 V, in addition, the fan can be switched off completely which allows the user to choose between high and ultra-cooling operation.
scythe schrieb:Fan control and temperature monitoring:
With the Kaze Master Ace, four fans can be controlled independently, and four temperatures (in either ° C or °F) can be monitored. An integrated acoustic alarm function (which can be deactivated by a jumper) warns the user from overheating and failure of a fan.
jop genau das ists und sollte eig auf jeden fall ausstellbar sein wegen wakü und so...
