Skyrim Realistic Overhaul by Starac - 4 files or 2 files (high-res or low-res) + 1 for Dawnguard
For high-res: Download part 1, part 2, part 3 and the 1.6 update. For low-res: Only grab the 1024k version and the 1.6 update. If you want the Dawnguard textures, then choose your resolution option and go ahead and grab those as well!
This mod is no longer available on the Nexus due to the author being banned. If you don't already have the files, I can only recommend asking a friend if they can supply them for you. The TPC will work without this mod, but it won't look as intended.
