AristoChat
Semiprofi
ja burstrate ... aber damit kannst du probleme auffinden falsche einstellungen im Kontroller .. die bemerkst du schneller mit Atto
data)burstrate as used by benchmarks is the data (user-data, the con-
tents of a sector) rate as measured from cache by continuously reading
the same sectors over and over again.
The result can vary widely depending on type of cacheing, cache settings
and other drive behaviour.
In der praxis ist STR wichtiger ...
The speed of the drive" (or "STR") is the maximum sequential user
data rate accomplished by reading the outer cylinders sequentially.
The 3rd generation 15k Cheetah can indeed do 71 MB/s sequentially. It
should be able to do much better from cache or give back slightly lower
values because of the somewhat random nature (continuously seek back
to the start of the read area) of reading the same sectors over and over.
