Wenn Steam noch installiert ist, dann lösche mal die Datei "Clientregistry.blob" im Steam Verzeichnis und starte Steam.
Was alle immer mit ihrem steam probleme haben![]()
Welcome to the Steamlinuxbeta@list.valvesoftware.com mailing list!
Welcome to the Steam for Linux limited beta!
Information about installing and getting started can be found here:
https://steamcommunity.com/login/home/?goto=app/221410/discussions/1/
Do not reply to this message; this mailing list is not moderated.
To post to this list, send your email to:
steamlinuxbeta@list.valvesoftware.com
General information about the mailing list is at:
https://list.valvesoftware.com/cgi-bin/mailman/listinfo/steamlinuxbeta
If you ever want to unsubscribe or change your options (eg, switch to
or from digest mode, change your password, etc.), visit your
subscription page at:
https://list.valvesoftware.com/cgi-bin/mailman/options/steamlinuxbeta/xxxxxxxxxxx
You can also make such adjustments via email by sending a message to:
Steamlinuxbeta-request@list.valvesoftware.com
with the word `help' in the subject or body (don't include the
quotes), and you will get back a message with instructions.
You must know your password to change your options (including changing
the password, itself) or to unsubscribe. It is:
xxxxxxxxxxx
Normally, Mailman will remind you of your list.valvesoftware.com
mailing list passwords once every month, although you can disable this
if you prefer. This reminder will also include instructions on how to
unsubscribe or change your account options. There is also a button on
your options page that will email your current password to you.
Ich habe auch keine Probleme ... Selbst der BigPicture Mode lässt sich mit der XBox taste am controler öffnen.
@Moo, Probier mal die kompletten Registryeinträge von Steam zu durchsuchen, ich weiß leider nicht mehr wo das war aber dort kann es sein, dass der Pfad zum Steamfolder verlorengegangen ist. Einfach wieder eintragen dann. Der Key heißt auch irgendwas mit Path, bin leider gerade auf der Arbeit kann sonst heute Abend noch einmal schauen.
Der Pfad wird automatisch beim Starten gesetzt, das stimmt alles soweit. Jetzt liegt es in einem zusätzlichen Unterordner und es geht wieder alles. Was für unnötige Probleme![]()
Ich will nur nochmal einwerfen, dass ich die beiden Batmanteile ( Arkham Asylum und City) als Gift hab und nicht unbedingt behalten möchte![]()
Was willst denn dafür haben?
Gibt es eigentlich einen Grund warum Steam ab und an meint, dass ich diverse Games neu runterladen muss, obwohl ich nichts an Steam, am Game oder an der Config des Rechners getan habe. Habt ihr das Problem auch ab und an mal. Gerade aktuell meint Steam ich müsste 8 Games neu runterladen.
Metro2033 gibts gerade kostenlos für ein facebook like bei THQ...(like klicken, dann auf redeem code und man erhält einen steam code)
www.facebook.com/MetroVideoGame?sk=app_395840630491782
