ich poste die hier mal ;-)
New A.I. behaviour, mutants will sometimes go home to sleep during day along with other new routines.
Distorted mutants can now be killed with regular weapons.
Distorted mutants more aggressive and deadly in combat and have expanded actions.
Better ambient lighting. Trees and large objects diffusely occlude skylight. (experimental)
Pause menu now actually pauses game.
Enemies use rocks more often to jump attack at player.
New female enemy type added.
Better distribution of enemies throughout the world.
Constructed bench now works and players can sit to regain energy or watch sunset.
Increased axe damage against enemies.
More variation to female cannibal models, added procedural
breasts size system.
Improved Rabbit/Lizard distribution and optimized CPU usage.
Improved sky and sun look.
Improved dead cave lighting and cave 2 lighting.
Better cave textures and rock look.
Dead cave prop fixes, fixed some incorrect rock placements.
Improved load times and added loading percentage amount.
Re-balanced hunger drain.
Better cave ground with flowing water and more detailed textures.
Enemies will now push small items out of the way instead of getting stuck on them.
Dead sharks now ragdoll.
Bugs:
Fixed rain sound never going away even after rain stops.
Fixed bug where some partially built structures couldn’t be completed after loading a saved game.
Fixed animals sometimes disappearing in regular and vegan mode.
Fixed issue where you could still shoot flare gun or use other weapons when pause menu was open.
Yacht random position won't change now or get lost when saved game is loaded
Fixed all effigies turning into arm effigy on load
Fixed E to add icon showing up if holding a rock or stick even if items not needed in building
Fixed cave drips continuing to play even when not in cave
Fixed fish swimming outside of pond near cliff section
Fixed fullness always starting at half when loading a saved game
Fixed moonlight sometimes missing completely
Fixed stick marker vanishing on loading saved game
Fixed missing collision roof of cabin
Fixed player flying in air after chopping dead bodies
Rain effigy effect should now work and will wear off after time
Cannibals spawning in villages no longer ‘pop’ when waking up
Fixed creepy female model attacks sometimes not hitting player
Fixed bug where bird landing on hand would sometimes stop axe from working
Fixed enemy head and leg pickups sometimes appearing as arm pickups
