DDR V1.11 f1474cf52f cym 23/05/09-11:02:36
LPDDR4X, 2112MHz
channel[0] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[1] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[2] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
channel[3] BW=16 Col=10 Bk=8 CS0 Row=16 CS1 Row=16 CS=2 Die BW=16 Size=2048MB
Manufacturer ID:0x1
CH0 RX Vref:27.9%, TX Vref:19.8%,20.8%
CH1 RX Vref:27.1%, TX Vref:21.8%,20.8%
CH2 RX Vref:27.9%, TX Vref:19.8%,19.8%
CH3 RX Vref:27.1%, TX Vref:20.8%,20.8%
change to F1: 528MHz
change to F2: 1068MHz
change to F3: 1560MHz
change to F0: 2112MHz
out
U-Boot SPL board init
U-Boot SPL 2017.09-armbian (May 21 2024 - 16:21:13)
unknown raw ID 0 0 0
unrecognized JEDEC id bytes: 00, 00, 00
Trying to boot from MMC2
spl: partition error
Trying fit image at 0x4000 sector
## Verified-boot: 0
## Checking atf-1 0x00040000 ... sha256(7efcd01a0f...) + OK
## Checking uboot 0x00200000 ... sha256(2f31ed4655...) + OK
## Checking fdt 0x0031ec90 ... sha256(c5d44f02b4...) + OK
## Checking atf-2 0x000f0000 ... sha256(da90adf3a4...) + OK
## Checking atf-3 0xff100000 ... sha256(1163474a5b...) + OK
Jumping to U-Boot(0x00200000) via ARM Trusted Firmware(0x00040000)
Total: 430.20/581.170 ms
INFO: Preloader serial: 2
NOTICE: BL31: v2.3():v2.3-589-g3389cfdda
errick.huang
NOTICE: BL31: Built : 10:14:29, May 9 2023
INFO: spec: 0x13
INFO: ext 32k is valid
INFO: ddr: stride-en 4CH
INFO: GICv3 without legacy support detected.
INFO: ARM GICv3 driver initialized in EL3
INFO: valid_cpu_msk=0xff bcore0_rst = 0x0, bcore1_rst = 0x0
INFO: system boots from cpu-hwid-0
INFO: idle_st=0x21fff, pd_st=0x11fff9, repair_st=0xfff70001
INFO: dfs DDR fsp_params[0].freq_mhz= 2112MHz
INFO: dfs DDR fsp_params[1].freq_mhz= 528MHz
INFO: dfs DDR fsp_params[2].freq_mhz= 1068MHz
INFO: dfs DDR fsp_params[3].freq_mhz= 1560MHz
INFO: BL31: Initialising Exception Handling Framework
INFO: BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR: Error initializing runtime service opteed_fast
INFO: BL31: Preparing for EL3 exit to normal world
INFO: Entry point address = 0x200000
INFO: SPSR = 0x3c9
U-Boot 2017.09-armbian (May 21 2024 - 16:21:13 +0000)
Model: NanoPi R6S
MPIDR: 0x81000000
PreSerial: 2, raw, 0xfeb50000
DRAM: 8 GiB
Sysmem: init
Relocation Offset: eda3f000
Relocation fdt: eb9f9960 - eb9fecd0
CR: M/C/I
Using default environment
optee check api revision fail: -1.0
optee api revision is too low
### ERROR ### Please RESET the board ###
