Treiber
GeForce 418.81 macht RTX-Notebooks kompatibel
0
NVIDIA hat einen neuen Treiber für seine GeForce- und hier vor allem für die GeForce-RTX-Karten vorgestellt. Die neueste Version unterstützt die mobilen Varianten der Turing-Generation. Käufer eines neuen Notebooks mit GeForce RTX 2060, GeForce RTX 2070 und GeForce RTX 2080 (auch in der Max-Q-Variante) bekommen damit die optimale Unterstützung.
Weiterhin will NVIDIA folgende Probleme behoben haben:
  • [Gamestream][OS HDR]: Stream is not set to launch in HDR despite having HDR display attached to the PC and client. [2467526]
  • [GeForce Experience]: Share FPS overlay appears in the Twitter UWP app from the Microsoft Store. [2465033]
  • [G-SYNC]: Flickering may occurs in games if G-SYNC is enabled. [2399845]
  • [G-SYNC]: With G-SYNC enabled, after hot-pugging a G-SYNC display and then a GSYNC Compatible display, the right half of the G SYNC Compatible display may go blank. [200484819]
Weiterhin bestehende Probleme sind:
  • [GeForce RTX 20 series]: Event ID 14 error appears in event viewer logs when Digital Vibrance setting is changed. [2488424]
  • [SLI][Shadow of the Tomb Raider][G-SYNC]: Flickering occurs in the game when launched with SLI, HDR, and G-SYNC enabled [200467122]
  • [G-SYNC]: With a G-SYNC and G-SYNC Compatible display connected in clone mode, flashing occurs on games played on the G-SYNC display with G-SYNC enabled. [200482157]
  • [HDR][Ni no Kuni 2]: Enabling HDR causes the application to crash when launched. [2483952]
  • [ARK Survival]: Multiple errors and then blue-screen crash may occur when playing the game. [2453173]
  • [Batman: Arkham Origins]: PhysX fog renders incorrectly [2451459]
  • [Firefox]: Cursor shows brief corruption when hovering on certain links in Firefox. [2107201]
  • Dynamic Super Resolution (DSR) is not available for monitors with 4k2k timings. [2496987]
  • Random desktop flicker occurs on some multi-display PCs [2453059]
Der Download des GeForce 418.81 ist wie immer direkt bei NVIDIA möglich.
