[Sammelthread] Asus Rampage III Extreme R.o.G. (Intel X58) [2]
Chrisch
Legende
Münsterland
[blockquote]
Spezifikationen Spezifikationen
CPU
  • Intel® Socket 1366 Core™ i7 Processor Extreme Edition/Core™ i7 Processor
  • Supports Intel® Dynamic Speed Technology
  • Supports 4.8GT/s & 6.4GT/s QuickPath Interconnection
Intel® chipset
  • Northbridge:
    - Intel® X58 Express chipset
  • Southbridge:
    - Intel® ICH10R
Memory
  • 6 x DIMM, Max. 24 GB, DDR3 2200(O.C.)/2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Non-ECC,Un-buffered Memory
    Triple channel memory architecture
    - Supports Intel® Extreme Memory Profile (XMP)
    - *Hyper DIMM support is subject to the physical characteristics of individual CPUs.
Expansion Slots
  • 4 x PCIe 2.0 x16 , support x16; x16/x16; x16/x8/x8 and x8/x8/x8/x8 configurations
  • 1 x PCIe x4
  • 1 x PCI 2.2
Multi-GPU Support
  • Support NVIDIA 3-Way SLI™ / ATI CrossFireX™ Technology
    - * We recommend that you use full tower chassis for building a 3-Way SLI system.
Storage
  • Intel ICH10R controller
    - 6 xSATA 3 Gb/s ports
    - Intel Matrix Storage Technology Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 xExternal SATA 3.0 Gb/s port (SATA On-the-Go)
    - 1 xSATA 3.0 Gb/s port
  • Marvell® PCIe SATA 6Gb/s controller
    - 2 xSATA 6.0 Gb/s ports
Audio
  • 8-Channel High Definition Audio CODEC
    - Blu-ray audio layer Content Protection
    - Supports Jack-Detection, Multi-streaming, Front Panel Jack-Retasking
    - Supports 1 Optical S/PDIF out port at back I/O
LAN
  • Gigabit Intel® LAN
Internal I/O Connectors
  • 1 x IEEE 1394a connector
  • 1 x S/PDIF Out connector
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connectors
  • 1 x 24-pin ATX Power connector
  • 2 x 8-pin ATX 12V Power connectors
  • 1 x En/Dis-able Clr CMOS header
  • 1 x LN2 Mode Header
  • 1 x START (Power On) button
  • 1 x RESET button
  • 2 x EZ Plug connectors (4-pin Molex Power connectors)
  • 1 x OC Station header
  • 1 x RC Bluetooth header
  • 1 x Go Button
  • 1 x BIOS Switch button
  • 1 x ROG light connector
  • 1 x CD Audio in
  • 1 x Audio front panel
  • 1 x System panel connector
  • 1 x FAN1 Connector for optional fan-thermal module
Back Panel I/O Ports
  • 1 x PS/2 Keyboard port (purple)
  • 1 x Clr CMOS switch
  • 1 x Optical S/PDIF out port
  • 1 x External SATA port
  • 1 x LAN (RJ45) port
  • 1 x ROG Connect On/Off switch
  • 1 x RC Bluetooth switch
  • 2 x USB 3.0/2.0 ports (Blue)
  • 7 x USB 2.0/1.1 ports (1 port also for ROG Connect)
  • 8-channel Audio I/O
Special Features
  • CPU Level Up
  • MemOK!
  • Onboard Switches: Power / Reset / Clr CMOS (at rear)
  • ASUS MyLogo3
  • ASUS Fan Xpert
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • Q-Fan Plus
  • ROG BIOS Wallpaper
  • ASUS Q-Connector
  • ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
  • ASUS Q-Slot
  • ASUS Q-DIMM
Accessories
  • 1 x ROG Connect cable
  • 1 x ProbeIt cable set
  • 1 x 3-Way SLI Bridge
  • 1 x SLI Cable
  • 1 x CrossFire Cable
  • 1 x 2 in 1 ASUS Q-Connector Kit
  • 3 x 2-in-1 SATA signal cables
  • 1 x 2-in-1 SATA 6G cables
  • 1 x 2-port USB2.0 + ESATA module
  • 1 x I/O Shield
  • 1 x Thermal Sensor Cable Pack
  • 1 x Cable Ties Pack
  • 1 x ROG theme label
  • 1 x 12-in-1 ROG Cable Label
  • 1 x Optional Fan-Thermal Module
  • 1 x Bluetooth Module Accessory Card
    - Bluetooth V2.0/V2.1+EDR
    - RC Bluetooth On/Off Switch
BilderBilder
Das Mainboard
Die Verpackung und das Zubehör
(Quelle: AwardFabrik.de)
Das BiosDas Bios
DownloadsDownloads
Bios Downloads
  • Bios 0402
    - First release Bios
  • Bios 0531
    - RAM-Performance verbessert
    - Besseres OC-Verhalten unter Kälte
  • Bios 0602
    - FIX SATA 6G device may experience S3 resume failure when using Intel i7 965 CPU
  • Bios 0704
    - Added additional memory options (tRFC settings) to improve overclocking
    - Enable support for "Subzero Booster" for improved LN2 overclocking capabilities
    - Enabled additional CPU support for CPU Level Up functionality
    - Improved 3D performance at stock settings
  • Bios 0802
    - Improve system stability
  • Bios 0901
    - Added "2D Performance Booster" in BIOS setup
  • Bios 1005
Sonstige Downloads
[/blockquote]
Ich habe Sie nicht drin, dafür die Schrauben auch nicht so feste angezogen ;)
Gleichmäßig und über kreutz angezogen :wink:
@kaspar
und was haste so für temps ?
ist beim EK so ein moosgummi dabei ? das kommt doch auf den Chipsatz bzw daneben oder ?
soll ich die beilagsscheiben auch weg lassen was sagst du
bios rennt nur wer beta bios 0860 drauf hatte und 0901 flasht hat das problem das bios 0901 NICHTS speichert
ich musste vom 0860 aufs 0802 flashen dann vom 0802 aufs 0901 dann lüppte es
lag am bios boot block vom 0860
Hab noch mein auslieferungs bios(702) drauf,bin eigentlich nzu frieden damit.Mich wurmte nur diese 2D Booster geschichte.
Schon mal getestet was anders ist??
ist einfach zu erklären
wenn der 2d booster im bios an ist rennen apps aufm desktop schneller winrar etc
3d games "leiden" aber drunter
will heissen 2d booster aktivieren wenn du viel aufm desktop inet machst
wenn du viel zockst 2d booste deakt.
Ist Mir schon klar das mann in 2D anwendungen ein Boost bekommt wie der name schon sagt^^
Nur wiso, was wird geändert??? Das ist es was ich wissen will;)
Hats mit den C-state zutuen oder Den Sync mode oder oder????
Jepp..ich hatte auch die U-scheiben benutze...dafür sidn die ja da... ;)
und fallen die nicht runter ? manche habe da bissl kleber zur hilfe genommen hab ich gelesen
übrigens ich werd mir doch das RIIIE holen und das RIIE verkaufen :fresse2:
Das kann dir glaube ich nur ASUS selber beantworten
@kaspar
Temps siehe screen, 4,4 GHz run
moosgummi,
kann mich nicht erinnern, ist schonein paar tage her, habe ich abe auch nicht drauf bzw drunter.
weglassen oder draufmachen, hhhmmmm,
andere haben se drauf und gute temps. Deine Entscheidung.
okay danke, ja ich werde die spacer mal draufmachen :)
Das mit dem 2D Modus klingt ja interessant, könnte evt. mal jemand 1-2 runs SuperPi (1M und 32M) einmal mit 2D on und off testen.
Der Vergleich würde mich mal interessieren :-)
Fals wer ein 980X hat, ambesten mit 4,GHz, 3,6GHz Uncore und 800MHz ram....dann hätt ich einen direkten vgl zu xpower und ud9...das OS außenvor gelassen :P
Habe meine Core i7 920 auf dem Rampage III auf 21*190 übertaktet.
Aber wenn ich rechts auf Computer klicke und dann Eigenschaften, zeigt er mir nur 3,81 Ghz, also Sprich 20*190 an???
Coretemp und Everest zeigen mir beide 4 Ghz an.
Woran kann das liegen?
Tawwa
Du musst den Multi im Bios auf 21 fixieren ;)
Bringt es etwas den Multi zu fixieren?
Weil bei 3d Mark Vantage habe ich die CPU Leistung von 4 Ghz, habe mit einigen anderen Core i 7 auf 4 Ghz verglichen, meiner hatte sogar die höchsten Werte von den 4 Ghz Core i 7s. Und Rechner läuft auch stabil.....
Würd nur ungern jetzt noch was ändern im Bios?
Tawwa
Speichert das 0901 denn die Einstellungen wenn man 0802 kommt?
Done...läuft. Danke für den Hinweis!
Tawwa
Naja, er würde dann unter Last halt immer auf 4GHz bleiben, was ja, wenn Du den Multi auf auto stehen hast, nicht so ist.
Hä, im Moment ist mein Core i 7 unter Last nicht auf 4 Ghz?
Tawwa
Auf auto und 190 läuft er nur im "Turbomodus" mit 4GHz wenn mich jetzt nicht wirklich alles täuscht, ich hab den Multi schon immer auf 21 fixiert. ;)
Sagt mal Leute schon jemand auf dem board Tripple SLI verbaut???
Oder erfahrung damit,hat man einbusen weil im Tripple SLI die Grka nur noch 8X pci angesprochen werden??
Rennt die kiste mit 3x 285 GTX pci technisch 16x-16x-8x oder 16x-8x-8x ?????
Siehe Handbuch 2-28: 3-way-SLI x16/x8/x8
Es stehen insgesamt nunmal nur maximal 32 Lanes für die Grafikkarten zur Verfügung, egal, wieviele du einbaust.
