Ok will do!!...my next step will be opening the card 😆😆 wish me luck 😑😁
Any guides on opening up a gigabyte waterforce? 😆😆😆
It’s pretty much the same for all cards. Remove backplate screws (and sometimes, two small screws on the bracket), then disconnect fan and RGB cables from the PCB before lifting the cooler. Remove more screws on the PCB to remove the backplate. The steps will vary depending on the card. I suggest you watch Gamers Nexus on YouTube in their disassembly of the 6900 XT card.
Nein, du siehst doch, dass TDV aktiviert und hochgestellt ist. @ApolloX hat den EVC2 nur, weil er die Lötstellen so hübsch findet. :asthanos:
LOL. He might still have used the EVC2 because it’s possible to use both at the same time. It’s hard to believe he only used 1.2v. :d
Ich sehe dort 1300 mV GFX und 1281 mV Soc.
Oh yes, my bad. :) @ShirKhan Do you ever leave this forum? Are you some kind of a retired German billionaire? :d
OK, so you’re really a German billionaire who has nothing else to do except to read hardware forums and harass people who don’t share your enthusiasm for the EVC2. :d
I won't stop you from believing that. Actually, I have the billions in my heart. :)
Now, if you would excuse me for a moment? My presence is expected at a small brunch on one of the upper decks. All the guests are already waiting and we will have to do another couple of miles to reach our anchorage spot at Monaco harbour for F1 race will start in a few hours.
Edit:
:d
This is not harassment. It's guidance. :d
But if you would excuse me now for a moment? I have to organize a small brunch on my little boat, all the guests are already waiting and we will still have to do some miles to reach our anchorage spot at Monaco harbour for F1 race will start in a few hours.
Adopt me please.
Arbeite mich langsam an die Grenze unter meiner Luftkühlung heran. Ist aber schon Brutal was man so alles bedenken muss bei den AMDs um wirkoich Leistung raus zu bekommen:
24189
Beste Grüße
Yeah, a little bit :d
But its aircooled, Not riskin too much there.
Du riskierst dank der Schutzmechanismen da ja auch nichts. Du kannst dir jetzt per MPT 100.000W reinschreiben und es passiert nichts anderes als dass die Hotspot dann zur Drosselung führt.
Aber es ist eh schon stark, dass du mit Luftkühlung im Peak die 500W überschritten hast, der Hotspot nicht noch heißer war und deine Lüfter nicht auf 100 gingen. Diese Werte in dieser Kombination hab ich noch nicht gesehen, man könnt da an Auslesefehler denken.
Ich sag mal so, viel mehr Durchtzug als in meinem System geht glaub ich kaum. Da werkeln 16 Lüfter am absoluten Limit. Lüfter auf der Grafikkarte waren auf 100% gestellt, aber bei Last gehen sie von ~3150upm auf die 2950upm runter.
Habe aber zu wenig Erfahrung mit den AMD Karten daher bin ich erst ml so zufrieden.
Beste Grüße
Ab einem gewissen Punkt kriegt der Luftkühler die Hitze nicht mehr vom Chip.
Hatte das mit der Asrock probiert und selbst mit dem Klimakiller war dann das Delta Chip - Hotspot nicht mehr in den Griff zu bekommen.
Oh ja. Der Kühler bekommt die Hitze nicht schnell genug aufgenommen damit die Lüfter die Hitze dann weg bringen. Da geht dann nur noch Wakü. Werde hoffentlich noch die 6950xt vor dem Urlaub bekomme und grob antesten und dann mal schauen welche bleibt.
Beste Grüße
@Devcom hast du an beiden Karten einen EVC?
Kannst ja beide an einen EVC2 hängen, hat ja ein paar eingänge mehr das ding.
True, I remember!
So, AsRock 6950XT OC Formula ist auf dem Weg. Wenn alles gut klappt sollte sie Morgen da sein. Bin gespannt und hoffe sehr das sie nicht fiept :d.
Beste Grüße
Beste Grüße
Ab 550-600W hat fast jede AMD karte Spulenfiepen
Es ist schwach, jedoch...
Die lösung wäre Hotglue
Es ist einfach keine Kingpin bzw GALAX HoF um genug phasen zu haben
Sie ist gut, recht gut, aber dennoch
Oha, da will ich ja gar nicht hin mit Luftkühlung. Ich sag mal zum Testen kurz mal 500Watt und auf dauer eher Undervolting.
Die AsRock hat ja zumindest das Beste PCB unter den Luftgekühlten was Phasen angeht, daher bin ich Optimistisch.
Beste Grüße
Beste Grüße
Sollte passen~
Will a 6950 XT and 6800 XT work in Crossfire?
No, because different Device ID
How did he do this?
How did he do this?
I have the feeling some people here just like to say no without doing the research but yeah i also don't know if crossfire will work properly when using two different models. Try it out if you can.
