[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
@4090 Besitzer mit NV Adapter, wie macht ihr das denn, einfach unbeschwert weiter zocken und davon ausgehen, dass nichts passiert oder habt ihr aufgehört, die Karte mit Last zu nutzen bzw das Nutzungsverhalten irgendwie eingeschränkt?
Karte läuft auf 60% PL bis ein ATX 3.0 Netzteil kommt, PC ist nur an, wenn ich im Haus bin/über Nacht wird er ausgemacht. Kabel sitzt richtig, viel mehr kann ich nicht machen^^
Habe zwar schon überlegt, meine 3090 wieder einzubauen, allerdings bringt mir als Content Creator der duale AV1 Encoder zuviele Vorteile... Videodateien haben statt 35 GB Größe á 30min jetzt 10-12 GB. Mal abgesehen von den Coding Zeiten, die sich mehr als halbiert haben. Da blutet das Herz ein bisschen, darüber nachzudenken, die Karte jetzt einzumotten^^
Bisher hieß es laut Testern würde es reichen das Power Limit zu beschränken . Vielleicht fehlt dahingehend eher die Motivation da noch zu optimieren .
UV bringt aber tatsächlich mehr als PT senken. Das wird hier von ein paar Leuten auch so bestätigt. Ich nutze auch UV weil ich mehr Takt habe und weniger Verbrauch als bei PT.
Was ist konkret für ein CPU-LIMIT ursächlich?
Takt und IPC. aka single-core-performance.
Post #29 und Post #31:
Es gibt Anwendungen, die produzieren mehr Cpu-Last als andere.
Wie kommt's?
N Auto transportiert 4-5 Leute, ein Schulbus 30-50.
Wer hat die höhere Last und wie kommts?
Wenn das die Frage nicht beantwortet, verstehe ich die Frage nicht.
Wie kommt's?
naja das hat ja am ende nix mit dem cpu limit zu tun.
entscheident ist, ob die fps deiner cpu für dich ausreichen oder nicht.
ein störendes cpu limit ist wenn deine gewünschten fps seitens der cpu nicht erreicht werden.
Ich habe meine karte vor ca 12 Tagen eingebaut und direkt nach 5 Minuten meine passende UV Variante gefunden und bin damit unterwegs. PC ist zu und bleibt auch erstmal zu bis ich ein Kabel habe das ich direkt am NT anschließen kann ohne Adapter. Und in der zwischenzeit zocke ich einfach nach Lust und Laune. Mal 1 Stunde und mal mehr, je nach Zeit und Lust. Das Kabel habe ich nicht geprüft und das obwohl es hier bei mir seid mindestens 3 Tagen verbrannt riecht. Aber das kommt von außerhalb, wahrscheinlich die Firma gegenüber. Die Karte läuft wie sie soll, sehe keinen Bedarf da was zu prüfen.
ABER: Meine Karte läuft mit nichtmal 300 Watt Auslatung durch das UV und somit lächle ich über den Verbrauch und über die Temperatur sowieso. Die Karte sieht die 50 Grad nicht mehr.
hast du überhaupt eine 4090 ? Laut Systeminfo nicht. Mein PC bleibt nachts an, geht aber ins Standby wie immer. Ich mache den PC nur aus wenn ich außer Haus gehe zum Arbeiten.
Ich mach nix. Jage da auch weiter die 600 Watt durch. BeQuiet Kabel liegt zuhause, ist aber derzeit nicht einbaubar, bis der Wasserblock kommt. Der Samsung Note 7 Vergleich trifft es wohl. Ja, ist ne schlechte Konstruktion, aber das Risiko ist gering.
Mein BQ Kabel ist leider zu kurz um es quer durchs Gehäuse zu führen und ohne Wasserblock gehts einfach nicht. 1-5 Wochen sollten da noch „Risiko“-technisch funktionieren, da das Kabel nicht genickt ist, Gehäuse läuft ohne Side-Panel.
Ist doch normal, dass hauptsächlich über die Adapterproblematik gepostet wird. Davon abgesehen sind die Karten doch größtenteils perfekt und ziemlich identisch, abgesehen von Kleinigkeiten. Jeder weiß, dass die rennen wie die Sau. Die Leute die nix posten sind vermutlich beschäftigt mit Zocken.
Das ständige Gerede um Spulenfiepen (was mich persönlich nicht sonderlich juckt, alter Mann mit Tinitus) und die Screenshots von Versandbestätigungen finde ich persönlich nerviger.
Warum hast Du ständig das Bedürfnis, eine Diskussion mit sachlichen Informationen auf eine persönliche Ebene herabzuwürdigen?
Ne, ich sage so Sachen nur aus bloßer Belustigung.
Ernsthaft mal, was soll so eine Frage?
Offensichtlich habe ich eine 4090, weil ich es schon mehrfach erwähnt habe. Sogar hier im Forum Informationen teilen konnte, wieviele FE Karten NBB verfügbar hatte (Zettel auf meiner Lieferung)...
80% PT +180 OC rennt bei mir schneller als Curve UV. Takt ist 90% der Zeit bei über 2900Mhz, max. 2970Mhz.
355W max Verbrauch.
Was stimmt mit dir nicht? Ich habe deine Systeminfo gesehen und da steht keine 4090 drin. Ergo eine stinknormale Frage. Die von jedem kommen kann. Ich habe nichts davon gelesen das du eine FE bekommen hast. Ich glaube du musst mal lernen Beiträge zu lesen und zu verstehen bevor du hier um danke klicks zu sammeln direkt mit der persönlichen Ebene kommst. An meiner Frage ist nichts persönlich.
355W max Verbrauch.
ja ist halt bei jedem anders, gibt genug andere Beispiele. Jedem wie es gefällt :)
Würde auch gerne mehr Ergebnisse lesen…
Und wer hat eine Perle, ohne die „zehnte“ 4090 durchprobiert zu haben?
Perle weiß ich nicht…
Habe eine Strix OC mit leichtem Rasseln/Ultra wenig Fiepen bei 60-120Hz (4K OLED Gsync).
Lüfter sind top; kommt aber auf Grund der Größe unter Wasser.
Bin derzeit Nummer 1 in DACH Region bei Port Royal (28646 Punkte). 3105@1.1V und 24640Mhz Mem.
Interessant finde ich das manch einer mit viel weniger MHz vor mir ist und manch einer mit viel mehr MHz hinter mir. Da scheint es noch eine „versteckte“ Effizienz zu geben (effective core clock? - clock stretching?).
Ich habe allerdings eine stink-normale Win 11 upgrade installation mit Auqasuite etc. habe im Taskmanager alles an LG Update, Aquasuite, etc beendet vor den Benchmarks, aber die GeForce Telemetry und Win Telemetry läuft halt noch… keine Ahnung ob es eben das ist, oder effective Clock als Faktor zum tragen kommt.
Bin sehr zufrieden - 1 Karte geordert und fertig. Unter Wasser versuche ich dann die 3105/24640 Game stable zu bekommen. Derzeit läuft sie mit 3060/24000 auf Luft im offenen Gehäuse mit 55-68c core temp und bis zu 580 Watt Max. CP2077 dann „nur“ 420-500 Watt…alles ohne Probleme an einem BeQuiet Straight Power 11 850W Platinum mit 5800X3D, LEDs, 2NVME, 4RAM, 9FAN, 1Pumpe.
  • Danke
Reaktionen: THK
70% PT Target und das Seitenteil offen damit der Adpater nicht zu stark knickt. Sollte fürn Anfang reichen.
krass dass man 500 seiten über diese graka quatschen kann.. zu meiner fällt mir überhaupt nix ein. läuft wie erwartet.. vllt. sogar etwas besser.
tobi
So das sind meine Werte mehr geht nicht, habe ich mehrmals getestet bin ich sehr zufrieden mit.
Lg
tobi
Ohne #adaptergate und erfolgreiche Bestell-/Versandbestätigungen wären wir hier allerdings auch sicherlich nur bei der Hälfte. :d
Ich habe heute morgen mal meinen Adapter kontrolliert, sieht bis jetzt noch gut aus.
Ich lass sie einfach mit PT 80% laufen, da läuft sie wie mit 2730mhz Standard und zock eh nur Assetto Corsa Competitione mit tripple und da limitiert sowieso der 12700k, wenn ich sie auf 70% stelle dann fängt sie wg Powerlimit an bissl hin und her zu takten. Ich hoffe und 🙏 das sie nicht 🔥 aber nutzen tu ich sie ganz normal. Auch 4 Stunden am Stück bei längeren Races und der Lüfter im Boden bläst schön auf den Superadapter...bis irgendwann das bestellte be quiet Kabel kommt.
Fast alles, was hier gepostet wird, ist eh nicht stable.
Spätestens beim MP in MW2 oder Division 2 werden die ganzen OC-Wunderkarten rasiert.
Ich hatte bisher zwei schnelle Crashes bei MW2 und ohne OC keine Probleme.
Internet ist aber voll, wie MW2 verbugged und scheiße ist - gerade die Lobby Crashes :lol:
Die Leute kommen nicht mal darauf, dass ihr scheiß OC nicht stable ist.
Nee, Port Royal lief ja durch und andere Spiele liefen auch, muss MW2 sein.
0,900v default +300 MHz … ist never game stable oder wenn ich +250 MHz für 3 GHz benötige.
Und ja, Port Royal lief trotzdem 40 Loops 4K und 40 Loops StressTest durch, 20+ Std RDR2 gezockt und MW2 macht den hier :wink:
Auf die ganzen OC Ergebnisse hier kann man nix geben.
Paar User haben es wenigstens geschnallt.
@Naennon hatte mir mal 2016 übrigens das Gleiche gesagt in Bezug auf PUBG und OC.
Da war ich es aber noch, der sein OC für stable hielt und das Game verantwortlich machte.
Aber danach hat es Klick gemacht.
3dMark und game stable :wall:
Anschließend wird aber nicht weiter von der Karte berichtet, weil man nicht eingestehen möchte, dass es nicht stable war.
UV ist und bleibt ein großes Problem, was Stabilität angeht. Ein einfacher Benchmark reicht nicht aus, um das als Stable zu bezeichnen. Deshalb ist am PL drehen immer die einfachere Variante - kaum Leistungsverlust, aber echte Stabilität.
118fps. karte leise, kein fiepen
ein traum
solange die karte nicht belastet wird ist absolute ruhe :d
Soweit ich gelesen habe soll der Kühler der KFA nicht so dolle sein und die Lüfter wohl recht laut aber ich werde mir selber davon erst ein Bild machen.
Es ging nur um das Feedback da die Frage aufkam ob Neuware oder ausgenudelte Retoure.
Also bislang steht soweit ich sehen kann nur mein Wort gegen das von Usern, die sagen die Karte läuft super leise. Auf jeden Fall erstmal selbst ein Bild machen.
Ähnliche Themen
