[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Die Frostbite ist doch bisher noch nie verfügbar gewesen. Bitte korregiert mich wenn ich falsch liege.
Doch heute morgen gegen 08:30 Uhr. Habe eine iChill Black bekommen.
Hatte noch nie ein Produkt von Inno3d, war für mich immer ein "Hersteller" wie Zotac, Palit, Gainward etc.. Da ich aber nun mit der Suprim X einen Reinfall erlebt habe, bin ich doch recht freudig auf die Karte gestimmt und vor allem wird es KEIN Rückläufer sein! Meine Suprim war zwar auch versiegelt aber die Folie der Backplate war bereits abgezogen gewesen, es waren Fusseln darunter und 2 Fingerabdrücke auf dem Kühlkörper (auf einer Finne) + die Lüfter waren nicht in Ordnung!
Einen 5950X. :d Ich brauche die 16 Kerne aber nicht und bin mit dem 5800X3D deutlich besser dran.
Bei mir war die Wahl, jetzt wechseln oder in ein paar Jahren.
Heute bekomme ich noch ca 400-450€ für den 5950X, was über dem Kaufpreis des 5800X3D ist.
In ein paar Jahren wird das nicht mehr 400€ sind, sondern möglicherweise weniger.
"Verlust" habe ich so oder so gemacht, da ich damals für den 5950X ca 700€ gezahlt hatte.
Ich hatte einfach die falsche CPU für mich gekauft. Damals gab es leider den 5800X3D noch nicht, also wusste noch keiner wieviel besser der fürs Gaming gewesen wäre. Tja...
Ich habe auch kein Interesse einen 7800X3D zu kaufen, wenn der mal kommt.
Mein Board/RAM ist noch keine 2 Jahre alt und das nächste CPU Upgrade ist erst in 3-4 Jahren geplant.
So ging es mir mit dem 5900x.
Wollte gestern den 5800x 3D bestellen aber habe ihn storniert.
Wie gesagt die Aussagen sind zu unterschiedlich.
Es wäre nett wenn Du Deine 4090 zuerst mit dem 5950x testest und dann erst den 5800x 3d einbaust. So kannst Du rausfinden ob es sich gelohnt hat und davon berichten... :-)
Die Reviews sagen doch eigentlich alles. Für Games lohnt sich das durchaus, vor allem wenn man nicht auf ein neues System gehen möchte. Wenn man natürlich nebenher andere Sachen macht wo die Mehrkerne Sinn ergeben, dann natürlich nicht. Da mein Rechner zu 95% ein Gaming Rechner ist, tausche ich die Tage. Und nach dem Star Citizen Video muss ich diese CPU einfach haben. Das Game spiele ich aktuell intensiv und dafür gibt es nicht genug Leistung.
Ich glaub erst drann, wenn ich die in meinen Händen halte...
Ich hoffe, dass ihr alle eine bekommt. Aber sieht nach Überbestellung aus.
Das wird sich sowieso lohnen, da mein 5950X mit 4,2Ghz@1,1V läuft. Boost ist ausgeschaltet.
Ich habe mit dem ein Problem, das der in Stock auf dem Desktop auf 5Ghz@1,5V boostet, wenn ich nur Firefox auf habe.
Kann natürlich an einem Hintergrund-Programm liegen, aber ich habe schon alles nicht notwendige ausgeschaltet.
PBO, Offset, Energiemanagment brachte keine Besserung oder Crashes.
Mit den Takt/Spannung den ich oben angegeben habe, konnte ich den Verbrauch und die Temperatur halbieren!!! Auch zu mind 25% im Gaming.
Laut Cinebench ist die Leistung nur 10% niedriger in ST.
Den Fehler brauchen wir nicht zu diskutieren, es ist irgendeine komische Kombination mit meinem Board, meinem guten Kühler und meinem System. Wie gesagt alles duchgecheckt und Problem bleibt da.. :d
Ich habe auch schon viele Stunden darin investiert und habe einfach keinen Bock mehr :d
Der 5800X3D boostet von Haus aus nicht so hoch, speziell die Spannung, also könnte ich den so Stock einfach laufen lassen.
Was mir also beim 5950X (bzw bei meinem Board) gefehlt hat, war ein Takt oder Spannungs CAP für den Boost. Ähnlich wie ein Temperaturcap, was es bereits gibt.
Diese Aussagen beziehen sich aber alle darauf wenn man von einem Zen 2 kommt. Alle 5900x oder 59050x Besitzer sagen, dass es kein Upgrade sondern nur ein Sidegrade wäre. Zudem auch einige Games mit dem 5900x schneller sind als mit dem 5800x. Wohl dann wenn es auf Cores & Takt statt Cache ankommt.
Vielleicht hole ich mir über Weihachetn doch mal nen 5800x 3d und teste den in ein paar Games.
Zur Not geht dann einer von den beiden CPUS nach EKA:
Hast Du mal Fastboot ausgeschalten und CSM deaktiviert?
Ja Fastboot ist aus und CSM aus.
Schalte ich CSM ein habe ich das Asus Logo.
Habe das Problem auch nur mit der FE sobald eine andere Karte im System ist alles ganz normal ohne am Bios was anzupassen.
Trotzdem hatte ich alles mögliche schon versucht.
Nvidia meinte allen Ernstes bei einem ~2K EUR Produkt brauchen sie denn das Bioslogo unbedingt 😂
Ja,
So Bestellung der 4090 bei Caseking ist abgeschlossen, dann hoffe ich mal, die Karte kommt am Montag :).
Hier übrigens noch ein Review der iChill Black, welche vielversprechend aussieht :) (gibt auch ein paar schöne Bilder)!
57 Grad unter Last bei nur 700 Umdrehungen klingt sehr gut. Leider werden in dem Tests keine weiteren Temperaturen angegeben.
Hoffentlich gibt es bald noch detailliertere Reviews.
Wenn es geht Temperaturen des VRAM und der SpaWas bzw. Elkos.
Wenn du mal richtig zockst hast du auch über
50•C GPU bei einem mora . Richtig Vorteile beim GPU Clock hast eigentlich erst bei unter 40•C . Du kommst locker bei einem dicken System auf 35 •C Wassertemperatur.
Habe selber alles hier und 6 Jahre benutzt . Mir braucht man nichts mehr erzählen .
Bei einer 1080TI hatte man noch 6 Kelvin Delta und bei Turing und ampere war es schon deutlich mehr und hier hast du 20 Kelvin über Wassertemperatur.
Geil ist was anderes ;-)
Mal schauen, wie weit ich unter 30 Grad @ load komme :fire:
Ok, hast Du den mal den 5950x auf Eco im Bios gestellt??? Ich glaube das Problem könnte eins sein dessen Lösung du evtl. nicht kennst. Bin seit Tagen dabei PBO und CO zu optimieren. Da habe ich viel erfahren was ich bisher nicht wußte obwohl ich schon fit in dem Thema bin.
Da wirst DU keine Lösung bekommen. Da ist dann irgendeine Inkompatibilität zwischen MB Bios und Graka Bios.
Evtl. gibts noch einstellungen die du noch nicht probiert hast.
Fullsreenbootlogo usw aktivieren.
Finde aber auch, dass es kein Problem ist was Nvidia lösen muss. Eher Dein MB Hersteller. Was er aber auch nicht tun wird.
Da hilft Dir nur eine andere 4090 ztu testen um zu wissen woran es liegt.
4090 Frostbite bei Caseking...
12 Karten auf Lager...
ca. 500 Bestellungen...
Das ist wirklich verrückt, zumal die Frostbite relativ lang als "verfügbar" gelistet war.
Hoffentlich kommen die nochmal irgendwo anders in die Shops!
Was nützt einem mehr Leistung, wenn die Engine trotzdem ständiges stuttering verursacht:
12 Karten ist aber auch ein Tropfen auf den heißen Stein /:
Der hat schon mehr als genug 4090 getest. Keine war für ihn zufrieden stellend sollte es jetzt mal lassen
Schade dass man Star Citizen unmöglich Benchmarken kann da man sich 10 mal neu einloggen kann und 10 mal andere performance haben wird weil die Serverperformance auch Clientperformance vorgibt
Und die geht mit der Zeit runter und ist momentan sowieso eher schlecht als recht
Source: Zu viel Geld schon für das Spiel ausgegeben und tausende Stunden Spielzeit
Die 13er Serie sollte in etwa gleich auf sein mit dem 5800X3D in SC aber mit meinem 13700k/4090 läuft das Game dermaßen schlecht Momentan.. zumindest in den 'Städten'.
Wahnsinn was man alles für Probleme haben kann, wenn man nur gründlich genug danach sucht. Da hilft wohl nur Retoure die 20. :ROFLMAO:
Eco-Mode ist wieder was anderes. Eco-Mode ist ein Power-Limiter.
Und dieser ist tödlich für einen 5950X. Eco ist bei meinem Board 86W.
Der 5Ghz@1,5V Boost braucht aber nur ~80W. Heißt der boostet auch so hoch trotz Eco-Mode, aber wenn man viele Kerne nutzen will, braucht der 5950X Strom.
Bei mir kann der normal 142W ziehen und wird auch bei Vollast nur 65°C warm.
NUR der Single-Core Boost ist das Problem, mit biszu 95°C in Prime 95.
Quasi dasselbe "Problem" das Ryzen 7000 auch hat, nur ist es da noch schlimmer. Da das Spannungslimit (1,5V beim 5950X) bei Zen4 nicht erreicht wird, sondern das Templimit.
Ich will halt aus Prinzip keine ZU heißen Komponenten haben. >80°C wäre mir zu hoch. Deswegen tat mir die 3090 auch immer weh, weil dessen VRAM über 95°C war... :d
Für die Enthusiasten:
So ging es mir auch mit der 3090.
Und bei der CPU kann ich Dich auch verstehen. Habe die gleichen Vorlieben wie Du.
Also im Singlecore Boost geht mein 5900x auch auf über 80°. Trotz optimierten CO. Bei Fullcorelast habe ich das PBO so eingestellt, dass ich auf ca. 80° komme.
Also so lang Du im Singlecore die 90° nicht erreichst würde ich sagen, dass alles normal ist.
Eventuell nochmal Wärmeleitpaste fachgerecht auftragen und Kühler kontrolieren.
Welchen Kühler hast Du? Hast DU auch einen guten Airflow?
Edit 80°
@UdoG
UEFI / GOP funktioniert nicht wie er soll.
Zeigt kein UEFI Boot logo mehr bzw. wenn dann nur das Windows Logo ...
Hab dem Support von Nvidia ein Video geschickt wo ich offensichtlich zeige das es an der Karte liegt ;-) was ein Aufwand ;-)
Bei meinem Z690 Dark hatte ich auch kein Boot Logo und kam auch nicht ins BIOS - erst nachdem Windows vollumfänglich geladen wurde, war das Bild da.
EVGA hat dafür ein Beta Bios rausgebracht und nun passt es wieder.
Ich frage mich wann Seasonic die gratis Kabel verschickt, laut ihrer Mail hieß es Ende Oktober, mittlerweile haben wir November und noch keine Versandmail...
Mir wurde letzte Woche gesagt (per mail) das erst im November verschickt wird... Bis dahin benutze ich mein pinkes Kabel von Amazon. Der Nvidia Adapter hat es am Ende aber auch getan
Nee das ist die erste und einzige ... die werde ich auch behalten bzw. Abwickeln ;-)
Na ja das Problem siehst du jeden Tag wenn du den Rechner einschaltest bei ner 2K Grafikkarte ... Nööö muss nicht sein.
Vielleicht liegt es an ASUS ... muss später mal ein Anderes MB testen ... aber glaub ich leider nicht, wie gesagt jede andere GraKa funktioniert ... auch andere 4090 ;-)
Da bin ich voll und ganz bei dir. Man muss sich auch nicht alles gefallen lassen, gerade bei einem so teuren Luxus Artikel sollte die Qualität und Funktion stimmen.
Ich persönlich habe mich jahrelang zurückgehalten und auch mal eingesteckt, was sowas angeht, aber irgendwann ist das Maß auch mal voll. Sonst gibt es bald nur noch Schrott zu noch höheren Preisen.
Ähnliche Themen
