[Sammelthread] NVIDIA GeForce RTX 4090 + FAQ
Here we go again
Quelle:
TEST:
Karten:
News:
Wakü News:
Shops:
PowerLimits:
KarteMinMax
4090 Founders Edition450W600W
4090 Gainward Golden Sample450W450W
4090 MSI Suprim X450W450W Silent Mode / 520W Power Modus
4090 STRIX OC500W600W / Dual Bios
4090 Aorus Master450W600W
4090 Zotac AMP Extreme450W495W
4090 MSI Suprim Liquid X480W530W / Selten auch 600W
4090 Gigabyte Gaming OC450W600W
4090 Palit Gamerock OC450W500W
CARDGPU Voltage PhasesGPU Voltage ControllerGPU MOSMOS Current (A)Total GPU CurrentMemory Voltage PhasesMemory Voltage ControllerMemory MOSMOS Current (A)Total Memory CurrentTotal PhasesSource
MSI Suprim X (& Liquid)
26​
Monolithic MP2891Monolithic MP86957
70​
1820​
4​
70​
280​
30​
Techpowerup
ASUS STRIX OC
24​
Monolithic MP2891OnSemi FDMF3170
70​
1680​
4​
70​
280​
28​
Techpowerup
Nvidia Founders
20​
70​
1400​
3​
70​
210​
23​
Techpowerup
Colorful Vulcan (& Neptune)
24​
uPI uP9512UAlpha & Omega AOZ5311NQI-03 BLN3
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI-03 BLN3
55​
220​
28​
Techpowerup
Zotac AIRO
24​
55​
1320​
4​
uPI uP9512RAlpha & Omega AOZ5311NQI BLN0
50​
200​
28​
Techpowerup
ASUS TUF OC
18​
Monolithic MP2888AInfineon TDA21570
70​
1260​
4​
uPI uP9512QVishay SIC638A
50​
200​
22​
Hardware Unboxed
Gigabyte Gaming OC
20​
uPI uP9512UVishay SIC653A
50​
1000​
4​
uPI uP9512RVishay SIC653A
50​
200​
24​
Techpowerup
MSI Gaming Trio X
18​
Monolithic MP2891OnSemi NCP303151
50​
900​
4​
50​
200​
22​
CoolPC
Palit GameRock OC
16​
uPI uP9512UOnSemi NCP302150
50​
800​
3​
uPI uP9512ROnSemi NCP302150
50​
150​
19​
Techpowerup
Zotac Trinity OC
14​
55​
770​
4​
50​
200​
18​
CoolPC
Inno3D X3 OC
14​
uPI uP9512UAlpha & Omega AOZ5311NQI BLN0
55​
770​
3​
55​
165​
17​
KitGuru
Gigabyte Windforce
14​
?Vishay SIC653A
50​
700​
4​
?Vishay SIC653A
50​
200​
18​
profesionalreview
Tool
How To?
Anleitung
7. Enter drücken
10. PC neu starten
Seasonic
gibt Ihren Kunden das Kabel Umsonst, für spezielle Seasonic-NT, welche in den letzten 12 Monaten gekauft wurde.
Corsair
FAQ:
Verliere ich Leistung, wenn ich die RTX 4090 mit PCIe 3 laufen lasse? > Ja, ca 2,1% :) Also nicht viel
Quelle: https://www.computerbase.de/2022-10...hnitt_die_geforce_rtx_4090_mit_pcie_30_update
Hat die TUF OC ein 600W ?
Bei der Frostbite ist der Preis wohl einfach Nebensache. :)
Ich weiß ehrlich gesagt nicht, warum die Karte so gebasht wird. Fertige WaKü-Karte mit Garantie, gut verarbeitet, kühl -> reinstecken, läuft. Aktuell gibts keine Karte wirklich viel günstiger, dann kämen noch Kosten und Wartezeit für den Kühler obendrauf. Nur 450W PL ? Ganz ehrlich, meiner Meinung nach ist das völlig egal außer man ist harter OCer und möchte noch die 2-8% mehr Benchmark-Balken haben für 150W mehr Strom.
Nur könnte Inno3D das auch deutlicher vermerken, dass die Karte nur 450W PL hat. Bis darauf passt es eigentlich. der8auer war ja bis auf das Marketing auch zufrieden.
Teuer sind sie momentan alle, und ich glaube auch jeder Käufer und auch Nicht-Käufer weiß, dass es momentan eigentlich völlig "dämlich" ist zu kaufen und nicht ein paar Wochen zu warten. Ist halt unser Hobby ;)
Also Master Strixx TUF und FE 600W
Lecker !
Hast du The Division 2 ? da würden mich mal die Temps nach einer Stunde mit OC interessieren da kommt man wenn man die 3GHZ angeht deutlich über 500W.
power lmit obwohl er nur 415w zieht, was da los :d
Das ist normal, da "Heißleiter". Aber fast 80W weniger als @xl_digit wundert mich etwas
Wieviel OC/Takt war es mit Luft?
ram konnte ich 1485 machen, nun nur noch 1300. gpu ist gleich +250
Am Ende spielts eigentlich auch keine Rolle mehr, ob die Karte 2100 oder 2300 kostet, wer eine 4090 kauft, hat eh die Kontrolle über sein Leben verloren...
muss sagen, hab meins so gut im Griff wie nie. Andere kaufen Fußballvereine, wie stehst du zu denen in Bezug auf Kontrolle
Zumindest eins hat die Frostbite nicht, Rasseln oder Fiepen, zumindest hör ich nichts.
Boost liegt bei 2835/ 43°GPU/ 26° Wasser und 415 Watt Leistungsaufnahme.
Sollten klar um die 550W Peaks sein bei 3GHZ rum.
Wieviel V hast du ?
Weil hast nicht gemaxt in GPUZ die V Anzeige.
The Division 2 ist echt ein Brett was Powertarget angeht .
Hab mit 2940 MHz 1,1V Peak 565W gehabt mit der Master.
Wird Sie doch nicht. Ich sagte nur das der Preis wohl keine Rolle spielt. Das war ja hier meist das Hauptthema.
Günstiger ist natürlich selbst bauen, aber dafür keine Wartezeit. Und in der Vergangenheit wurde inno3d und die Frostbite auch nicht grad gut dargestellt von den Communitys.
Aber es wird vermutlich die einzige 4090 direkt mit Block bleiben. Ich habe noch keine Ankündigung der z.b. Waterforce WB gesehen.
Ist doch ein guter Wert .
Meine TUF hat 2700 @ 1,05 .
Man kann beim Afterburner in der CURVE schauen was hinterlegt ist .
Mal ein paar OC Versuche mit der TUF OC gemacht, 3GHz Marke geknackt, braucht mein Chip eine leichte Erhöhung auf 1,65V - Time Spy Extreme und Superposition läuft dann wie angetackert auf 3000MHz durch, für unter Luft wirklich beeindruckend - die FE zuvor hat die 3 GHz nicht gepackt. Zieht dann aber auch durchgehend um die 470 - 480 Watt, mit Peaks auf 552 Watt während des Time Spy Runs. Speicher habe ich +1250, nuckelt auch an den Watt und weiter höher gehen bringt nichts mehr groß Auch das alles im Übirgen kein Problem mit meinem 750 Watt Netzteil und 12700K@5GHz/ 32GB DDR4 4000. Unter Wasser bestimmt lecker, muss wohl doch ne Wakü drauf, für die Tests liefen die Fans volle Pulle, sieht auch Gamestabel aus.
Grafik Punkte: 20 739 Time Spy Extreme
Finde es witzig das hier einige out of the box über 2800 MHZ @ 1,05V haben und du etwa 2715 oder 2730.
***** mit seiner ersten TUF 2700 MHZ wie ich mit meiner TUF OC und mit seiner zweiten 2730 MHZ .
Aber muss sagen ist mir auch vollkommen latte. 3 GHZ habe ich auch in Benchmarks geknackt .
Im Alltag reicht mir Stock vollkommen.
Wieviel V hast du ?
siehst in hwinfo 1.1v
hmm
Ähnliche Themen
