Nov 14 13:17:18 truenas kernel: ------------[ cut here ]------------
Nov 14 13:17:18 truenas kernel: NETDEV WATCHDOG: enp5s0 (igb): transmit queue 0 timed out 9472 ms
Nov 14 13:17:18 truenas kernel: WARNING: CPU: 6 PID: 2915 at net/sched/sch_generic.c:525 dev_watchdog+0x235/0x240
Nov 14 13:17:18 truenas kernel: Modules linked in: sr_mod(E) cdrom(E) joydev(E) uas(E) cdc_ether(E) usbnet(E) usb_storage(E) mii(E) xt_nat(E) xt_tcpudp(E) veth(E) xt_conntrack(E) nft_chain_nat(E) xt_MASQUERADE(E) nf_nat(E) nf_conntrack_netlink(E) nf_conntrack(E) nf_defrag_ipv6(E) nf_defrag_ipv4(E) xfrm_user(E) xfrm_algo(E) xt_addrtype(E) nft_compat(E) nf_tables(E) libcrc32c(E) crc32c_generic(E) nfnetlink(E) br_netfilter(E) bridge(E) stp(E) llc(E) nvme_fabrics(E) nvme_core(E) overlay(E) sunrpc(E) binfmt_misc(E) ntb_netdev(E) ntb_transport(E) ntb_split(E) ntb(E) ioatdma(E) ipmi_ssif(E) intel_rapl_msr(E) intel_rapl_common(E) amd64_edac(E) edac_mce_amd(E) kvm_amd(E) kvm(E) irqbypass(E) ghash_clmulni_intel(E) sha512_ssse3(E) sha256_ssse3(E) sha1_ssse3(E) aesni_intel(E) crypto_simd(E) cryptd(E) snd_hda_intel(E) snd_intel_dspcfg(E) rapl(E) snd_hda_codec(E) snd_hda_core(E) snd_hwdep(E) snd_pcm(E) ast(E) evdev(E) drm_shmem_helper(E) sp5100_tco(E) snd_timer(E) snd(E) acpi_cpufreq(E) pcspkr(E) soundcore(E) watchdog(E) k10temp(E) drm_kms_helper(E)
Nov 14 13:17:18 truenas kernel: ccp(E) acpi_ipmi(E) ipmi_si(E) ipmi_devintf(E) ipmi_msghandler(E) sg(E) button(E) loop(E) drm(E) efi_pstore(E) configfs(E) ip_tables(E) x_tables(E) autofs4(E) zfs(POE) spl(OE) efivarfs(E) mlx4_ib(E) ib_uverbs(E) ib_core(E) mlx4_en(E) hid_generic(E) usbhid(E) hid(E) sd_mod(E) t10_pi(E) crc64_rocksoft(E) crc64(E) crc_t10dif(E) crct10dif_generic(E) ahci(E) ahciem(E) libahci(E) xhci_pci(E) crct10dif_pclmul(E) crct10dif_common(E) xhci_hcd(E) libata(E) igb(E) crc32_pclmul(E) crc32c_intel(E) usbcore(E) scsi_mod(E) i2c_algo_bit(E) scsi_common(E) usb_common(E) i2c_piix4(E) mlx4_core(E) dca(E)
Nov 14 13:17:18 truenas kernel: CPU: 6 PID: 2915 Comm: IoThread Tainted: P OE 6.6.44-production+truenas #1
Nov 14 13:17:18 truenas kernel: Hardware name: GIGABYTE G431-MM0-OT/MJ11-EC1-OT, BIOS F09 09/14/2021
Nov 14 13:17:18 truenas kernel: RIP: 0010
Nov 14 13:17:18 truenas kernel: Code: ff ff ff 48 89 df c6 05 b6 26 40 01 01 e8 f3 2c fa ff 45 89 f8 44 89 f1 48 89 de 48 89 c2 48 c7 c7 60 f9 d1 87 e8 cb 16 6b ff <0f> 0b e9 2a ff ff ff 0f 1f 40 00 90 90 90 90 90 90 90 90 90 90 90
Nov 14 13:17:18 truenas kernel: RSP: 0000:ffffbbd98772fdb8 EFLAGS: 00010286
Nov 14 13:17:18 truenas kernel: RAX: 0000000000000000 RBX: ffff9bc72a1a4000 RCX: 0000000000000027
Nov 14 13:17:18 truenas kernel: RDX: ffff9bcdfd3a13c8 RSI: 0000000000000001 RDI: ffff9bcdfd3a13c0
Nov 14 13:17:18 truenas kernel: RBP: ffff9bc72a1a4488 R08: 0000000000000000 R09: ffffbbd98772fc40
Nov 14 13:17:18 truenas kernel: R10: 0000000000000003 R11: ffff9bcdfd1fffe8 R12: ffff9bc72b21f000
Nov 14 13:17:18 truenas kernel: R13: ffff9bc72a1a43dc R14: 0000000000000000 R15: 0000000000002500
Nov 14 13:17:18 truenas kernel: FS: 00007f64adefb6c0(0000) GS:ffff9bcdfd380000(0000) knlGS:0000000000000000
Nov 14 13:17:18 truenas kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Nov 14 13:17:18 truenas kernel: CR2: 00007fa9f3798010 CR3: 0000000121fde000 CR4: 00000000003506e0
Nov 14 13:17:18 truenas kernel: Call Trace:
Nov 14 13:17:18 truenas kernel: <TASK>
Nov 14 13:17:18 truenas kernel: ? dev_watchdog+0x235/0x240
Nov 14 13:17:18 truenas kernel: ? __warn+0x81/0x130
Nov 14 13:17:18 truenas kernel: ? report_bug+0x171/0x1a0
Nov 14 13:17:18 truenas kernel: ? prb_read_valid+0x1b/0x30
Nov 14 13:17:18 truenas kernel: ? srso_return_thunk+0x5/0x5f
Nov 14 13:17:18 truenas kernel: ? handle_bug+0x41/0x70
Nov 14 13:17:18 truenas kernel: ? exc_invalid_op+0x17/0x70
Nov 14 13:17:18 truenas kernel: ? asm_exc_invalid_op+0x1a/0x20
Nov 14 13:17:18 truenas kernel: ? __pfx_dev_watchdog+0x10/0x10
Nov 14 13:17:18 truenas kernel: call_timer_fn+0x27/0x130
Nov 14 13:17:18 truenas kernel: __run_timers+0x222/0x2c0
Nov 14 13:17:18 truenas kernel: run_timer_softirq+0x1d/0x40
Nov 14 13:17:18 truenas kernel: handle_softirqs+0xda/0x2c0
Nov 14 13:17:18 truenas kernel: __irq_exit_rcu+0x98/0xc0
Nov 14 13:17:18 truenas kernel: sysvec_apic_timer_interrupt+0x3e/0x90
Nov 14 13:17:18 truenas kernel: asm_sysvec_apic_timer_interrupt+0x1a/0x20
Nov 14 13:17:18 truenas kernel: RIP: 0033:0x5e0abd
Nov 14 13:17:18 truenas kernel: Code: 8b 45 28 48 8b 40 08 48 85 c0 0f 84 a4 00 00 00 49 8d 54 24 08 48 8b 75 10 49 8b 3c 24 48 8d 4b ff ff d0 48 8b 15 c3 ce 47 00 <83> 42 20 01 48 83 c4 18 5b 5d 41 5c 41 5d 41 5e 41 5f c3 49 8b 87
Nov 14 13:17:18 truenas kernel: RSP: 002b:00007f64adefaa40 EFLAGS: 00000202
Nov 14 13:17:18 truenas kernel: RAX: 00007f64ac40cb50 RBX: 0000000000000001 RCX: 00007f6516bee531
Nov 14 13:17:18 truenas kernel: RDX: 00000000037843c0 RSI: 0000000000000081 RDI: 0000000001f8b320
Nov 14 13:17:18 truenas kernel: RBP: 00007f6515346890 R08: 000000000007b000 R09: 0000000000000000
Nov 14 13:17:18 truenas kernel: R10: 0000000000000000 R11: 0000000000000246 R12: 00007f64e407e208
Nov 14 13:17:18 truenas kernel: R13: 00000000037843c0 R14: 00000000021a6df0 R15: 00000000021a6df0
Nov 14 13:17:18 truenas kernel: </TASK>
Nov 14 13:17:18 truenas kernel: ---[ end trace 0000000000000000 ]---
Nov 14 13:17:18 truenas kernel: igb 0000:05:00.0 enp5s0: Reset adapter
Nov 14 13:17:18 truenas kernel: igb 0000:05:00.0 enp5s0: igb: enp5s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Nov 14 13:17:18 truenas kernel: igb 0000:05:00.0: read 1000Base-T Status Reg
