VRAM Heizung kommt diese woche.Wer nicht wagt, der nicht gewinnt
VRAM Heizung kommt diese woche.![]()
I don't use MoreClockTool.MoreClockTool, can you send me a copy?
I noticed that when you overclocked 4090, the system optimization was not done properly
What do you mean by that?My score is totally optimized by the system
No Asus software comes near to my bench windows.Asus AI overclocking![]()
Reduce desktop resolution and increase some frame countsWhat do you mean by that?
Thank you for your help.@qq948371167 for the MCT you need to go to Igor
Download area: New version of MorePowerTool (MPT) and final release of RedBIOSEditor (RBE) | igor´sLAB
I have combined the download sections into one page and instead link to the older articles with the tutorials in the software table. The download as such is only available on this page in a summarised…www.igorslab.de
VDCR_MEM+150mvJetzt kann es wieder Sommer werden![]()
Anhang anzeigen 944560![]()
I scored 39 344 in Time Spy
Intel Core i9 processor 14900KF, AMD Radeon RX 7900 XTX x 1, 32768 MB, 64-bit Windows 11}www.3dmark.com
Loop 1 Iout Gain 100My XTX card is at 39340 points, can not raise and need help
Can you help me optimize it?
I need to move those places to boost memoryLoop 1 Iout Gain 100
Change Vid offset at address 26?First, at adress 22, you need to adjust Iout Gain to 100 to almost remove Power Limit.
I guess with 3xx something you are in PL thats why points starve. Especially since you use quite high voltage and offset.
Second step you can try increase memory. But it is at adress 26!
Super 👌Jetzt kann es wieder Sommer werden
Yes for memory!Change Vid offset at address 26?
Ich denke das hängt vom GPU-Takt ab, je höher desto mehr bringt RAM-OC.Wieviel TS-Grafikpunkte machen 250 MHz VRAM-Takt bei der 7900 XTX etwa aus?
Mag sein. Es kam aber an, dass ich nicht eine theoretische Diskussion darüber führen wollte, sondern um zwei reale Scores (mit/ohne VRAM-OC) gebeten habe?Ich denke das hängt vom GPU-Takt ab, je höher desto mehr bringt RAM-OC.
Möglichst im Nicht-Powerlimit, also entweder mit ASR-XOC-BIOS oder reduziertem Iout Gain. Oder kräftig undervolted natürlich.
Ich hätte das gern für meinen Abenteuerbericht. Würd's ja selbst testen, aber so hoch komm ich gar nicht mit meiner Krüppelkiefer. Wenn jemand bitte so freundlich wäre?🙏
Der hier ersetzt den Sept-Prev. 31.0.23013.1020 , ist von UL validiert , bringt bei mir so 200+ Pkt. mehr . Der 23.12.1 kam 1oder 2 Tage später , habe ich noch nicht getestet .Ist 23.12.1 ein starker TS-Treiber, kann er den Sept-Prev 2007 ersetzen? Kann das derzeit nicht testen, hab keine Karte.![]()
