[Sammelthread] Asrock AOD790GX/128M (AMD 790GX)
ASRock AOD790GX/128M, 790GX
1. Support for Socket AM2+ / AM2 processors: AMD Phenom™ FX / Phenom / Athlon 64 FX / Athlon 64 X2 Dual-Core / Athlon X2 Dual-Core / Athlon 64 / Sempron processor
2. Supports CPU up to 140W
3. ASRock DuraCap (2.5 x longer life time), 100% Japan-made high-quality Conductive Polymer Capacitors
4. AMD 790GX + SB750 Chipsets
5. AM3 CPU Ready!
* FSB 2600 MHz (5.2 GT/s)
* Supports AMD OverDrive™ with ACC feature (Advanced Clock Calibration)
* Supports Hyper-Transport 3.0 (HT 3.0) Technology
* Supports Dual Channel DDR2 1066 with AM2+ CPU , and DDR2 800/667/533 with AM2 CPU, with 4 DIMM slots, maximum capacity up to 16GB
* Integrated AMD Radeon HD 3300 graphics, DX10 class iGPU, Pixel Shader 4.0, Max. shared memory 512MB
* Integrated 128MB side port memory for iGPU
* Supports ATI™ CrossFire™ and Hybrid CrossFireX™
* 2 x PCI Express 2.0 x16 slots (green @ x16 mode, blue @ x8 mode)
* 6 x SATAII 3.0 Gb/s connectors, support RAID (RAID 0, RAID 1, RAID 5, RAID 10 and JBOD), NCQ, AHCI and Hot Plug functions
* 1 x eSATAII 3.0 Gb/s connector
* 2 x IEEE1394 ports (one port on back panel, one header on board)
* PCIE Gigabit LAN 10/100/1000 Mb/s
* Three VGA Output options: D-Sub, DVI-D and HDMI with DVI-to-HDMI Converter
* Supports HDCP function
* Supports Full HD 1080p Blu-ray (BD) / HD-DVD playback
* 1 x USB/WiFi header
* Supports Smart BIOS, ASRock OC Tuner, Intelligent Energy Saver, Extra ESD Protection
* Free Bundle: 1 x ASRock XFire Switch Card, 1 x DVI-to-HDMI Converter
* 7.1 CH Windows® Vista™ Premium Level HD Audio, DAC with 110dB dynamic range (ALC890 Audio Codec)
* Windows® Vista™ Premium 2008 Logo Ready
* I/O Panel: 1 x VGA/D-Sub Port, 1 x VGA/DVI-D Port, 1 x eSATAII Port, 1 x IEEE 1394 Port, 1 x RJ-45 LAN Port with LED, 6 x USB 2.0 Ports
2. FAQ - Frequently Asked Questions
- "Lassen sich 3 Pin Lüfter steuern?"
Nein das geht nicht.
- "Ist der Sideportspeicher alleine nutzbar?."
Jawohl das ist möglich.
3. Links & Downloads
3.1 Links zu Treibern, BIOS,Programmen
http://www.asrock.com/mb/download.asp?Model=AOD790GX/128M&s=AM2+
3.2 Reviews
http://www.pctreiber.net/thread.php?threadid=10224
http://www.cpu3d.com/review/5844-1/asrock-aod790gx-128m-motherboard/introduction.html
http://www.thinkcomputers.org/index.php?x=reviews&id=850
http://my.ocworkbench.com/2008/asrock/AOD790GX-128M/g1.htm
http://www.amdzone.com/index.php/reviews/66/10542-asrock-aod790gx128mb
3.3 Interessantes:
- Sideportspeicher ist alleine nutzbar
- Asrock OC Tuner unter Windows zum Übertakten
- Stromsparender als der Vorgänger 780G
- DVI auf HDMI Adapter im Lieferumfang enthalten
3.4. Overclocking
4. Preise
http://preisvergleich.hardwareluxx.de/deutschland/a365733.html
http://www.hardwareschotte.de/hardware/preise/proid_9775432/preis_ASROCK+AOD790GX128M
http://www.preistrend.de/suchen.php?q=AOD790GX&s=0&a=&z=&x=0&y=0
http://www.google.de/products?q=ASRock+AOD790GX&hl=de&scoring=p
5. Bekannte Probleme:
unter XP ist die 2D Performance bei allen 7er Chipsätzen nicht sehr hoch. Den Treiber aktualisieren bringt etwas. Ganz schlimm ist es mit Treibern unter dem 8.12er!
6. Fixes:
Lüfteregelung mit Speedfan:
http://www.hardwareluxx.de/community/showpost.php?p=13259216&postcount=587
7. Bios:
1.70er Version ist aktuell, doch gibt es hier Probleme mit der Core-Freischaltung
Interessantes Board, leider werden die Spannungswandler nicht mit einem Kühlkörper gekühlt... :motz:
Hast du das Board?
Wenn ja, bitte deine Erfahrungen posten!! :rolleyes:
Bitte auch mit FOTOS! :d
Ich habe das Board seit vorgestern. Läuft an sich recht gut mit einem Phenom 9950 BE 125W.
Jetzt wollte ich mich ans Overclocken per Bios machen, da mir AMD-Overdrive nicht zusagt. Das läuft ja nicht als Nicht-Admin und bei mir funkionieren die halben Teiler nicht nach dem Reboot bzw. beim Laden einer Konfiguration.
Ist das normal?
Beim Bios habe ich aber gleich das erste Problem: Was stelle ich beim CPU Frequency Multiplier ein? Z.B 29 um z.B. 2900 MHz zu haben? Auf 13 geht der Multiplier gar nicht runter und Halbschritte gibt es auch nicht...
@Micki_Krause: Bitte den Hotlink entfernen und das Bild verkleinern (Forenregeln beachten)!
@ Herrn Krause Haste das Board schon?
Wenn ja, bitte ein paar Erfahrungen! :)
Bisher läuft es in freier Verdrahtung. Verbrauch liegt mit einem 380Watt Netzteil und einer alten 120gb Platte bei 39 Watt im Idle. Stabil und schnell ist es wirklich. Der Biosboot geht sehr schnell von statten. Mehr kann ich bisher leider noch nicht sagen.
Windowsinstallation lief problemlos ab. Crystalcpuid funktioniert einwandfrei und die Vcore ist sehr stabil.
Gruß Micki
Wirst du es letztendlich mit picoPSU und 2,5" HDD betreiben?
Als "Interessantes" könntest du noch die Stromsparfunktion (IES) von ASRock einfügen, die im Idle die CPU Phasen ausschaltet.
Funktioniert die gut?
Der Sideport Memory ist übrigens DDR2, falls jemand fragt und der eSATA ist "shared". Also entweder 6x SATA oder 5x SATA + 1x eSATA.
Ich finde das einzige Manko an dem Board sind die zu dicht beieinanderliegenden PCIe x16 Slots und der fehlende Mostfet Kühler.
Ich denke mal das BIOS wird ähnlich wie bei meinem A770CrossFire sein, also schon mit dem Auslieferungsbios sehr ausgereift und ohne Macken.
Die ASRock Boards dieser Generation können sich echt sehen lassen.
IES funktioniert leider nur mit dem K10, hatte mich auch schon beim Asrock GeF8200 von dem Feature blenden lassen ;) Bringt aber scheinbar eh nicht viel, ASRock_User hat 1 Watt Unterschied gemessen.
Bisher läuft es in freier Verdrahtung. Verbrauch liegt mit einem 380Watt und einer alten 120gb Platte bei 39 Watt im Idle. Stabil und schnell ist es wirklich. Der Biosboot geht sehr schnell von statten. Mehr kann ich bisher leider noch nicht sagen.
Gruß Micki
Du meinst wohl 38 Watt, oder (380 wären bissl viel...)?
da fehlt "Netzteil" ups ;)
Ja wird mit meinem Pico und der 320gb Samsung betrieben werden. Speicher ist der MDT AMD Edition mit 2x2gb. Benutze einen X2 mit 4200+ im G2 Stepping.
Es lassen sich übrigens mal wieder nur 4 Pin Lüfter vom Bios steuern aber das ja net so schlimm denke ich.
Klasse bei dem Board finde ich das die Sata-Ports bei verwendung von 2 Grakas nicht verdeckt werden, dass ist bei meinem DS4H von Gigabyte nicht so !
rolle1112
@Micky Was meinste welcher Prozzi am besten zu dem Board passt um anständig zocken zu können?
AMD Athlon X2 4850e Sockel-AM2 boxed, 2x 2.50GHz, 2x 512kB Cache für 50€
AMD Athlon 64 X2 5400+ 65nm Black Edition Sockel-AM2 boxed, 2x 2.80GHz, 2x 512kB Cache für 64€
AMD Athlon 64 X2 5400+ 65nm Sockel-AM2 boxed, 2x 2.80GHz, 2x 512kB Cache für 62€
oder
AMD Athlon X2 5050e Sockel-AM2 boxed, 2x 2.60GHz, 2x 512kB Cache für 77€
Ich würde wohl den Black edition mit offenem Multi nehmen. Ansonsten den 4850e.
Ok, welchen Prozzi hast du denn drauf?
Und wenn du VISTA nutzt, könntest du dann bitte mal ein Leistungsindex ausführen und hier posten?
Ich hab einen X2 4200+ im G2 Stepping demnächst drauf. Bis morgen werkelt der Prozi noch in dem in der Signatur verlinkten Stromsparer.
Nutze XP.
Gruß Micki
So inzwischen habe ich meinen Rechner auf 2900 MHz übertaktet bekommen bei 1,275 Volt. Mich wundert es bloss, dass man bei Umstellung auf manuelle Taktung keine funktionierende Ersteinstellung hat :( Das war mein Problem. Northbridgespannung war zu niedrig und die Multiplikatoreinstellung ist auch irreführend.
Wie bekomme ich Crystalcpuid zum Laufen, so daß ich übertakten kann. Ist momentan alles bei mir ausgegraut.
Wenn ich im Bios per Multi übertakte, dann habe ich ja leider kein CnQ mehr.
Stephan
du kannst ja auch crystalcpuid als CNQ Ersatz nehmen - Stichwort "multipliermanagement"
CNQ im Bios dafür aber deaktivieren soweit ich das noch weiß. Mache das schon lange so und man kann die Vcore auf 0,8V statt 1,1V absenken.
CrystalCPUID scheint mit Phenoms nicht zu fuktionieren, zumindest lese ich immer davon.
aber dafür gibt es doch von AMD ein eigenes Tool mit dem man sogar die Kerne unabhängig takten kann.
AMD Overdrive lässt auch kein CnQ zu. Und läuft bei mir instabil. Und braucht auch wieder Administratorrechte.
CrystalCpuid läuft bei mir mit Phenom nicht.
Also bleib ich wohl bei Bios-Einstellungen... :(
@ Micky Krause und allen anderen die das Board schon haben: Wie gefällt euch das Board, was stört euch daran und überhaupt? :)
Was genau findest du daran irreführend? Das System ist doch recht einfach (und recht "mächtig"):
Hier sind insgesamt drei Einstellungen wichtig:
1) CPU Frequency (Referenztakt), 2) Frequency Multi und 3) Frequency Divider.
Der Takt des Phenoms errechnet sich nun nach folgender Formel:
(Referenztakt/2) * (1/Divider)* Multiplikator = Coretakt des AMD Phenom auf dem AOD790GX/128M
http://www.pctreiber.net/datenbank_artikel_86_lesen.html
Irreführend ist, daß man bei AOD z.B. als Multiplikator 14,5 einstellt und im Bios 29.
Und dass man eine nicht funktionierende Einstellung hat, wenn man Multiplier-/Voltage auf manuell stellt, ist doch schon mehr als verwirrend.
Wenn ich den Artikel gelesen hätte, dann wäre ich zumindest nicht über den Multiplikator gestolpert.
Sooo, ich habe das Board samt X2 5400+ BE!
Soweit finde ich es ganz gut!
ABER: Zwei Kritijpunkte habe ich gefunden:
1. Wieso kann ich nur eine Auflösung von 1920x1080 via Onboardgrafik auswählen (es sollen doch 2560x1600 laut AsRock mit DVI möglich sein!!)?
2. Wieso wird meine Festplatte (1TB F1) nicht von den üblichen Verdächtigen erkannt (Everest, Speedfan usw.)?
Aber sonst ist es ein cooles Board!
Ach ja, eine Frage hätte ich noch an AsRock_User:
Weißt du etwas von "Instant Boot" für AMD Boards?
Die P45XE Reihe hat ja seit heute (?) ein Biosupdate erhalten, dass Instant Boot enthält!
Mein Board hängt sich über Nacht leider immer auf. Der letzte Eintrag ist immer um 3:05 :d
morgens ist der Bildschirm immer schwarz. Habe nun statt 0,775V mal wieder 0,8V bei 800mhz eingestellt. Vielleicht liegt es ja daran - ich hoffe doch mal.
Sonst bisher noch keinen Absturz. USB Performance ist göttlich. Tja bisher fast rundherum zufrieden.
Hallo Forengemeinde,
ich bin neu hier und habe diesen Thread gefunden weil ich langsam aber sicher ans Aufrüsten denken muss.
CPU, Grafikkarte und SPeicher sind schon fix, jedoch habe ich echte Entscheidungsprobleme was das Mainboard betrifft. Die schier unüberschaubare Vielfalt an AMD Mainboards macht die Auswahl nicht gerade einfach weil jedes Board pro und kontras zu bieten hat.
Erst wollte ich mir das MSI KA790GX-M zulegen. Jedoch wird reihenweise über den BIOS Support gemeckert und ich möchte eigentlich doch gerne wenigstens etwas Zukunftssicherheit haben und auch mal einen Deneb nutzen können.
Jetzt habe ich mir das Gigabyte GA-MA790GP-DS4H angesehen und bin eben dadurch auf das hier diskutierte ASRock AOD790GX gekommen.
Ich wollte gerne von euch wissen ob das ASRock Board qualitativ an das Gigabyte Board heranreicht auch bezüglich SpaWas (ASRock war für mich immer eine Billigschmiede) oder ob es eine echte Alternative zum 30 Euro teureren DS4H ist.
Viele Grüsse
Ich glaube da kannst du dir nur die Bilder anschauen. Kann ich leider wenig zu sagen, da ich das GB nicht kenne.
