[Sammelthread] ASRock Fatal1ty X370 Gaming K4
(lt. Berichten bereits EOL!)
- Spezifikationen:
Gaming ArmorPower
  • Hi-Density Power Connectors (24 pin and 8 pin)
Memory
  • 15μ Gold Contact in DIMM Slots
VGA Card
  • 15μ Gold Contact in VGA PCIe Slot (PCIE2)
Internet
  • Intel® LAN
Cooling
  • XXL Aluminum Alloy Heatsink
Audio
  • Creative Sound Blaster™ Cinema 3
Unique FeatureASRock USB 3.1
  • ASRock USB 3.1 Type-A Port (10 Gb/s)
  • ASRock USB 3.1 Type-C Port (10 Gb/s)
ASRock Super Alloy
  • Premium 45A Power Choke
  • Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
  • I/O Armor
  • Matte Black PCB
  • High Density Glass Fabric PCB
  • 2oz Copper PCB
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
CPU
  • Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
  • IR Digital PWM
  • 12 Power Phase design
  • Supports 95W Water Cooling
Chipset
  • AMD Promontory X370
Memory
  • Dual Channel DDR4 Memory Technology
  • 4 x DDR4 DIMM Slots
  • AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
  • AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
  • Max. capacity of system memory: 64GB**
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
  • 128Mb AMI UEFI Legal BIOS with GUI support
  • Supports "Plug and Play"
  • ACPI 5.1 compliance wake up events
  • Supports jumperfree
  • SMBIOS 2.3 support
  • CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
Graphics
  • Integrated AMD Radeon™ R-Series Graphics in A-series APU*
  • DirectX 12, Pixel Shader 5.0
  • Max. shared memory 2GB
  • Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
  • Supports HDCP with HDMI Port
  • Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
*Actual support may vary by CPU
Audio
  • 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
  • Premium Blu-ray Audio support
  • Supports Surge Protection
  • Nichicon Fine Gold Series Audio Caps
  • 120dB SNR DAC with Differential Amplifier
  • TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
  • Pure Power-In
  • Direct Drive Technology
  • PCB Isolate Shielding
  • Impedance Sensing on Line Out port
  • Individual PCB Layers for R/L Audio Channel
  • Gold Audio Jacks
  • Supports Creative Sound Blaster™ Cinema 3
LAN
  • Gigabit LAN 10/100/1000 Mb/s
  • GigaLAN Intel® I211AT
  • Supports Wake-On-LAN
  • Supports Lightning/ESD Protection
  • Supports Energy Efficient Ethernet 802.3az
  • Supports PXE
SlotsAMD Ryzen series CPUs
  • 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
AMD 7th A-Series APUs
  • 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
  • 4 x PCI Express 2.0 x1 Slots
  • Supports AMD Quad CrossFireX™ and CrossFireX™**
  • Supports NVIDIA® Quad SLI™ and SLI™**
  • 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
  • 1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
  • 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks
Connector
  • 1 x COM Port Header
  • 1 x TPM Header
  • 1 x Power LED and Speaker Header
  • 1 x AMD Fan LED Header
  • 2 x RGB LED Headers*
  • 1 x CPU Fan Connector (4-pin)**
  • 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
  • 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
  • 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
  • 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
  • 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
  • 1 x Front Panel Audio Connector
  • 1 x AMD LED Fan USB Header
  • 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
  • 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
  • 1 x Dr. Debug with LED
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
Rear Panel I/O
  • 2 x Antenna Ports
  • 1 x PS/2 Mouse Port
  • 1 x PS/2 Keyboard Port
  • 1 x HDMI Port
  • 1 x Optical SPDIF Out Port
  • 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
  • 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
  • 6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
  • 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
  • HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
Software and UEFI
Software
  • ASRock F-Stream
  • ASRock RGB LED
  • ASRock Key Master
  • ASRock APP Charger
  • ASRock XFast LAN*
UEFI
  • ASRock Full HD UEFI
  • ASRock Instant Flash
  • ASRock Internet Flash
  • ASRock Crashless BIOS
  • ASRock Easy RAID Installer
*These utilities can be downloaded from ASRock Live Update & APP Shop.
Support CD
  • Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
Accessories
  • Quick Installation Guide, Support CD, I/O Shield
  • 4 x SATA Data Cables
  • 1 x ASRock SLI_HB_Bridge_2S Card
  • 3 x Screws for M.2 Sockets
Hardware Monitor
  • Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
Form Factor
  • ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS
  • Microsoft® Windows® 10 64-bit*
*For the updated Windows® 10 driver, please visit ASRock's website for details.
Certifications
  • FCC, CE
  • ErP/EuP ready (ErP/EuP ready power supply is required)
[td]
Quelle: ASRock-Webseite
- RAM Kompatibilität:
Liste der geprüften RAM-Riegel des Herstellers
weitere KITs von Forenmitgliedern:
G.Skill Flare X 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GFX@3200Mhz (XMP-Profile)
G.Skill Trident Z 32GB Kit (16GBx2) 3200MhzF4-3200C14D-32GTZ@2933Mhz 18-16-16-16-40 1.35V
G.Skill Trident Z 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GTZ@2933Mhz (XMP-Profile)
G.Skill Trident Z 16GB Kit (8GBx2) 3600MhzF4-3600C15D-16GTZ@3200Mhz 14-14-14-14-34 1.36V
G.Skill RipJaws V 16GB Kit (8GBx2) 3600MhzF4-3600C16D-16GVK@2933Mhz 14-14-14-14-34 1.35V
Crucial Ballistix Tactical 16GB Kit (8GBx2) 2666MhzBLT2C8G4D26AFTA@2666Mhz (XMP-Profile)
Crucial Ballistix Sport LT 16GB Kit (8GBx2) 2400MhzBLS2C8G4D240FSE@2933Mhz 20-20-20-20-48 1.35V
Tipps von "paui":
CAS-Timing:
Es können nur gerade Zahlen dort eingegeben werden.
Sobald man eine 15 einstellt wird diese aufgerundet. Also entweder 14 oder 16 aber keine 15 CAS.
RAM-Stabilität:
Die SOC Spannung erhöhen z.b. auf 1,1V oder 1,2V und überall immer LLC auf Level3
Bei SingleRank Modulen den Bankgroupswap auf disabled stellen.
Die Spannung auf 1,360V für 1,352V unter Last für den ram setzen, VTT_DDR ist immer die Hälfte davon!
Als Beispiel beim G.Skill F4-3600C15D-16GTZ:
3200MHz bei 14-14-14-14-34 mit 1,36V, Bankgroupswap disabled, SOC 1,112V
(wenn es nicht läuft, dann auf 2933MHz da läuft er definitiv stabil)
- BIOS-Versionen:
BIOS-Download von der Herstellerseite
BIOS-Download (auch alte Versionen) bei Computertechnik JZelectronic
V4.70 - Enhance compatibility for Raven CPU with Intel WiFi.
V4.60 - 1.Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a. 2.Improve M.2 SSD compatibility.
V4.50 - Update AGESA for upcoming processors.
Wenn man eine Version unter V3.50 auf eine Versionen über V3.50 flashen möchte, muss man einen Zwischenschritt auf V3.50 machen!
V3.50 - Bridge BIOS
V3.40 - 1.Sync the H/W Monitor and Dr.Debug code Temp source to tCTL 2. Gray out Instant Flash when fTPM is enabled.
V3.30 - 1. With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
V3.20 - 1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. 2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
V3.10 - Add AMD PBS Primary Video Adapter to control Bristol Ridge CPU display order.
V3.00 - Update AGESA to 1.0.0.6a
V2.50 - Update AGESA to 1.0.0.6
V2.40 - Enhance OC setting for advanced Overclocker
V2.30 - Verbesserte System und Speicher Kompatibilität
V2.20 - Update AGESA Version string SummitPI-AM4 1.0.0.4a
V2.10 - Verbesserte System Kompatibilität
V2.00 - AGESA-Code aktualisiert - Verbesserung für Ryzen 5 & Precision Boost - Taktraten können jetzt in 25MHz-Schritten im BIOS-Setup eingestellt werden
V1.70 - Improve XMP DRAM compatibility & Add Simultaneous Multi-Threading(SMT) item in BIOS setup
V1.60 - Add Instant flash function & Add CPU Frequency Multiplier Change item
V1.50 - Support CPU Frequency Multiplier function
- Übertakten (CPU/RAM):
Laut dem Video von AMD sollte man bei einem Dauerbetrieb die CPU nicht über VCORE 1.425V betreiben.
Oft kann man auch lesen, dass Werte von 1.45V oder gar bis zu 1.5V ok sind. Hier sollte man aber bedenken, dass dies die Lebensdauer der CPU verkürzt werden kann.
Der SoC kann super mit 1.1V betrieben werden. Oft kann man auch lesen, dass 1.2V noch ok sind.
- Testberichte / Reviews:
Altes Startposting:
Hallo!
Sie wie es aussieht scheint kaum wer ein ASRock X370 Gaming K4 zu haben. Entsprechend spärlich sind auch die Infos, die ich bis jetzt so finden konnte...
Weiß jemand, ob die Backplate des ASRock X370 Gaming K4 verschraubt oder verklebt ist? Da ich einen Lüfter mit eigener Backplate holen möchte, wäre dies wirklich gut zu wissen.
Des weiteren wollte ich fragen, ob man bei ASRock X370 Gaming K4 im BIOS die DRAM Timings manuell einstellen kann und natürlich auch die Taktfrequenz?
Optisch und Preislich spricht mich das Mainboard sehr an, technisch kann ich leider nicht beurteilen, wobei die "Werbeaussagen" ja nicht schlecht sind.
Vielen Dank
SneakyPie
Hat jemand schon folgenden RAM auf dem K4 getestet?
G.Skill Trident Z RGB DIMM Kit 32GB, DDR4-3200, CL15-15-15-35 (F4-3200C15D-32GTZR)
Okay danke für die Antworten, dann werde ich mich mal langsam rantasten.
Hey... Wisst ihr, ob es sich lohnt jetzt noch ein K4 Mainboard zu holen? Auch, wenn es EOL ist? Mir gehts da mehr so um die BIOS Updates...
Wenn Du ein paar Euro mehr über hast, kriegst Du mit dem Taichi etwas deutlich Besseres.
Ich hatte durch Blacky66 die günstige Chance das Pro Gaming zu erwerben. Also ich habe das Board jetzt erst seit 10 Minuten am Laufen. Ich hätte nicht gedacht, dass die Unterschiede so enorm sind. Mal davon abgesehen, dass der RAM endlich mit vollem Speed läuft und das nicht mit Startschwierigkeiten. Ich hatte da immer mal ein geringes Haken im Browser gehabt, auch durch die Speicherspiele. Die Sound Blaster Z läuft endlich ordentlich. Da gab es immer Signalabbrüche und sie war dadurch nutzlos. Also signaltechnisch scheint der Unterschied schon da zu sein. Nur der M.2-Sockel für S-ATA ist im Sockel näher zum Prozessor. Und ich wunderte mich, warum meine Crucial MX200 M.2 nicht läuft.
Wenn du eine pcie soundkarte nutzt, dann funktioniert der M2 Ultra Sockel nicht, weil dir einfach die Lanes ausgehen
Also viel besser sind die RAM-Spiele nicht mit dem F4-3200C16D-32GTZA nicht. Die Laufen halt jetzt mit 1600 MHz und problemloser.
@Blacky66 Die MX200 ist ohnehin keine SSD für PCI-E. Die lief auch nicht ohne Karte am M.2-Slot unter dem Slot des PCI-E 1x. Das hatte man beim Pro Gaming gedreht.
Dieses scheint DS zu sein, wäre interessant zu wissen, wie es im Vergleich zum 3200 SS performt.
Ich habe die Benchmarks nirgends gespreichert, aber ich kann dazusagen, dass der Corsair Ram bei 2666 MHz gleich schnell war wie der Flare X bei 2933 MHZ und den Flare X auf 3200 schaft man mit dem Board noch nicht. Aber ich würde wieder zu DS greifen und nicht zum Überteurten Ryzen Compatible Mist.
Ich habe 2x8GB vom Corsair 3200 CL16, das läuft auf den Killer SLI mit 2967 CL14, auf dem ASUS Prime B350-Plus meiner Tochter mit 3066 CL14. Aber eigentlich will ich 2x16GB haben, warte aber damit bis die Ram Preise sich wieder normalisieren und man mit Sicherheit weiß, das es dann auch mit dem spezifizierten Takt läuft.
Ok, das CL Tuning habe ich bis jetzt ausgelassen, ich bin schon verdammt froh, dass die 32GB mit 2933 MHz laufen
Laufen bei euch eigentlich alle USB3 Geräte ohne Probleme?
Bei mir (Killer), gibt es immer Abbrüche bei der Übertragung großen Datenmengen (40-60GB) von HDD/SSD auf externen USB3 Festplatten oder USB-Sticks. Diese vorher bestens mit einem Z170 funktionierten.
Hey Leute
Ich bin gerade meinen Ryzen Prozessor am übertaktet und bin ein wenig überfordert, die SOC finde ich bei mir nicht im bios (asrock 350 pro4) daher meine Frage ist die SOC unter VDDP verzeichnet ?
Hast du das neueste BIOS drauf? Bei 1.50 ist es nicht im BIOS vorhanden.
Gesendet von meinem ALE-L21 mit Tapatalk
Mein Rechner (X370 Killer SLI, 1700X, Samsung SSD 850 EVO 1TB, aktuelles Bios) braucht 20 sec bis zum Bios Screen, bis zum Windows 7 64bit Login dauert es mind. 50 sec. Der Rechner meiner Tochter (Asus Prime 350-Plus, 1600, Samsung SSD 840 EVO 500GB) braucht 10 sec bis zum Bios Screen, bis zum Windows 7 64bit Login dauert es ca 25 sec. In Anbetracht des höheren Preises ist das schon enttäuschend. Was könnten die Ursachen für die lange Bootzeit sein?
Falsche Speichereinstellungen oder zu viele selber gesetzte Timings oder allgemein ein schlechtes Speicherkit fuer die Platine. Wo auch imner, der Prozessor ein Boottraining durchfuehrt, wird wohl versucht Speichereinstellungen zu finden. Welcher RAM wird verwendet? Aktuelles UEFI ist wichtig.
2966MHz ist doch schon gar nicht so schlecht. die Riegel sind SS, Hynix Chips.
hast du die SOC Spannung angehoben bei 3200MHz?
CR1 oder 2?
