[Sammelthread] ASRock Fatal1ty X370 Gaming K4
(lt. Berichten bereits EOL!)
- Spezifikationen:
Gaming ArmorPower
  • Hi-Density Power Connectors (24 pin and 8 pin)
Memory
  • 15μ Gold Contact in DIMM Slots
VGA Card
  • 15μ Gold Contact in VGA PCIe Slot (PCIE2)
Internet
  • Intel® LAN
Cooling
  • XXL Aluminum Alloy Heatsink
Audio
  • Creative Sound Blaster™ Cinema 3
Unique FeatureASRock USB 3.1
  • ASRock USB 3.1 Type-A Port (10 Gb/s)
  • ASRock USB 3.1 Type-C Port (10 Gb/s)
ASRock Super Alloy
  • Premium 45A Power Choke
  • Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
  • I/O Armor
  • Matte Black PCB
  • High Density Glass Fabric PCB
  • 2oz Copper PCB
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
CPU
  • Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
  • IR Digital PWM
  • 12 Power Phase design
  • Supports 95W Water Cooling
Chipset
  • AMD Promontory X370
Memory
  • Dual Channel DDR4 Memory Technology
  • 4 x DDR4 DIMM Slots
  • AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
  • AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
  • Max. capacity of system memory: 64GB**
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
  • 128Mb AMI UEFI Legal BIOS with GUI support
  • Supports "Plug and Play"
  • ACPI 5.1 compliance wake up events
  • Supports jumperfree
  • SMBIOS 2.3 support
  • CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
Graphics
  • Integrated AMD Radeon™ R-Series Graphics in A-series APU*
  • DirectX 12, Pixel Shader 5.0
  • Max. shared memory 2GB
  • Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
  • Supports HDCP with HDMI Port
  • Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
*Actual support may vary by CPU
Audio
  • 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
  • Premium Blu-ray Audio support
  • Supports Surge Protection
  • Nichicon Fine Gold Series Audio Caps
  • 120dB SNR DAC with Differential Amplifier
  • TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
  • Pure Power-In
  • Direct Drive Technology
  • PCB Isolate Shielding
  • Impedance Sensing on Line Out port
  • Individual PCB Layers for R/L Audio Channel
  • Gold Audio Jacks
  • Supports Creative Sound Blaster™ Cinema 3
LAN
  • Gigabit LAN 10/100/1000 Mb/s
  • GigaLAN Intel® I211AT
  • Supports Wake-On-LAN
  • Supports Lightning/ESD Protection
  • Supports Energy Efficient Ethernet 802.3az
  • Supports PXE
SlotsAMD Ryzen series CPUs
  • 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
AMD 7th A-Series APUs
  • 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
  • 4 x PCI Express 2.0 x1 Slots
  • Supports AMD Quad CrossFireX™ and CrossFireX™**
  • Supports NVIDIA® Quad SLI™ and SLI™**
  • 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
  • 1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
  • 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks
Connector
  • 1 x COM Port Header
  • 1 x TPM Header
  • 1 x Power LED and Speaker Header
  • 1 x AMD Fan LED Header
  • 2 x RGB LED Headers*
  • 1 x CPU Fan Connector (4-pin)**
  • 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
  • 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
  • 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
  • 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
  • 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
  • 1 x Front Panel Audio Connector
  • 1 x AMD LED Fan USB Header
  • 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
  • 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
  • 1 x Dr. Debug with LED
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
Rear Panel I/O
  • 2 x Antenna Ports
  • 1 x PS/2 Mouse Port
  • 1 x PS/2 Keyboard Port
  • 1 x HDMI Port
  • 1 x Optical SPDIF Out Port
  • 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
  • 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
  • 6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
  • 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
  • HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
Software and UEFI
Software
  • ASRock F-Stream
  • ASRock RGB LED
  • ASRock Key Master
  • ASRock APP Charger
  • ASRock XFast LAN*
UEFI
  • ASRock Full HD UEFI
  • ASRock Instant Flash
  • ASRock Internet Flash
  • ASRock Crashless BIOS
  • ASRock Easy RAID Installer
*These utilities can be downloaded from ASRock Live Update & APP Shop.
Support CD
  • Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
Accessories
  • Quick Installation Guide, Support CD, I/O Shield
  • 4 x SATA Data Cables
  • 1 x ASRock SLI_HB_Bridge_2S Card
  • 3 x Screws for M.2 Sockets
Hardware Monitor
  • Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
Form Factor
  • ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS
  • Microsoft® Windows® 10 64-bit*
*For the updated Windows® 10 driver, please visit ASRock's website for details.
Certifications
  • FCC, CE
  • ErP/EuP ready (ErP/EuP ready power supply is required)
[td]
Quelle: ASRock-Webseite
- RAM Kompatibilität:
Liste der geprüften RAM-Riegel des Herstellers
weitere KITs von Forenmitgliedern:
G.Skill Flare X 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GFX@3200Mhz (XMP-Profile)
G.Skill Trident Z 32GB Kit (16GBx2) 3200MhzF4-3200C14D-32GTZ@2933Mhz 18-16-16-16-40 1.35V
G.Skill Trident Z 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GTZ@2933Mhz (XMP-Profile)
G.Skill Trident Z 16GB Kit (8GBx2) 3600MhzF4-3600C15D-16GTZ@3200Mhz 14-14-14-14-34 1.36V
G.Skill RipJaws V 16GB Kit (8GBx2) 3600MhzF4-3600C16D-16GVK@2933Mhz 14-14-14-14-34 1.35V
Crucial Ballistix Tactical 16GB Kit (8GBx2) 2666MhzBLT2C8G4D26AFTA@2666Mhz (XMP-Profile)
Crucial Ballistix Sport LT 16GB Kit (8GBx2) 2400MhzBLS2C8G4D240FSE@2933Mhz 20-20-20-20-48 1.35V
Tipps von "paui":
CAS-Timing:
Es können nur gerade Zahlen dort eingegeben werden.
Sobald man eine 15 einstellt wird diese aufgerundet. Also entweder 14 oder 16 aber keine 15 CAS.
RAM-Stabilität:
Die SOC Spannung erhöhen z.b. auf 1,1V oder 1,2V und überall immer LLC auf Level3
Bei SingleRank Modulen den Bankgroupswap auf disabled stellen.
Die Spannung auf 1,360V für 1,352V unter Last für den ram setzen, VTT_DDR ist immer die Hälfte davon!
Als Beispiel beim G.Skill F4-3600C15D-16GTZ:
3200MHz bei 14-14-14-14-34 mit 1,36V, Bankgroupswap disabled, SOC 1,112V
(wenn es nicht läuft, dann auf 2933MHz da läuft er definitiv stabil)
- BIOS-Versionen:
BIOS-Download von der Herstellerseite
BIOS-Download (auch alte Versionen) bei Computertechnik JZelectronic
V4.70 - Enhance compatibility for Raven CPU with Intel WiFi.
V4.60 - 1.Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a. 2.Improve M.2 SSD compatibility.
V4.50 - Update AGESA for upcoming processors.
Wenn man eine Version unter V3.50 auf eine Versionen über V3.50 flashen möchte, muss man einen Zwischenschritt auf V3.50 machen!
V3.50 - Bridge BIOS
V3.40 - 1.Sync the H/W Monitor and Dr.Debug code Temp source to tCTL 2. Gray out Instant Flash when fTPM is enabled.
V3.30 - 1. With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
V3.20 - 1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. 2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
V3.10 - Add AMD PBS Primary Video Adapter to control Bristol Ridge CPU display order.
V3.00 - Update AGESA to 1.0.0.6a
V2.50 - Update AGESA to 1.0.0.6
V2.40 - Enhance OC setting for advanced Overclocker
V2.30 - Verbesserte System und Speicher Kompatibilität
V2.20 - Update AGESA Version string SummitPI-AM4 1.0.0.4a
V2.10 - Verbesserte System Kompatibilität
V2.00 - AGESA-Code aktualisiert - Verbesserung für Ryzen 5 & Precision Boost - Taktraten können jetzt in 25MHz-Schritten im BIOS-Setup eingestellt werden
V1.70 - Improve XMP DRAM compatibility & Add Simultaneous Multi-Threading(SMT) item in BIOS setup
V1.60 - Add Instant flash function & Add CPU Frequency Multiplier Change item
V1.50 - Support CPU Frequency Multiplier function
- Übertakten (CPU/RAM):
Laut dem Video von AMD sollte man bei einem Dauerbetrieb die CPU nicht über VCORE 1.425V betreiben.
Oft kann man auch lesen, dass Werte von 1.45V oder gar bis zu 1.5V ok sind. Hier sollte man aber bedenken, dass dies die Lebensdauer der CPU verkürzt werden kann.
Der SoC kann super mit 1.1V betrieben werden. Oft kann man auch lesen, dass 1.2V noch ok sind.
- Testberichte / Reviews:
Altes Startposting:
Hallo!
Sie wie es aussieht scheint kaum wer ein ASRock X370 Gaming K4 zu haben. Entsprechend spärlich sind auch die Infos, die ich bis jetzt so finden konnte...
Weiß jemand, ob die Backplate des ASRock X370 Gaming K4 verschraubt oder verklebt ist? Da ich einen Lüfter mit eigener Backplate holen möchte, wäre dies wirklich gut zu wissen.
Des weiteren wollte ich fragen, ob man bei ASRock X370 Gaming K4 im BIOS die DRAM Timings manuell einstellen kann und natürlich auch die Taktfrequenz?
Optisch und Preislich spricht mich das Mainboard sehr an, technisch kann ich leider nicht beurteilen, wobei die "Werbeaussagen" ja nicht schlecht sind.
Vielen Dank
SneakyPie
mein größtes problem momentan ist, dass mein PC über Nacht einfriert. Jetzt lief er wieder über 2 Nächte ohne Probleme und in der dritten Nacht wieder aufgehangen. Wo nurmehr ein Hardreset hilft. kein bluescreen keine Meldung im Eventviewer.
bin schon echt verzweifelt. Jemand ne idee?
An welchen Takt/Volt schrauben hast du gedreht? Oder tritt das bei Standartwerten auf.
Ich kann mir vorstellen dass die Spannungen vom RAM und/oder SoC im Idle gesenkt werden - und daher Memtest (bei dem dann die volle Spannung anliegt) kein Problem erkennt.
Ich spiele mit dem Gedanken mir das Gaming X zu holen - hat sich jemand evtl. das M2 Wifi Modul nachgerüstet und kann ein fertiges Kit bzw zumindest Kit aus Blende/Antennen/Kabel empfehlen?
Oder ohnehin lieber einen PCIe/USB Adapter? Bei USB habe ich immer "Vertrauensprobleme", da schon oft erlebt, dass die Dinger nicht zuverlässig die Verbindung halten...
Ich hab aus einem alten Laptop einen genommen, und die antennen innen im gehäuse verlegt.
hm grad nen reboot gehabt, im eventlog steht
Message: Schwerwiegender Hardwarefehler.
Gemeldet von Komponente: Prozessorkern
Fehlerquelle: 3
Fehlertyp: 9
Prozessor-APIC-ID: 3
Die Detailansicht dieses Eintrags beinhaltet weitere Informationen.
Hallo zusammen, habe ein kleines Problem. Habe seit Samstag das Gaming X. Dazu G.Skill Trident Z 3200Mhz. Laut QVL von AsRock sollten die mit 2933Mhz laufen. Ich habe also im BIOS das XMP Profil geladen und bei der Geschwindigkeit 2933MHz eingestellt. Startet alles super. Mache ich aber z.B. einen Neustart. Versucht er 3 mal zu booten und setzt dann den RAM wieder auf 2133 zurück. Das ist aber total unregelmäßig. Mal geht es, mal nicht. Mache ich irgendetwas falsch?
Ich hatte ein ähnliches Problem - hatte zwei identische System mit dem Gaming X, einem 1700 und G.Skill 3200 (gibt aber davon mehrer Ausführungen). Die CPU war entscheidender als das Board - CPU A konnte auf beiden Boards die 3200 mit Stock XMP profil fahren, bei CPU B musste ich die SoC leicht anheben.
Interessant fand ich jedoch das CPU A alle Ram kombos (ich hab die 4 Module in allen erdenklichen zweier-Kombis ausprobiert) per XMP mitmachte, CPU B bei manchen Kombis nichtmal bis 2800 bei XMP timings kam. Letztendlich kann ich aber für die G.Skill Speicher mit Samsung-B dies sagen, das Timings besser anspringen als takt. Also zb war einmal 2800 nicht mit CL-14 möglich - erst mit CL-16, Auf 3200 aber das gleiche Spiel.
Also ich würde versuchen erst die Voltage an deine Schmerzgrenze zu fahren (bei mir war das SoC +60mv und DRAM auf 1.375v) - und dann die Timings zu erhöhen bis es stabil ist. FastBoot würde ich weglassen, CSM vllt auch aktivieren (hilft beim starten).
"Bank Group Swap" und GearDown hab ich auf aus.
Hab mal n Screenshot angehängt wie die werte dann Live aussehen
https://abload.de/img/gskillugolm.png
Bei CPU-A sah das genauso aus, nur das SoC auf +0mv und RAM bei 1.35 lief. Hätte ich aber bei CPU-B, die RAM Module genommen die jetzt auf CPU-A laufen, hätte ich CL-16 nehmen müssen UND volt anheben.
PS:
Die Probleme Traten aber wie bei dir nicht sofort auf. Sondern erst nachdem ich ihn einmal komplett aus, und dann nach ein paar sek wieder angemacht habe.
Das ist ja interessant zu hören. Also ich habe die Trident Z mit Hynix Chips. Habe ich aber bewusst so gewählt, da ich für mich dachte 2933Mhz reichen mir, und so sollten sie ja laut AsRock auch laufen. GTZB steht glaub ich hinten bei meinen G.Skill. Sind auch "nur" CL16.
Das komische ist, dass ich das XMP Profil lade, dann trägt es ja automatisch die Timings und DRAM Voltage ein. Er möchte 1,35V eintragen, bleibt aber immer auf 1,25V im BIOS. Habe dann gestern nochmal alles im BIOS auf default und die BIOS Version 3.10 nochmal geflasht. Gestern Abend hatte ich dann keine Probleme mehr beim neustarten. Muss ich heute nochmal genauer testen.
Hat das evtl was mit zu tun, dass momentan die CPU noch auf Auto läuft? Was ich gesehen habe im Windows, stellt das Board die schon auf einen Multi von 35. Stock wären doch 34?
Schreibe jetzt nochmal mein System als Info:
Ryzen 1700x
AsRock X370 Fatality Gaming X
G.Skill 16GB F4-3200C16D-16GTZB
beQuiet Straight Power 500W
Ich möchte jetzt keine OC Wunder erreichen, aber ein bisschen komisch ist es schon. Kann ich das irgendwie umgehen mit anderem RAM? Oder denkst du es liegt wirklich an der CPU?
Die 1.35v solltest du dem RAM aber auf jedenfall geben - das macht schon einen Unterschied.
Was Windows an Multi anzeigt ist gefühlt geraten - wenn du HWmonitor oder so zum auslesen nutzt zeigt der das eigentlich besser an.
Übertakten ist mit dem Gaming X auch sehr easy - trag einfach den Max-Takt und die Volt ein (3.75ghz - 1.3v hatte ich), der Rest kommt von alleine. Ein tipp noch - nutze nicht die ASrock treiber.
Chipset
Nim die von AMD, da ist alles bei was man braucht + Ryzen Power Plan. Der Wird nicht so weit runtertakten wie man denkt (ich glaube 2.9 ghz im idle) - aber das ist ok, kann im zweifel dann in den Windowseinstellungen nachjustieren.
Und warte 1-2 Minuten nach dem Start bis er runtergeht.
Und ja - ich bin mir ziemlich sicher dass mit einer anderen CPU auf dem Selben Board andere RAM settings möglich sind.
Aber wenns jetzt läuft - fass es nicht mehr an :)
Chipset
Im BIOS bleiben momentan immer 1,25V beim DRAM stehen. Nochmal schauen, ob das ein Anzeigebug ist.
Habe CPU-Z genutzt um den Multi auszulesen. Eigentlich wollte ich die CPU moderat übertakten, aber wenn die ganze Kiste nicht mal richtig bootet, brauche ich damit nicht anfangen. Muss jetzt heute Abend nochmal schauen, ob er jetzt richtig bootet, bzw nach einem Neustart nicht wieder alle Settings zurücksetzt, weil er nicht booten kann.
Dann sollten ja z.B. 3,6Ghz mit unter 1,3V laufen.
Ansonsten läuft das System stabil. Ich habe jetzt einige Games gespielt und getestet, habe Cinebench und andere Benches laufen lassen. Nur das mit dem Booten macht mich doch etwas stutzig. Wie kann er zuerst normal booten und beim Neustart merkt er "oh mit den Settings kann ich nicht booeten" :stupid:
Vlt. spackt das Boottraining oder wie das heisst? Schalte das mal aus.
Das Gaming X mit Bios 3.10 hat die Einstellung übrigens eh nicht (oder ich bin zu blöd sie zu finden).
Finde sie auch nicht. Das 3.10 hat einiges nicht mehr oder, wie ältere BIOS Versionen? LLC und solche Dinge?
Also ich kann im BIOS in der VDRAM eintragen was ich will, das interessiert das Board gar nicht. Bleibt halt auf 1.25V. Unter Windows mit HWinfo zeigt es mir dann 1,256V. Ich verstehe das nicht.
Habe mal noch das gefunden. Hier kann der User auch eintragen was er will in die VDRAM aber es passiert nichts.
http://forum.asrock.com/forum_posts.asp?TID=5400&title=x370-gaming-x-no-llc-offsetv-fixedv-values-only
edit: unter HWinfo sehe ich dass meine CPU mit 35er Multi läuft und 1.5V Vcore. Das macht das Mainboard wenn ich auf Auto bin. Kann das sich noch auswirken auf den RAM? Wenn kozfogel seine CPU mit 1,3V auf glaube ich 3.7 laufen hat, dann kommt mir das ein wenig viel vor?
LLC gabs glaube ich nie beim X - ob Boot training mal da war kann ich nicht sagen.
Das mit der RAM voltage ist durchsaus eigenartig - wüsste jetzt nicht woher das rührt (die VTT_DDR hast du nehme ich an nicht angefasst). Der User aus dem verlinkten Forum meint aber auch das es wohl nur ein Auslesefehler ist - was ich übrigens bei der Vcore auch behaupten würde.
1.5 ist sehr hoch (und die Ryzen standarts gehn glaube ich nur bis ~1.44) - wenn du jetzt nicht gerade eine fett Wakü hast würde man das auch kaum kühlen können.
Hattest du nach dem BIOS update mal ein reset gemacht (mit Jumper - nicht über das menu)? Das wäre alles was mir dazu noch einfällt - das vllt irgendwas nicht richtig gecleart wurde.
Danke für deine Hilfe! Was komisch ist und eben auch für den Anzeigebug spricht: die VTT_DDR steht auf 0,68. Das ist die Hälfte von 1,36V. Das ist genau das was der User im Forum beschrieben hat. Komisch ist nur, dass auch unter Windows HWinfo 1,256V anzeigt.
Den CMOS Reset habe ich eben gemacht. Brachte keine Besserung. Was ich auch nicht verstehe, ich habe jetzt im BIOS die CPU auf 34 gestellt. Trotzdem springt der Multi im HWinfo und CPU-Z auf 35 sobald Last drauf kommt. Auch ein Anzeigebug?
keine ahnung welchen ram hast du ..... kann ich mir nicht vorstellen ..... der linke wert ist vorgegeben der rechte ist was du einstellst solte klar sein.
Ich habe den RAM F4-3200C16-8GTZB : G.Skill Trident Z 3200 CL16. Mir ist das schon klar. Ich stelle ja 1,35 ein bzw. das XMP Profil macht das. Aber es zeigt mir nur 1,256 unter Windows/BIOS an.
Hast du es mal mit FStream versucht? Das ist ja vom Hersteller und nutzt möglicherweise andere APIs als HWmon und konsorten. Da kannst du sogar im Windows die Spannung einstellen.
Würd jedenfalls mal n Blick rein werfen, vllt gibt es ja Aufschluss.
Habe ich eben getestet. Es zeigt hier auch 1,256V an. Jedoch steht da drin, dass 1,35V eingestellt sind. Somit vermute ich er liest das falsch aus. Das Gleiche gilt für den Multi. Der wird immer mit 35 angezeigt. Lass ich aber Cinebench laufen, dann sagt er mir 1700x @ 3200 als Beispiel. Im FStream steht auch 3200. Finde das irgendwie total komisch, sowas hatte ich noch bei keinem Rechner. Aber dieses Verhalten hat nichts mit der CPU zu tun? Könnte den RAM mal noch auf Fehler testen.
edit: sehe gerade, auf S. 24 von diesem Thread hat der user paui genau das Verhalten mit der falschen Voltage Anzeige beschrieben...
Testen kann nie schaden. Aber falsche V-core, falscher takt, falscher DRam voltage ... irgendwas sagt mir an dem Parte vom Board der zum auslesen zuständig ist hat ein Problem. Das könnte ein aus irgendwelchen Gründen schief gelaufenes Update von Bios oder Microcode sein, oder ein Hardware defekt.
Du könntest:
1.das Bios nochmal flashen um das auszuschließen (vllt auch mal die 3.00er probieren)
2.Beim Ram mal nur einen Riegel nehmen, und den auf den Slots durchtesten (falls was mit dem Speichercontroller der CPU nicht passt)
3.Falls du es nicht hast - Windows frisch machen (Für den Fall dass du die platte einfach aus einem alten Rechner mit win7 da reingestopft hast)
4.Den BoneCrusherXes ausm ASrock forum anschreiben, vllt ist der ja schlauer geworden.
ich halte das alles für eher unwahrscheinlich das es was bringt, aber ich für meine Teil wüsste sonst nicht mehr viel.
Im klartext würde ich das Bios nochmal Flashen, einmal reboot, bios resetten - einen RAM-modul von dem ich weiß das es läuft einsetzen und die DRAM auf 1.3 stellen (von Hand). Wird der Werte dann nach einem Neustart immer noch falsch gesetzt/angezeigt würde ich es umtauschen oder mit dem Anzeigefehler leben.
Hallo, nochmals danke für deine Hilfe. Ich bin gestern schon auf 3.00 zurück. Habe danach gebootet und ein CMOS Reset per Jumper gemacht. Spiele das Ganze aber heute Abend nochmal durch. Windows 10 habe ich auf eine neue SSD installiert. Das kann ich ausschließen. Der User aus dem AsRock Forum hat sein Board zurück geschickt und verwendet jetzt das Taichi.
Falls das alles nichts bringt, was ist dann am ehesten Schrott? Das MB oder? Weil dann würde ich das einfach umtauschen, oder gleich den RAM mit? Wobei das jetzt gestern alles mit 2933Mhz funktioniert hat. Also er hing beim Neustart nicht mehr oder ähnliches. Nur ich finde das halt echt strange, dass die Werte so komisch angezeigt werden.
Ein hervorragende Frage was da defekt ist. Ein Gedanke kam mir da gerade noch - und zwar sind Spannungen (ich hoffe ich erzähle jetzt kein Blödsinn - kenn das vom Arduino) nicht direkt messbar, sonder werden mit einer fest bekannten Referenzspannung verglichen.
Wo diese Referenzspannung her kommt kann ich nicht sagen, wenn sie aber vom Netzteil direkt genutzt wird (bspw die 3.3er) wäre das noch eine Möglichkeit - altes/defektes Netzteil?.
Vermutlich wird diese aber eher auf dem MB generiert und ich glaube nicht das AMD die Spannungsmessung in der CPU vornimmt - bin mir zu 95% sicher dass das Board misst, und dieser Teil wird wohl leider nicht richtig funktionieren (also Board tauschen).
Ebenfalls denke ich dass die Auslesefehler nichts mit deinem ursprünglichen neustart-RAM-Problem zu tun haben, Ryzen ist halt was ram angeht eine Diva.
Das ist auch der Grund warum mir das nicht so richtig schmeckt. Ich kann nicht sagen, ist etwas defekt oder halt nicht. Nachher funktioniert es eine gewisse Zeit und nachher raucht mir das Board aber so. Keine Ahnung, ob das realistisch ist. Bin jetzt nur noch innerhalb der 14 Tage. Schicke jetzt CPU, Board und RAM zurück. Bestelle nochmal neu. Frage ist dann welchen RAM?
Wenn man das so einfach beantworten könnte ^^
Mit Samsung B-dies macht man natürlich nichts verkehrt, ob dir die 2-300mhz den Aufpreis wert sind, ist die andere Frage.
Listen mit RAMs und was die können gibts ja wie Sand am mehr, aber ende braucht man auch ein wenig Glück - mit Garnierten werten ist da nicht viel, was aber nicht so schlimm - auch mit 2666Mhz und CL15 macht die Kiste Spaß (das Hauptproblem ist wie so oft dieses innere Gefühl :) )
Wenn du kannst tausch nochmal das Netzteil (nur zur Sicherheit).
Das NT kann ich mal noch austauschen. Ist zwar auch neu, aber wer weiß. Dann hab ich glaube ich aber alles andere ausgeschlossen.
Eben diese paar hundert Mhz waren mir den Aufpreis nicht wert. Könnte nochmal die Trident testen, oder Corsair Vengeance. Wenn die mit 2933 laufen oder auch 2666 ist mir das recht. Hauptsache stabil. Diese Anzeigesache nervt mich aber am meisten.
