[Sammelthread] ASRock Fatal1ty X370 Gaming K4
(lt. Berichten bereits EOL!)
- Spezifikationen:
Gaming ArmorPower
  • Hi-Density Power Connectors (24 pin and 8 pin)
Memory
  • 15μ Gold Contact in DIMM Slots
VGA Card
  • 15μ Gold Contact in VGA PCIe Slot (PCIE2)
Internet
  • Intel® LAN
Cooling
  • XXL Aluminum Alloy Heatsink
Audio
  • Creative Sound Blaster™ Cinema 3
Unique FeatureASRock USB 3.1
  • ASRock USB 3.1 Type-A Port (10 Gb/s)
  • ASRock USB 3.1 Type-C Port (10 Gb/s)
ASRock Super Alloy
  • Premium 45A Power Choke
  • Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
  • I/O Armor
  • Matte Black PCB
  • High Density Glass Fabric PCB
  • 2oz Copper PCB
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
CPU
  • Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
  • IR Digital PWM
  • 12 Power Phase design
  • Supports 95W Water Cooling
Chipset
  • AMD Promontory X370
Memory
  • Dual Channel DDR4 Memory Technology
  • 4 x DDR4 DIMM Slots
  • AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
  • AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
  • Max. capacity of system memory: 64GB**
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
  • 128Mb AMI UEFI Legal BIOS with GUI support
  • Supports "Plug and Play"
  • ACPI 5.1 compliance wake up events
  • Supports jumperfree
  • SMBIOS 2.3 support
  • CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
Graphics
  • Integrated AMD Radeon™ R-Series Graphics in A-series APU*
  • DirectX 12, Pixel Shader 5.0
  • Max. shared memory 2GB
  • Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
  • Supports HDCP with HDMI Port
  • Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
*Actual support may vary by CPU
Audio
  • 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
  • Premium Blu-ray Audio support
  • Supports Surge Protection
  • Nichicon Fine Gold Series Audio Caps
  • 120dB SNR DAC with Differential Amplifier
  • TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
  • Pure Power-In
  • Direct Drive Technology
  • PCB Isolate Shielding
  • Impedance Sensing on Line Out port
  • Individual PCB Layers for R/L Audio Channel
  • Gold Audio Jacks
  • Supports Creative Sound Blaster™ Cinema 3
LAN
  • Gigabit LAN 10/100/1000 Mb/s
  • GigaLAN Intel® I211AT
  • Supports Wake-On-LAN
  • Supports Lightning/ESD Protection
  • Supports Energy Efficient Ethernet 802.3az
  • Supports PXE
SlotsAMD Ryzen series CPUs
  • 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
AMD 7th A-Series APUs
  • 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
  • 4 x PCI Express 2.0 x1 Slots
  • Supports AMD Quad CrossFireX™ and CrossFireX™**
  • Supports NVIDIA® Quad SLI™ and SLI™**
  • 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
  • 1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
  • 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks
Connector
  • 1 x COM Port Header
  • 1 x TPM Header
  • 1 x Power LED and Speaker Header
  • 1 x AMD Fan LED Header
  • 2 x RGB LED Headers*
  • 1 x CPU Fan Connector (4-pin)**
  • 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
  • 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
  • 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
  • 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
  • 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
  • 1 x Front Panel Audio Connector
  • 1 x AMD LED Fan USB Header
  • 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
  • 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
  • 1 x Dr. Debug with LED
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
Rear Panel I/O
  • 2 x Antenna Ports
  • 1 x PS/2 Mouse Port
  • 1 x PS/2 Keyboard Port
  • 1 x HDMI Port
  • 1 x Optical SPDIF Out Port
  • 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
  • 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
  • 6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
  • 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
  • HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
Software and UEFI
Software
  • ASRock F-Stream
  • ASRock RGB LED
  • ASRock Key Master
  • ASRock APP Charger
  • ASRock XFast LAN*
UEFI
  • ASRock Full HD UEFI
  • ASRock Instant Flash
  • ASRock Internet Flash
  • ASRock Crashless BIOS
  • ASRock Easy RAID Installer
*These utilities can be downloaded from ASRock Live Update & APP Shop.
Support CD
  • Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
Accessories
  • Quick Installation Guide, Support CD, I/O Shield
  • 4 x SATA Data Cables
  • 1 x ASRock SLI_HB_Bridge_2S Card
  • 3 x Screws for M.2 Sockets
Hardware Monitor
  • Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
Form Factor
  • ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS
  • Microsoft® Windows® 10 64-bit*
*For the updated Windows® 10 driver, please visit ASRock's website for details.
Certifications
  • FCC, CE
  • ErP/EuP ready (ErP/EuP ready power supply is required)
[td]
Quelle: ASRock-Webseite
- RAM Kompatibilität:
Liste der geprüften RAM-Riegel des Herstellers
weitere KITs von Forenmitgliedern:
G.Skill Flare X 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GFX@3200Mhz (XMP-Profile)
G.Skill Trident Z 32GB Kit (16GBx2) 3200MhzF4-3200C14D-32GTZ@2933Mhz 18-16-16-16-40 1.35V
G.Skill Trident Z 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GTZ@2933Mhz (XMP-Profile)
G.Skill Trident Z 16GB Kit (8GBx2) 3600MhzF4-3600C15D-16GTZ@3200Mhz 14-14-14-14-34 1.36V
G.Skill RipJaws V 16GB Kit (8GBx2) 3600MhzF4-3600C16D-16GVK@2933Mhz 14-14-14-14-34 1.35V
Crucial Ballistix Tactical 16GB Kit (8GBx2) 2666MhzBLT2C8G4D26AFTA@2666Mhz (XMP-Profile)
Crucial Ballistix Sport LT 16GB Kit (8GBx2) 2400MhzBLS2C8G4D240FSE@2933Mhz 20-20-20-20-48 1.35V
Tipps von "paui":
CAS-Timing:
Es können nur gerade Zahlen dort eingegeben werden.
Sobald man eine 15 einstellt wird diese aufgerundet. Also entweder 14 oder 16 aber keine 15 CAS.
RAM-Stabilität:
Die SOC Spannung erhöhen z.b. auf 1,1V oder 1,2V und überall immer LLC auf Level3
Bei SingleRank Modulen den Bankgroupswap auf disabled stellen.
Die Spannung auf 1,360V für 1,352V unter Last für den ram setzen, VTT_DDR ist immer die Hälfte davon!
Als Beispiel beim G.Skill F4-3600C15D-16GTZ:
3200MHz bei 14-14-14-14-34 mit 1,36V, Bankgroupswap disabled, SOC 1,112V
(wenn es nicht läuft, dann auf 2933MHz da läuft er definitiv stabil)
- BIOS-Versionen:
BIOS-Download von der Herstellerseite
BIOS-Download (auch alte Versionen) bei Computertechnik JZelectronic
V4.70 - Enhance compatibility for Raven CPU with Intel WiFi.
V4.60 - 1.Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a. 2.Improve M.2 SSD compatibility.
V4.50 - Update AGESA for upcoming processors.
Wenn man eine Version unter V3.50 auf eine Versionen über V3.50 flashen möchte, muss man einen Zwischenschritt auf V3.50 machen!
V3.50 - Bridge BIOS
V3.40 - 1.Sync the H/W Monitor and Dr.Debug code Temp source to tCTL 2. Gray out Instant Flash when fTPM is enabled.
V3.30 - 1. With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
V3.20 - 1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. 2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
V3.10 - Add AMD PBS Primary Video Adapter to control Bristol Ridge CPU display order.
V3.00 - Update AGESA to 1.0.0.6a
V2.50 - Update AGESA to 1.0.0.6
V2.40 - Enhance OC setting for advanced Overclocker
V2.30 - Verbesserte System und Speicher Kompatibilität
V2.20 - Update AGESA Version string SummitPI-AM4 1.0.0.4a
V2.10 - Verbesserte System Kompatibilität
V2.00 - AGESA-Code aktualisiert - Verbesserung für Ryzen 5 & Precision Boost - Taktraten können jetzt in 25MHz-Schritten im BIOS-Setup eingestellt werden
V1.70 - Improve XMP DRAM compatibility & Add Simultaneous Multi-Threading(SMT) item in BIOS setup
V1.60 - Add Instant flash function & Add CPU Frequency Multiplier Change item
V1.50 - Support CPU Frequency Multiplier function
- Übertakten (CPU/RAM):
Laut dem Video von AMD sollte man bei einem Dauerbetrieb die CPU nicht über VCORE 1.425V betreiben.
Oft kann man auch lesen, dass Werte von 1.45V oder gar bis zu 1.5V ok sind. Hier sollte man aber bedenken, dass dies die Lebensdauer der CPU verkürzt werden kann.
Der SoC kann super mit 1.1V betrieben werden. Oft kann man auch lesen, dass 1.2V noch ok sind.
- Testberichte / Reviews:
Altes Startposting:
Hallo!
Sie wie es aussieht scheint kaum wer ein ASRock X370 Gaming K4 zu haben. Entsprechend spärlich sind auch die Infos, die ich bis jetzt so finden konnte...
Weiß jemand, ob die Backplate des ASRock X370 Gaming K4 verschraubt oder verklebt ist? Da ich einen Lüfter mit eigener Backplate holen möchte, wäre dies wirklich gut zu wissen.
Des weiteren wollte ich fragen, ob man bei ASRock X370 Gaming K4 im BIOS die DRAM Timings manuell einstellen kann und natürlich auch die Taktfrequenz?
Optisch und Preislich spricht mich das Mainboard sehr an, technisch kann ich leider nicht beurteilen, wobei die "Werbeaussagen" ja nicht schlecht sind.
Vielen Dank
SneakyPie
Na da bin ich gespannt und hab noch Hoffnung :)
Es existiert UEFI-Version 2.10. Bei der 2.00 steht AGESA 1.0.0.4a - stand das beim letzten Mal schon da? Bei mir steht mit Aida und HWInfo immer noch AGESA 1.0.0.3.
UEFI-Version 2.10 ist jetzt bei mir auch drauf, läuft auf den ersten Eindruck gut. RAM max immer noch 2933.
CPU Package Power im CPUID HWMonitor zeigt mir aber nur noch max 90W statt zuvor 130W an.
Mal ein paar Einstellungen testen.
Mit 2.10 weiterhin nur 2666 beim Ram, schade.
Ansonsten auch keine Veränderung bemerkt.
Die unterschiedliche Watt Angabe kommt je nach Vcore Config zustande, hatte zuvor direkt nach der Takteinstellung statt 1,1875v 1,425v eingestellt und weiter unten die Vcore auf Auto gelassen, jetzt mit dem neuen Bios oben Standard und unten dann fixed 1,425v drinne.
Das schein nicht das gleiche unter Last zu sein, warum auch immer habe ich 30Watt mehr bzw weniger durch die verschiedenen Einstellungen
Vielleicht habe ich es übersehen, aber gab es irgendwo eine Info bzgl PCIe-Lane Sharing?
Meine Grafikkarte steckt aktuell im oberen 16x Slot, außerdem ist eine M2 SSD verbaut (M2-1).
Lt. HWInfo und GPU-Z wurde die Grafikkarte auf 8x zurück gestuft. Ich sehe allerdings bisher nicht, warum das passiert.
BIOS ist das aktuelle 2.10.
nein läuft, M2-1 über der Graka hab ich eine 960Pro und im ersten PCIe x16 steckt eine 980Ti. CPU-Z 1.78.3 sagt LinkWith X16.
-AMD Chipsatz Treiber installiert?
-NVME Treiber?
-AMD Energie Profil?
ASRock X370 Gaming K4 - Wer hat es und kann Auskunft geben?
1 & 3 ja. Wollte eh im Magician nach einer Firmware für meine Evo schauen, evtl sagt er mir da auch was zum Treiber. Wenn du sagst, es geht dann schaue ich da doch nochmal genauer nach :)
Sehr schön, danke!
Edit: habe die Treiber nun mal alle installiert bzw neu installiert. Problem bleibt bestehen.
Werde jetzt die Karte auch nochmal neu installieren.
Das ASRock X370 K4 ist eines der potentiellen mobos für meinen R5 1600(X) build, daher hätte ich einige Fragen:
Hat jemand die 1600(X) auf dem mobo und wenn ja mit welchem Kühler, bei wie viel Volt und welcher Temperatur? Außerdem, wie sieht es mit RAM aus? Witzigerweise ist die QVL des X370 K4 kleiner als die des B350 K4.
Läuft auf dem mobo Ripjaws V 3200 CL16 oder LPX 3000 CL15 auf >2666 oder muss man auf ein größeres Update im Mai warten bzw. teuren b-die kaufen?
also ich kann nur von meinem G.Skill 3866er berichten der ohne Probleme bei 2933Mhz bei 14-14-14-34 @ 1.35V läuft.
3200Mhz geht zwar auch, aber bekomme ihn nicht stabil zum laufen, er erzeugt dann immer Speicherfehler im memtest, egal welche Latenzen.
nach der QVL kann man nicht nur gehen, ich bin auch nicht danach gegangen. einfach RAM gekauft und probiert und bin zufrieden.
Sehr schön, danke!
Die Lanes müsste man doch im BIOS aufteilen können?
Im BIOS finde ich gar nix dazu, im Handbuch nix was andeuten würde dass die Karte überhaupt irgendwie verlangsamt wird.
Ich habe auch mal versuchsweise Dinge abgeschaltet oder Laufwerke abgezogen, leider ohne Erfolg. Bisher leicht schräg...
Ich habe halt weder eine zweite Grafikkarte (oder sonstige Karte) im zweiten PCIe 16x Slot stecken (PCIe4), noch habe ich eine A-Serie CPU (gibt es ja noch nicht zu kaufen).
Von Asrock direkt konnte ich auch noch keine Antwort bekommen.
Glaube ich baue die CPU mal aus und schaue was passiert.
Weiß jemand warum das Asrock X370 Gaming K4 so ziemlich das einziges Board von Asrock (und auch aller restlichen Hersteller) ist, bei denen in den Spezifikationen nur eine RAM-Unterstützung von 2933+ MHz genannt wird? Alle anderen Asrock-Boards (auch die B350-Varianten) führen 3200MHz bei den Spezifikationen auf. Das wird auch bei allen anderen Herstellern als Standard in den Spezifikationen geführt. Nur beim Gaming K4 nicht.
Ich versuche mich gerade zwischen dem Gaming K4 und dem Gigabyte Aorus GA-AX370-Gaming K5 zu entscheiden. Und diese Spezifikation bei der RAM-Unterstützung ist so ziemlich das einzige, was mich beim Asrock zurückhält. Ich hatte die letzten Jahre nur Asrock-Boards und war eigentlich immer sehr zufrieden.
Das ASRock X370 Gaming K4 ist auch für PC3200 vorgesehen und läßt sich im BIOS einschalten ;)
Weißt du ob mit dem neusten Bios 2.3 das Killer SLI auch 3200 läuft ? :) BZW. ist da auch was anderes geändert worden als der AGESA code?
DDR4RAM 2x 8GB DDR4-3200 Corsair Vengeance LPX schwarz Habe ich drin.
Die G.Skill F4-3200C14D-16GTZ laufen mit dem X370 Gaming K4 (aktuelles Bios) mit dem XMP-Profil übrigens mit 3200 MHz.
Dachte das ASRock mag keine 3200Mhz? Na dann GZ.
Meine F4-3600C16D-16GVK schaffen nur 2933 Mhz.
Ich war selbst sehr überrascht. Ein Kollege von mir hat das Board und da es die F4-3200C14D-16GTZ vor einigen Wochen bei amazon.de für 125 Euro gab, hatte ich mir die schon bestellt, obwohl mir selbst noch Board und CPU fehlen. Vorgestern war ich dann zum Testen die RAMs in den PC meines Kollegen einbauen und nach Auswahl des XML-Profils, lief dann auch alles stabil und ohne Absturz auf 3200 MHz. Getestet haben wir mit Prime, Cinebench und Doom. Mein Kollege betreibt über das X370 Gaming K4 einen 1800X. Aufgrund des positiven Tests wird es bei mir jetzt auch das X370 Gaming 4 zusammen mit dem 1600X.
habt ihr das auch per memtest überprüft?
ich bekomme keine 3200Mhz stabil. weder die F4-3866C18D-16GTZ bei 14-14-14-34 noch die F4-3200C14D-16GFX bei 14-14-14-34. egal auch welche Latenzen, es kommen immer Speicherfehler heraus.
ich habe auch mit der ram Spannung rum probiert und mit der SOC Spannung die ja auch für den Speichercontroller zuständig ist.
2933Mhz laufen problemlos bei 14-14-14-34 1.35V
3200 waren bei mir bisher auch nicht stabil, allerdings even auch 32GB.
2933 läuft dagegen sauber und unauffällig mittlerweile. SOC habe ich mittlerweile mal auf 1.05V gestellt, was sowohl dem RAM als auch scheinbar der Vcore gut getan hat.
Aktuell läuft Prime mal mit custom pstates, damit ich endlich vom Ryzen Master weg komme.
Meine Corsair laufen nach wie vor leider nur mit 2666 alles andere Bootet nicht.
Ist der Speicher stabil?
Ich möchte die hier verbauen:
CMK32GX4M2B3000C15
Sollten Dual Rank sein. Wenn die auf 3000 MHz laufen sollten, würde mir das schon reichen.
Ohne das ich eine AM4-Plattform besitze, würde ich, nach allem was ich bisher gelesen habe, eher davon ausgehen, dass du Corsair Dual-Rank eher nicht auf 3000 zum laufen kriegst.
Das würde mich doch sehr, sehr wundern.
Ist ja schön, dass hier Infos zum Board zusammen laufen, aber wie wäre es statt dessen mit einem richtigen Sammelthread, in dem jemand diese auch im Startbeitrag sammelt?
Ich hab mir vor 4 Tagen mein Ryzen System zusammengebaut,
Der Pc:
Asrock Gaming K4 x370 Fatility Gaming
Be Quiet Silentloop 240
Ryzen 1700
Corsair RAM CMD16GX4M2B3000C15, Dominator Platinum 3000Mhz
Be Qiuet Pure Power L8 530 Watt
Samsung Evo Pro 840 256
WD Blue HDD 1TB
Gtx 1070 Kfa2 ex oc 2020 Mhz
Habe direkt nach dem Zusammenbau das BIOS 2.20 per USB Stick aufgespielt, was auch problemlos klappte.
Ebenso habe ich den 1700 ohne Probleme bei 1,32 Volt auf 3,7 Ghz bei Maximal 56 Grad bekommen
Mein Großes Problem:
Der Ram geht auf Maximal 2133 Mhz, egal was ich einstelle, mit oder ohne XMP, Hab schon das Video von Robert Hallock mit Tipps zu den Einstellungen gesehen und das befolgt, SOC Spannung auf 1,1 Volt, Ram auf bis zu 1,4 Volt usw...
Aber er akzeptiert absolut keinen Wert über 2133, er fällt dann in eine Restart Schleife und nach 5 Durchgängen hat sich das BIOS Resettet
Der Flare X war zu dem Zeitpunkt des Kaufs vergiffen,und da ich alles zusammen bestellen wollte griff ich zum Corsair Dominator Platinum der sogar auf Corsairs Ryzen Seite als Kompatibel betitelt wurde, und da als OC Ram der Spitzenklasse mit selektierten Chips betitelt wird, umso bitterer das er nichtmal die 2400 schafft.
Laut CPU z ist der Speicher Single rank, und laut Internet wohl mit Hynix Chips, ich reiche aber noch einen Taiphoon Burner Screenshot nach.
Bin momentan von dem Board bzw RAM sehr genervt, jemand tipps? Was habt ihr eingestellt um 3000 MHz zum laufen zu bekommen?
Laut den Usern im Computerbase Forum soll es wohl an der BIOS Version 2.20 liegen, welche BIOS Version habt ihr?
Ist bei mir das selbe, auch mit dem neuen 2.30 UEFI immernoch maximal 2666 Mhz am Ram möglich statt 3000(2933).
Habe eben auch das 2.3 installiert, weil ich gehofft habe, dass evtl. irgendwann man 3200Mhz möglich sein wird.
Aber auch diesbezüglich hat sich noch nichts getan. Oh man... ich habe zwischen dem Gigabyte Gaming B350 und dem ASRock Gaming K4 mich entscheiden müssen. Hoffentlich war es kein Fehler. :-(
EDIT:
Kann man irgendwie diesen Thread nachträglich zum Sammelthread für unser ASRock x370 Gaming K4 machen?
Evtl. den Titel noch ändern?
Ist ja jetzt mittlerweile ein Sammelthread :-)
Kann man irgendwie diesen Thread nachträglich zum Sammelthread für unser ASRock x370 Gaming K4 machen? Evtl. den Titel noch ändern?
Das obliegt dir als Threadersteller. Du kannst über das erweiterte Bearbeiten des Startbeitrags auch den Titel anpassen.
Naja, nicht wirklich. Siehe: [Übersicht] Achtung vor dem Erstellen eines Threads! + Sammelthread Guide / Liste (Upd. 09.04.17)
Bevor der Thread den Prefix Sammelthread verdient hat, sollte also erst mal der Startbeitrag entsprechend gefüllt werden.
