[Sammelthread] ASRock Fatal1ty X370 Gaming K4
(lt. Berichten bereits EOL!)
- Spezifikationen:
Gaming ArmorPower
  • Hi-Density Power Connectors (24 pin and 8 pin)
Memory
  • 15μ Gold Contact in DIMM Slots
VGA Card
  • 15μ Gold Contact in VGA PCIe Slot (PCIE2)
Internet
  • Intel® LAN
Cooling
  • XXL Aluminum Alloy Heatsink
Audio
  • Creative Sound Blaster™ Cinema 3
Unique FeatureASRock USB 3.1
  • ASRock USB 3.1 Type-A Port (10 Gb/s)
  • ASRock USB 3.1 Type-C Port (10 Gb/s)
ASRock Super Alloy
  • Premium 45A Power Choke
  • Nichicon 12K Black Caps (100% Japan made high quality conductive polymer capacitors)
  • I/O Armor
  • Matte Black PCB
  • High Density Glass Fabric PCB
  • 2oz Copper PCB
ASRock Steel Slots
ASRock Ultra M.2 (PCIe Gen3 x4 & SATA3)
ASRock Full Spike Protection (for all USB, Audio, LAN Ports)
ASRock Live Update & APP Shop
CPU
  • Supports AMD Socket AM4 A-Series APUs (Bristol Ridge) and Ryzen Series CPUs (Summit Ridge)
  • IR Digital PWM
  • 12 Power Phase design
  • Supports 95W Water Cooling
Chipset
  • AMD Promontory X370
Memory
  • Dual Channel DDR4 Memory Technology
  • 4 x DDR4 DIMM Slots
  • AMD Ryzen series CPUs support DDR4 2933+(OC)2667/2400/2133 ECC & non-ECC, un-buffered memory*
  • AMD 7th Gen A-Series APUs support DDR4 2400/2133 ECC & non-ECC, un-buffered memory*
  • Max. capacity of system memory: 64GB**
*Please refer to Memory Support List on ASRock's website for more information.
**Due to the operating system limitation, the actual memory size may be less than 4GB for the reservation for system usage under Windows® 32-bit OS. For Windows® 64-bit OS with 64-bit CPU, there is no such limitation.
BIOS
  • 128Mb AMI UEFI Legal BIOS with GUI support
  • Supports "Plug and Play"
  • ACPI 5.1 compliance wake up events
  • Supports jumperfree
  • SMBIOS 2.3 support
  • CPU, VCORE_NB, DRAM, VPPM, PCH 1.05V, +1.8V, VDDP, PROM 2.5V, Voltage Multi-adjustment
Graphics
  • Integrated AMD Radeon™ R-Series Graphics in A-series APU*
  • DirectX 12, Pixel Shader 5.0
  • Max. shared memory 2GB
  • Supports HDMI with max. resolution up to 4K x 2K (4096x2160) @ 24Hz / (3840x2160) @ 30Hz
  • Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
  • Supports HDCP with HDMI Port
  • Supports Full HD 1080p Blu-ray (BD) playback with HDMI Port
*Actual support may vary by CPU
Audio
  • 7.1 CH HD Audio with Content Protection (Realtek ALC1220 Audio Codec)
  • Premium Blu-ray Audio support
  • Supports Surge Protection
  • Nichicon Fine Gold Series Audio Caps
  • 120dB SNR DAC with Differential Amplifier
  • TI® NE5532 Premium Headset Amplifier for Front Panel Audio Connector (Supports up to 600 Ohm headsets)
  • Pure Power-In
  • Direct Drive Technology
  • PCB Isolate Shielding
  • Impedance Sensing on Line Out port
  • Individual PCB Layers for R/L Audio Channel
  • Gold Audio Jacks
  • Supports Creative Sound Blaster™ Cinema 3
LAN
  • Gigabit LAN 10/100/1000 Mb/s
  • GigaLAN Intel® I211AT
  • Supports Wake-On-LAN
  • Supports Lightning/ESD Protection
  • Supports Energy Efficient Ethernet 802.3az
  • Supports PXE
SlotsAMD Ryzen series CPUs
  • 2 x PCI Express 3.0 x16 Slots (single at x16 (PCIE2); dual at x8 (PCIE2) / x8 (PCIE4))*
AMD 7th A-Series APUs
  • 1 x PCI Express 3.0 x16 Slot (single at x8 (PCIE2))*
  • 4 x PCI Express 2.0 x1 Slots
  • Supports AMD Quad CrossFireX™ and CrossFireX™**
  • Supports NVIDIA® Quad SLI™ and SLI™**
  • 1 x M.2 Socket (Key E), supports type 2230 WiFi/BT module
*Supports NVMe SSD as boot disks
**This feature is only supported with Ryzen Series CPUs (Summit Ridge).
Storage
  • 6 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
  • 1 x Ultra M.2 Socket (M2_1), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
  • 1 x M.2 Socket (M2_2), supports M Key type 2230/2242/2260/2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen2 x2 (10 Gb/s)*
*Supports ASRock U.2 Kit Supports NVMe SSD as boot disks
Connector
  • 1 x COM Port Header
  • 1 x TPM Header
  • 1 x Power LED and Speaker Header
  • 1 x AMD Fan LED Header
  • 2 x RGB LED Headers*
  • 1 x CPU Fan Connector (4-pin)**
  • 1 x CPU Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
  • 2 x Chassis Fan Connectors (4-pin) (Smart Fan Speed Control)****
  • 1 x Chassis Optional/Water Pump Fan Connector (4-pin) (Smart Fan Speed Control)****
  • 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
  • 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
  • 1 x Front Panel Audio Connector
  • 1 x AMD LED Fan USB Header
  • 2 x USB 2.0 Headers (Support 4 USB 2.0 ports) (Supports ESD Protection)
  • 2 x USB 3.0 Headers (Support 4 USB 3.0 ports) (Supports ESD Protection)
  • 1 x Dr. Debug with LED
*Supports up to 12V/3A, 36W LED Strip
**The CPU Fan Connector supports the CPU fan of maximum 1A (12W) fan power.
***The CPU Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
****The Chassis Optional/Water Pump Fan supports the water cooler fan of maximum 1.5A (18W) fan power.
Rear Panel I/O
  • 2 x Antenna Ports
  • 1 x PS/2 Mouse Port
  • 1 x PS/2 Keyboard Port
  • 1 x HDMI Port
  • 1 x Optical SPDIF Out Port
  • 1 x USB 3.1 Type-A Port (10 Gb/s) (Supports ESD Protection)
  • 1 x USB 3.1 Type-C Port (10 Gb/s) (Supports ESD Protection)
  • 6 x USB 3.0 Ports (Supports ESD Protection)* 1 x Fatal1ty Mouse Port (USB 3.0) is included
  • 1 x RJ-45 LAN Port with LED (ACT/LINK LED and SPEED LED)
  • HD Audio Jacks: Rear Speaker / Central / Bass / Line in / Front Speaker / Microphone (Gold Audio Jacks)
Software and UEFI
Software
  • ASRock F-Stream
  • ASRock RGB LED
  • ASRock Key Master
  • ASRock APP Charger
  • ASRock XFast LAN*
UEFI
  • ASRock Full HD UEFI
  • ASRock Instant Flash
  • ASRock Internet Flash
  • ASRock Crashless BIOS
  • ASRock Easy RAID Installer
*These utilities can be downloaded from ASRock Live Update & APP Shop.
Support CD
  • Drivers, Utilities, AntiVirus Software (Trial Version), Google Chrome Browser and Toolbar
Accessories
  • Quick Installation Guide, Support CD, I/O Shield
  • 4 x SATA Data Cables
  • 1 x ASRock SLI_HB_Bridge_2S Card
  • 3 x Screws for M.2 Sockets
Hardware Monitor
  • Temperature Sensing: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Tachometer: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Quiet Fan (Auto adjust chassis fan speed by CPU temperature): CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Fan Multi-Speed Control: CPU, CPU Optional/Water Pump, Chassis, Chassis Optional/Water Pump Fans
  • Voltage monitoring: +12V, +5V, +3.3V, CPU Vcore, VCORE_NB, DRAM, PCH 1.05V, +1.8V, VDDP
Form Factor
  • ATX Form Factor: 12.0-in x 9.6-in, 30.5 cm x 24.4 cm
OS
  • Microsoft® Windows® 10 64-bit*
*For the updated Windows® 10 driver, please visit ASRock's website for details.
Certifications
  • FCC, CE
  • ErP/EuP ready (ErP/EuP ready power supply is required)
[td]
Quelle: ASRock-Webseite
- RAM Kompatibilität:
Liste der geprüften RAM-Riegel des Herstellers
weitere KITs von Forenmitgliedern:
G.Skill Flare X 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GFX@3200Mhz (XMP-Profile)
G.Skill Trident Z 32GB Kit (16GBx2) 3200MhzF4-3200C14D-32GTZ@2933Mhz 18-16-16-16-40 1.35V
G.Skill Trident Z 16GB Kit (8GBx2) 3200MhzF4-3200C14D-16GTZ@2933Mhz (XMP-Profile)
G.Skill Trident Z 16GB Kit (8GBx2) 3600MhzF4-3600C15D-16GTZ@3200Mhz 14-14-14-14-34 1.36V
G.Skill RipJaws V 16GB Kit (8GBx2) 3600MhzF4-3600C16D-16GVK@2933Mhz 14-14-14-14-34 1.35V
Crucial Ballistix Tactical 16GB Kit (8GBx2) 2666MhzBLT2C8G4D26AFTA@2666Mhz (XMP-Profile)
Crucial Ballistix Sport LT 16GB Kit (8GBx2) 2400MhzBLS2C8G4D240FSE@2933Mhz 20-20-20-20-48 1.35V
Tipps von "paui":
CAS-Timing:
Es können nur gerade Zahlen dort eingegeben werden.
Sobald man eine 15 einstellt wird diese aufgerundet. Also entweder 14 oder 16 aber keine 15 CAS.
RAM-Stabilität:
Die SOC Spannung erhöhen z.b. auf 1,1V oder 1,2V und überall immer LLC auf Level3
Bei SingleRank Modulen den Bankgroupswap auf disabled stellen.
Die Spannung auf 1,360V für 1,352V unter Last für den ram setzen, VTT_DDR ist immer die Hälfte davon!
Als Beispiel beim G.Skill F4-3600C15D-16GTZ:
3200MHz bei 14-14-14-14-34 mit 1,36V, Bankgroupswap disabled, SOC 1,112V
(wenn es nicht läuft, dann auf 2933MHz da läuft er definitiv stabil)
- BIOS-Versionen:
BIOS-Download von der Herstellerseite
BIOS-Download (auch alte Versionen) bei Computertechnik JZelectronic
V4.70 - Enhance compatibility for Raven CPU with Intel WiFi.
V4.60 - 1.Update AMD AGESA to PinnaclePI-AM4_1.0.0.1a. 2.Improve M.2 SSD compatibility.
V4.50 - Update AGESA for upcoming processors.
Wenn man eine Version unter V3.50 auf eine Versionen über V3.50 flashen möchte, muss man einen Zwischenschritt auf V3.50 machen!
V3.50 - Bridge BIOS
V3.40 - 1.Sync the H/W Monitor and Dr.Debug code Temp source to tCTL 2. Gray out Instant Flash when fTPM is enabled.
V3.30 - 1. With JEDEC 2666MHz DDR4 module, default set DDR4 frequency to 2666MHz. Test with SANMAX SMD4-U8G48MH-26VR and SMD4-U16G48MH-26VR.
V3.20 - 1.Update AGESA to 1.0.0.6b. No memory ABL(AGESA Boot Loader) or training changes. 2.Add setup options to select SMART fan temperature source. Change default to monitor external CPU temperature.
V3.10 - Add AMD PBS Primary Video Adapter to control Bristol Ridge CPU display order.
V3.00 - Update AGESA to 1.0.0.6a
V2.50 - Update AGESA to 1.0.0.6
V2.40 - Enhance OC setting for advanced Overclocker
V2.30 - Verbesserte System und Speicher Kompatibilität
V2.20 - Update AGESA Version string SummitPI-AM4 1.0.0.4a
V2.10 - Verbesserte System Kompatibilität
V2.00 - AGESA-Code aktualisiert - Verbesserung für Ryzen 5 & Precision Boost - Taktraten können jetzt in 25MHz-Schritten im BIOS-Setup eingestellt werden
V1.70 - Improve XMP DRAM compatibility & Add Simultaneous Multi-Threading(SMT) item in BIOS setup
V1.60 - Add Instant flash function & Add CPU Frequency Multiplier Change item
V1.50 - Support CPU Frequency Multiplier function
- Übertakten (CPU/RAM):
Laut dem Video von AMD sollte man bei einem Dauerbetrieb die CPU nicht über VCORE 1.425V betreiben.
Oft kann man auch lesen, dass Werte von 1.45V oder gar bis zu 1.5V ok sind. Hier sollte man aber bedenken, dass dies die Lebensdauer der CPU verkürzt werden kann.
Der SoC kann super mit 1.1V betrieben werden. Oft kann man auch lesen, dass 1.2V noch ok sind.
- Testberichte / Reviews:
Altes Startposting:
Hallo!
Sie wie es aussieht scheint kaum wer ein ASRock X370 Gaming K4 zu haben. Entsprechend spärlich sind auch die Infos, die ich bis jetzt so finden konnte...
Weiß jemand, ob die Backplate des ASRock X370 Gaming K4 verschraubt oder verklebt ist? Da ich einen Lüfter mit eigener Backplate holen möchte, wäre dies wirklich gut zu wissen.
Des weiteren wollte ich fragen, ob man bei ASRock X370 Gaming K4 im BIOS die DRAM Timings manuell einstellen kann und natürlich auch die Taktfrequenz?
Optisch und Preislich spricht mich das Mainboard sehr an, technisch kann ich leider nicht beurteilen, wobei die "Werbeaussagen" ja nicht schlecht sind.
Vielen Dank
SneakyPie
Habs mal bestellt, versandfertig in 2-5 Wochen (ist mir sogar recht)
Falls ich es nicht brauchen kann, verkauf ich es einfach ^^
@Performer danke für den Tipp!
Welche Ram Version hast du? 5.30? 5.20? 5.39?
Es läuft inzwischen alles stabil nur mit Wahl des XML Profils ohne weiteres Rumgefummel an Spannungen oder timings:
CMK16GX4M2B3200C16 Version 5.39 auf 3200 CL 16
CMK16GX4M2B3000C15 Version 5.30 auf 2933 - allerdings nur CL 16 (ungerade CL Werte gehen nicht)
Crucial Ballistix tactical 2666 (2 Ranks) laufen korrekt auf 2666
Die 3200er laufen allerdings erst richtig seit dem neuesten BIOS 2.30 vom 10.5. Beim BIOS 2.20 vom 4.5. liefen die nur einmal, aber nach nem restart kam wieder ne loop.
p.s. auf dem X370 Gaming K4 laufen die 3200er natürlich nicht - das geht nur bis 2933
Also Welche Timings komplett ? 16-16-16-16-36 ? oder was genau ? Dann müssten die bei mir doch laufen ? Hab ja auch Corsairs mit 5.30
Meine Aussage betrifft nur das Taichi. Beim X370 Gaming K4 funzen z.Zt. die Corsair noch nicht - die Crucial gehen. Timings auf dem Taichi sind 16 - 17 - 17.
Hallo Zusammen,
ich benötige einmal etwas Aufklärung und Hilfe, gerade weil Ryzen für mich neu ist bzw. diese Problematik mit den Speichern für mich komplett neu sind.
Ich verwende, logischerweise ^^, das ASrock X370 Gaming K4 mit folgenden Speichern: Corsair Vengeance LPX 16GB, DDR4-3000, CL15-17-17-35 (CMK16GX4M2B3000C15).
Seit Samstag ist das System in Betrieb, und das erste was ich nach dem 1. Start gemacht habe, ist das Bios auf 2.40 zu updaten via Bios-Internet-Updater...dingens.
Die Speicher wurden soweit von Anfang an erkannt, und wurden Automatisch glaub ich mit 21xx oder 2400 eingestellt... bin mir nicht ganz sicher.
Seit dem Update auf 2.40 konnte ich auch dass einzige XMP-Profil auswählen mit 2933 Mhz, was ich auch gemacht habe.
Nun kommt aber die Verwirrung: Im Bios & im Task Manager unter Win10 steht dass die Speicher mit 2933 eingestellt sind. Im TM mit 2934 Mhz.
Aber bei CPU-Z (Vers. 1.79.0) mit 1463.7 Mhz und bei AMD's OC-Tool (AMD Ryzen Master) steht 1467 Mhz. Ja was den nun?
Mir ist auch gerade noch aufgefallen dass der CAS-Takt anstatt mit 15 auf 16 stand, und habs gerade im Tool auf 15 geändert, Neustart gemacht
und auf einmal steht bei CPU-Z nur noch 1064.5 Mhz sowie im Default-Profil vom Tool. WTF.
Vielleicht könnt Ihr mir hier ein wenig weiterhelfen, möglichst leicht verständlich :) danke im Voraus.
EDIT: Achja im Reiter SPD bei CPU-Z, werden die Speicher auch nur als "Single"-Ranks eingetragen.
Da nur 2 Module eben Auf A2 und B2 eingebaut, also DUAL-Channel was auch im Reiter Memory steht.
DDR bedeutet "Double-Data-Rate" womit pro Takt nicht nur einer sondern zwei Datenbit verarbeitet werden. Daher muss man die Mhz-Zahl aus CPU-Z einfach verdoppeln, um den effektiven Takt zu erhalten.
1466,5 Mhz x 2 entspricht 2933 Mhz
@ALL
Ich habe jetzt hier ein Sammelthread draus gemacht :-)
Hab jetzt auch bei Amazon zugeschlagen. Mal schauen ob es durchgeht. :)
So wie ich das sehe seid ihr ja hier in der Regel mit dem Mainboard zufrieden (wenn man mal von den RAM Schwierigkeiten absieht, die wohl nahezu jedes Mainboard betreffen), oder?
Achsooo.. aber warum dann nur so halbe Angaben die einen Verwirren?
Ich gehe / ging davon aus dass die Speicher nur noch mit 1463,7 Mhz laufen wie auf dem folgenden Scree unten zu sehen.
Gut der CAS ist zwar mit 1 Clock höher als er eig. sein müsste, aber macht das einen großen Unterschied? Weil im BIOS stehts richtig drin wie man im Link sehen kann.
Aus dem BIOS:
Dropbox - Ryzen
(Leider sieht man auf dem 2. Bild die Timings nicht richtig, aber Rechts bei 16 steht halt die 15. - man man Ranzoom sieht man sie ein wenig schimmern ^^)
Bis auf der CAS stimmen die Timings sonst wie sie beworben werden.
Nochmal ne ergänzende Frage zu meinem Post von 14:02:
Sollte ich 2933 und die Timings manuell einstellen oder das XMP-Profil verwenden?
Habe nämlich gerade noch in Videos gehört dass die XMP-Profile nicht funktionieren sollen etc.?
Mit dem aktuellen BIOS 2.40 muss man erst XMP aktivieren, damit man dann Takt & Timings selbst einstellen kann.
Würde bisher auch empfehlen es selbst zu wählen statt die Vorgabewerte zu nutzen.
Alle Boards haben ihre RAM-Probleme. Das ASRock X370 ist da aber momentan noch etwas nerviger, weil es die 3200Mhz wirklich noch etwas seltener zulässt. Aber das sind halt die "normalen" Probleme. Ansonsten kann ich nichts negatives über das Board berichten. Seit ich es habe, gab es keine weiteren Probleme.
Evtl. etwas viele BIOS-Updates... aber dass ist ja schon fast wieder gut :-)
Wenn nach dem Umstellen das Booten bzw POST recht lange gedauert hat, wurden deine Einstellungen als nicht brauchbar / bootbar erkannt und auf Standardwerte zurückgesetzt.
Das Board startet dann 4 (oder 5?) mal neu (Fehlercode F9) , wenn es den RAM dann nicht richtig initialisiert bekommt, wird ein 0815-Standardprofil gesetzt, mit dem recht sicher starten kann, in dem Fall dann 2133 Mhz.
Grundsätzlich lese ich mit AIDA64 oder HWInfo64 aus, CPU-Z zeigt zu grossen Teilen noch ne Menge Schrott.
Das ist ja das Ding, er macht keine mehrfachen Neustarts etc.
Es dauert beim Kaltstart (wenn komplett Heruntergefahren) ca. 10-12 Sekunden bis mein DVI-Monitor anspringt und das ASrock-Logo zeigt. (Mein HDMI-Monitor geht erst beim Windows-Start an)
Gerade eben habe ich einen Kaltstart entsprechend gemacht, also komplett aus dann wieder an und direkt ins Bios, und wie man sehen kann:
Sind alle Einstellungen behalten worden.
Mit diesem Bild werde ich Begrüßt: https://abload.de/img/whatsappimage2017-05k5uhu.jpeg
Und 2933 Mhz bleiben auch eingestellt: https://abload.de/img/whatsappimage2017-05u4uyy.jpeg (keine Ahnung warum man die rechten Spalten so schlecht sehen kann)
aber man sieht hier ja 15 - 17 - 17 - 35. Umstellen tut er also nichts zurück auf den Standard-Takt oder eben 2133 Mhz. Er bleibt bei 2933 Mhz.
HWinfo sagt das hier: Und Aida64 sagt:
ALLERDINGS steht wenn ich auf "Mainboard" klicke bei Speicherbus-Eigenschaften, Tatsächlicher Takt: 1467 MHz (DDR) // Effektiver Takt: 2933 MHz:
Habe dann eben nen Bench der Speicher gemacht, und das war das Ergebnis:
Warum ich so viel Frage ist halt logisch, damit ich es zukünftig besser Nachvollziehen kann (und von Intel gewohnt bin dass auch immer der exakte Speed angezeigt wurde),
und ob nun BIOS recht hat und der Task Manager, oder der Tatsächliche Takt sogar unter 2000 Mhz liegt und entsprechend auch die Leistung falsch ist was mir Aida, CPU, AMDs Tool & HWinfo da ausgibt.
Und dann ist die Frage, wenn es so ist, wie kann ich es beheben. Dass keine vollen 3000 unterstützt werden weiß ich, aber ASrock sagt ja selber dass dann auf 2933 Mhz getaktet wird.
Die Geschwindigkeit des DDR-Speichers ist bei AMD und INTEL identisch, da es eine Eigenart des RAM-Speichers ist und nicht der CPU.
Also auch der "INTEL"-Speicher mit 2400Mhz taktet in Wirklichkeit mit 1200Mhz (x2). Natürlich gibt es kein "INTEL"-Speicher, da die RAM-Module in der Regel auf beiden Plattformen laufen.
Ja das... meinte ich damit nicht Sneaky ;) ... sondern dass ich bisher einfach keine Probleme hatte.
Sprich wenn ich 2,6er oder 2,8er ... oder eben 3000 MHz Speicher eingebaut hatte, wurden diese auch überall so übernommen und auch angezeigt.
Das es keine reinen Speicher von Intel oder AMD gibt, ist mir klar. --- Nur eben jetzt bei Ryzen bin ich so konfus, ich weiß halt nicht was gerade Sache ist.
Es bringt mir halt nichts 3000er Speicher einzubauen wenn diese mit unter 2000 dauerhaft laufen, wie mir besagte Tools anzeigen.
Und ich möchte halt wissen ob irgendwo ein Fehler meinerseits vorliegt oder ob zb. BIOS & der Task Manager richtig anzeigen, aber alle anderen Programme ggf. falsche Werte.
Aber selbst wenn es falsche sind, warum zeigt dann selbst AMDs Ryzen Master ebenfalls im Schieberegler maximal 1600 an was man einstellen kann.
Klar 2x 1600 = 3200 ... aber warum so kompliziert.
Bei meiner Freundin werden komischerweise auch nur 800 Mhz angezeigt unter Windows, obwohl es 1666 Mhz speicher sind, sie hat aber nen AM3 Board.
Du hast dir da deine Antwort schon selbst gegeben - da liegt kein Fehler deinerseits vor, ist ne reine Interpretationssache, beide Anzeigemöglichkeiten sind richtig. Man muss halt nur wissen, wo / wann man den angezeigten Wert halbieren bzw verdoppeln muss. Ist keine schöne Sache, weil es einfach gern für Verwirrung sorgt. Wäre schön, wenn sich da alle mal auf einen Wert einigen könnten. Aber das wird nicht passieren , denke ich.
Aber es läuft schon alles so bei dir, wie es soll, keine Sorge. Würde der RAM nur mit halbem Takt laufen, würden einige Tools irgendwas um die 733Mhz rauswerfen. Und die anderen eben das doppelte davon.
(Hab btw auch gerade mal probiert - seit einem der letzten BIOS-Updates scheint das Board nicht 4 oder 5 mal mit falschen Timings / Frequenzen zu starten sondern schmeisst direkt beim ersten Fehler mal "sichere" Werte rein.)
Viele Tools haben auch noch richtig Probleme, was vernünftiges auszulesen - ob nun CPU-Z 2.6V Vcore anzeigt, AIDA64 (bei mir jetzt gerade mit dem Beta-Update, wie ich vor 5 min festgestellt habe) die RAM-Timings falsch anzeigt oder oder oder... Ich denke mal, es wird noch die eine oder andere Woche ins Land gehen, bis da salles passt. HWInfo64 scheint mir da bis jetzt am weitesten zu sein.
Ich habe zwischenzeitlich noch weiter mit dem "G.Skill F4-3200C14D-32GTZ" rumprobiert.
2933 war ja mit CL18 möglich, als Radical_53 meinte 3200 gingen bei ihm (semi stabil) mußte ich das auch nochmal probieren.
3200 habe ich zwar mit CL20-18-18-44 zum laufen bekommen, aber auch nicht 100% stabil. Irgendwann gabs dann doch einzelne Fehler beim memtest.
Hier mußte ich aber auch die SOC Spannung ordentlich erhöhen, damit es überhaupt halbwegs ging.
Was Performancesteigerungen angeht, ich hab mal ein wenig verglichen zwischen: 2666 CL14-14-14-34, 2933 CL18-16-16-40, 3200 CL20-18-18-44
Allerdings konnte ich in Firestrike, GTAIV, Witcher3, XPlane11 erstmal keinen Framezuwachs bei höherem Takt feststellen.
Da kann man jetzt spekulieren warum da nix vom Takt mehr rumkommt, oder welche Benchmarks evtl besser geeignet sind etc.
Mal noch was anderes, ist es eigentlich normal, daß bei X370 Boards SATA Platten / SSDs als Wechsellaufwerke erkannt werden ? ^^
Windows 10 Pro (1703) erkennt zumindest meine internen SATA Laufwerke alle 3 als "tragbare Geräte". Tauchen entsprechend in der USB Auswurfliste auf und im Explorer doppelt...
Gibts überhaupt nen eigenen Treiber dafür oder muss man mit den MS Standardtreibern arbeiten ?
Also sind diese ganze Werte doch richtig... nur mussten diese x2 genommen werden? ... grummel.
Dann ist ja doch alles in der Form richtig und ich muss keine neuen Speicher holen... danke für diese aufklärenden Worte.
Warum man in der Tat nicht einfach gleich den richtigen Wert angibt, verstehe ich auch nicht.
Ja ist mir auch schon aufgefallen... dass unten in der Taskleiste, beim Aufklappbaren Pfeil das Symbol für "Hardware sicher Entfernen und Medium auswerfen"
meine Festplatten angezeigt werden. Oder eben auch das im Explorer:
Warum tauchen da auf einmal 2 meiner Platten auf und dann auch noch verkehrt herum und wie kann ich die ausblenden bzw. wenigstens die Anordnung ändern?
Amazon hat storniert, was auch zu erwarten war. Nun gut, bleibe ich vorerst noch beim 2500K...
Hier ebenfalls.
Nun auch in den Übersichten verlinkt. Verschoben ins Sammelthread Unterforum wird dann je nach Aktivität des Threads.
Vielleicht könnten diese Speicher mit aufgenommen werden:
Crucial Ballistix Tactical DIMM Kit 16GB, DDR4-2666, CL16-17-17 (BLT2C8G4D26AFTA)
Die funktionieren auf dem Board. Zumindest bei mir und ohne Anstrengungen - nur mit XMP Profil Laden.
p.s. Amazon liefert das Brett nicht zu dem Preis - hab eben ne mail bekommen (hatte mir ein 2. bestellt)
Das hat es bei mir bisher noch nie gemacht, was den Speicher angeht.
Entweder es startet oder ich darf einen CMOS Clear machen.
Also wenn das alles wie oben so stimmt bezüglich meiner Sorge bzw. weil ich so verwundert war,
dann können meine Speicher auch mit aufgenommen werden. CMK16GX4M2B3000
Mit BIOS 2.40 konnte ich das XMP-Profil auswählen (2933 Mhz) und wurden auch so übernommen. Stehen nur auf der QVL leider (noch) nicht bei ASrock.
Bis auf der CAS-Timing welcher mit 16 angegeben wurde, habe ich im BIOS auf 15 geändert und sonst nichts zum Speicher.
