[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Das musst du selbst austesten...... SPi 32M / Memtest ect.
Wär toll wenn du das Ergebnis dann noch >hier< postest.
Hab auch XPG G v2.0, aber meine laufen bei 2000MHz mit 9-9-9-24-1T. Werkseinstellung.
Bootvorgang beschleunigen
Moin,
ich würde gerne bei mir den Bootvorgang etwas beschleunigen. Der kommt mir bei diesem Brett doch sehr langwierig vor. Ich habe das mal mit einer Stoppuhr nachgemessen:
00.00: Startknopf gedrückt
15.43: BIOS-OK-BEEP
21.46: Seltsame Meldung kommt^^
24.30: Seltsame Meldung geht
29.25: Windows wird gestartet.
Also über 15 Sekunden bis zum Piep finde ich allein schon unglaublich. Hat einer eine Ahnung, welche Bioseinstellung ich da ändern muss um da nen flotteren Start zu bekommen?
Dann noch die bebilderte Meldung hätte ich gerne komplett weg. Keine Ahnung, was mir das sagen soll.
Ingesamt also fast 30 Sekunden bis Windows überhaupt erst bootet (was erwartungsgemäß sehr schnell geht). Da lässt sich doch bestimmt was machen oder?
Bitte verkleinere das Bild, dies ist zu groß. Maximal 900x900px bei maximal 400KB.
Sorry, hab nicht aufgepasst.
sieht aus wie dein dvd laufwerk.... wo is das denn angesteckt?
ansonsten alle nicht genutzten controller im bios deaktivieren, zb fire wire
Ja das ist das DVD-Laufwerk. Ich habe gerade "nochmal" die neueste Firmware aufgespielt. Jetzt ist die Meldung verschwunden (obwohls die gleiche Version ist). Naja nun habe ich ein paar Sekündchen dadurch eingespart, aber was ist mit den 15 Sekunden vor dem BEEP? Ich habe vorhin mal im BIOS rumgefummelt (übrigens Ver. 1102) und ATA und ROG Connect deaktiviert. Firewire habe ich schon vorneherein deaktiviert. Weiß noch jemand Rat?
So habe ich gemacht und nun? Sind immer noch etwas mehr als 15 Sekunden.
Ohja hätte ich erwähnen sollen.^^ Ich habe 1304 aufgespielt. Bei dem neuen schreckt mich die Warnmeldung ab.
Ja Bilder kann ich nachher machen. Dauert noch etwas.
Ja geht in Ordnung. Welche Menüpunkte wären Dir denn besonders wichtig?
Das ist der JMB363, steck das mal an einen der ROTEN S-ATA's. :d Dann verschwindet auch der "komische Bildschirm"
Servus, hat von euch einer nen SLI am laufen auf dem Board? Geht das mit dem Patch mittlerweile gut oder nicht?
Martin
Naja durch das Firmwareupdate ist der ja nun verschwunden, bzw. er sieht nun etwas anders. Nur eine wirklich kurze (<1 sec.) Info. Sonst läuft das Laufwerk ja tadellos. Was würde es denn sonst noch bringen, das Laufwerk über nen normalen SATA-Port laufen zu lassen?
Wie gesagt, die Meldung, von der du sprachst, würde verschwinden. Es käme dann "No Devices found" und es ginge weiter.
Das ist auch keine Fehlermeldung. Er zeigt dir nur an, welches Laufwerk er erkannt hat. :d
Ja ist mir schon klar. es hat mich halt nur genervt, dass das da solange stand. naja ist ja nun gut so.
Wielange dauert es bei euch denn so vom Powerknopf bis BIOS-Beep?
Ein Speaker zählt für mich mit zu den wichtigsten Bauteilen eines Rechners.^^
Ist der peep lang oder kurz?
Was zeigen deine kontroll LEDs an beim booten? ( die roten leds beim atx stecker)
MfG
Sent from my MB525 using Tapatalk
Ein ganz normaler kurzer beep der mir sagt, dass mein System in Ordnung ist. Die roten LED werden auch ganz normal durchgekaut.
jo aber auf dem board is keiner verbaut und in meim case ebensowenig.... und ich kauf mir nu nich extra so ein dingens, ich merk doch wenn irgendwa snich ok is, zb an den led's...
Jo da muss ich smokey zustimmen ich schaue auch auf die leds die ja reichlich vorhanden sind ;-) ein peep habe ich auch noch nicht gehabt. Den bootvorgang stoppe ich mal.
Ich bin halt noch ein Bastler der alten Schule. Ich habe schon an Rechnern herum gebastelt, da wurden der CPU noch ausschließlich passiv gekühlt (wenn überhaupt)^^. Für mich gehört da halt einfach ein Speaker rein.
jo, is ja auch kein ding..... aber wenn de zb beim ocn bist und aller paar mins neu startest, geht dir der beep irgendwann aufn :grrr:
Also ich finde den Beep immer zutiefst beruhigend :)
