[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Ja. Meiner war bei 3,84GHz noch ohne Erhöhung stabil.
€dit: Die hohe Spannung brauch ich weil mein Coolermaster V8 'ne Niete im Kühlen ist.
Mit welcher Version von Prime testet Ihr? Hab zzt. die 26.2....sollte ic besser wieder zur 2511 wechseln?
linx scheint bei mir irgendwie nicht zu laufen....steht nur eleapsed Time und wenn ich nach 10 min auf stop drücke läuft er munter weiter....aber er lastet die cpu gar nicht aus....oder liegt es an den einstellungen?
kA, mach mal 'nen Screen. ;)
Ich benutz Prime95 25.11 x64
Noch eine Frage....wie habt Ihr im Bios (Bios 1304) die PWR Frequenz eingestellt? Ich hab die auf Auto gelassen, da ich damit nichts anfangen kann. Die kann man ansonsten von 200-500Mhz einstellen....
LInx läuft jetzt auch wieder seit 8 min....keine Änderung
Sorry, geändert....Bios 1304 sollte es sein....war noch bei Bios 1202....
Bios 1302?? Das gibts doch gar nicht, welches meinst du?
Ich benutze prime 25.11
@flayers
Bei wieviel mhz läuft deine nb frequency
Für 3,6ghz läuft meiner bei negativen offsets
Sent from my MB525 using Tapatalk
cpu/nb und HT laufen auf 2000Mhz....
von wann ist Deine CPU?
bei 3400Mhz und -offset von 0,0125V läuft auch alles rund...nichts stürzt ab....und ab 3,6Ghz....tja....bisher kein stabiles setting gefunden.....
So. ich verabschiede mich bis Freitag morgen...die Arbeit ruft....Danke
Ich habe eine der ersten CPU's als der x6 rauskam gleich bestellt:wink:
War ein umstieg von Intel auf AMD und bin begeisert.
Poste mal ein Screen vom bios dann schauen wir mal drüber :d
Viel Spass bei der Arbeit
MfG
Das ist ja ziemlicher Kappes, den LinX da macht. Sind die Ram's stabil? darin kann der Fehler auch liegen.
kommt man vom 3012er bios wieder aufs 1304er zurück ? hat schon jemand erfahrungen gemacht, wie mit dem neuen bios das cpu und ram ocing sich verändert, möglicherweise verbessert ?
ja, mache gleich mal Fotos von meinen Bios Einstellungen.
@CH4F Rams sollten stabil sein..1.läuft ja alles galtt bei 3400Mhz und 2. habe ich sie ja auch mit 1333Mhz undCR2 laufen gehabt und trotzdem diese Probs.
EDIT: Hier die Bilder von meinen Bioseinstellungen
Hast du mal statt Offset mit Manual versucht?
Du meinst die Spannung dirkt eingeben, bzw ohne offset zu arbeiten....bei diesem Board noch nie...beim CH III hab ich das so gemacht + LLC on bin damit gut gefahren....
man hat mir dann nur mal gesagt, dass dass mit offset anscheinend besser funktionieren würde.....
Achsoo, aber wenns mit Offset nicht geht, solltest du es mal mit Manual versuchen.
Wie laufen denn Deine A-Data....bekommst Du auch 1T hin?
Und kannst Du mir eventuell die ganaue Bezeichnung nennen?
Sind ja ähnlich günstig wie die G.Skill und ich denke unter dem Heatspreder ist der gleiche Hersteller :)
Also bisher läuft mein PC mit +0.05V offset bei 18x200....irgendwie verursacht die neue Primevesion Fehler mit dem 25.11 läuft das Ding bis jetzt....
Und was macht dein Linx??
Hängt es immernoch beim Testen??
MfG:wink:
Meine A-Datas heißen AX3U2000GB2G9-DG2
Bei 1T Muss ich Spannung leicht anheben.
Also es sind die mit 2000MHz mit 9-9-9-24 und 2T
@ flayer,
es ist der bessere kompromiss, da für die hardware schonender, wenn du die llc auf 50 % stellst und die grund vcore im bios etwas höher, da ein leichter vdrop nach unten besser ist, als die peaks nach oben, bei 100%
die ocp geschichten kannst du rein machen, weil sie deine hardware schützen und wenn überhaupt, nur hardcore - ln kühlungsbenutzer behindern.
sind 1,6 vdimm oder 1,65 vdimm standard für deine rams ? da mal manuell einstellen und nicht auf auto lassen.
du kannst mal bei ai overclocktuner (müsste da gewesen sein..) auf d.o.c.p. schalten und auf 1600er ram schalten. dann von hand die 4 haupttimings und evtl command rate einstellen, wie sie auf deinen rams angegeben sind.
unten die beiden spread spectrum dinger ausschalten.
Ich dachte das wären alles Basics, die man wissen sollte...
oh mist, d.h. ich muß wieder alles neu ausprobieren mit 50%..llc.....
die Rams sind normalerweise für 1,5V ausgelegt....9-9-9-24 Cr stellt er automatich auf 1T
ich hab das so verstanden, das man besser die OCP ausläßt, weil sie gerade den Schutz ausschalten, wenn sie aktiv sind....daher sind sie bei mir deaktiviert.
EDIT: So, hab diese D.O.C.P. gestellt, die timings manuel eingestellt. LLC auf 50% offset +0.05...Extreme OC deaktiviert. die Spreads deaktiviert....prime jetzt mal...
Und wie ist das Ergebnis?
€dit -> bei 3,75GHz Brauch ich unter 1,325v unter Last. hab einfach im Bios 1,3 und weiter runter hab ich ned gemacht.
äh, ich bin immer noch in der offset einstellung.....vergessen auf manuel zu stellen....rest wie oben geschrieben... die opc auch aktiviert. unter last bei Prime mit 3,6Ghz zzt. 1,316-1,336....linx klappt immer noch nicht...prime zeigt bisher keinen Fehler....
Dann ist er doch gar nich so 'ne Krücke. Obwohl 1,3 für 3,6GHz dann aber auch normal sind, denke ich.
wenn er so läuft, ok....wird wohl der Altag zeigen, ob er noch mucken macht....wenn er jetzt ohne Probs die nächsten Tage läuft, setzt ich mal die CPU/NB hoch
Morgen...so, bis jetzt ist er durchgelaufen ohne irgendwelche mucken :)
hoffe das bleibt so....
So, als nächstes bleibt noch die Frage für den Speicher....
bin vor kurzem auf diesen hier umgestiegen.
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL9-9-9-24 (DDR3-1600) (F3-12800CL9D-8GBXL) | Geizhals.at Deutschland
würde mir aber gerne ein Kit von denen hier zu legen
G.Skill RipJaws-X DIMM Kit 8GB PC3-12800U CL7-8-7-24 (DDR3-1600) (F3-12800CL7D-8GBXH) | Geizhals.at Deutschland
oder
G.Skill RipJaws-X DIMM Kit 8GB PC3-14900U CL9-9-9-24 (DDR3-1866) (F3-14900CL9D-8GBXLD) | Geizhals.at Deutschland
wobei ich eher zu den ersteren tendiere.....
Natürlich sag ich auch nicht nein zu dem Kit, was CH4F verwendet....
So....wünsch Euch nen schönen Samstag, bin jetzt erstmal auf Fahrertraining :)
Wenn ich meinen Kit unter Vollbestückung auf 1600Mhz laufen lasse, komm ich auf 6-7-6-16-1T bei 1,65v (stabil, nicht only 4 show :d). Aber wenn du einen der 3 nimmst, nimm den 1600er mit 7-8-7-24. ;) Ich bleib aber lieber beim 2000er Setting mit 9-9-9-24, das ist im Endeffekt flotter.
ne, ich glaube, ich werd die A-Data nehmen :) wenn die bei 1600 mit 1T laufen ist das prima....in der liste werden die allerdings mit 9-11-9-27 angegeben....
