[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
ja eben, unter volllast..... also kann doch im idle so wenig wie möglich sein, ich brauchs doch nur unter last 100% stable....
Du hast mich angespornt zu testen. ;)
Bios 1902: Vcore: 1.3718 V
Idle: Cpu Vcore
CPU LLC 100%: 1.376 ~ 1.382 V mit droop
CPU LLC 50%: 1.356 ~ 1.363 V mit droop
Also arbeitet LLC auch im Idle und kommt im Full (100%) an die im Bios
eingestellte 1.372V nahe. Unter Last werde ich noch testen.
Das ganze scheint mit dem letzten Bios verbessert worden zu sein, da
kein großes übervolten auffällt wie in den früheren Bios Versionen.
Hiermal ein Vergleich unter Vollast... :bigok:
Vcore: 1.3718 V
CPU LLC: 50% : 1.336V ~ 1.343V starkes Undervolten
CPU LLC: 100% : 1.409 *1.415V starkes Übervolten
Meiner Meinung nach arbeitet LLC weiterhin nicht ganz richtig.Zumindest
unter Vollast, wofür sie ja eigentlich gedacht und entwickelt worden ist. :shake:
Da stellt sich bei mir die Frage ob es nicht Sinn macht LLC ganz zu
deaktivieren? OK im Idle arbeitet es sauber, aber unter Vollast muß man
dann entweder mit zu wenig oder zu viel Spannung leben. :rolleyes:
MfG
also ich hab im bios 1,2375 eingestellt und komm unter volllast bis auf 1,27.... find ich eigentlich ganz ok bzw im rahmen...
bin am Überlegen mir dieses Board zu kaufen.
für was genau wird der SATA vom JMicron® JMB363 gebraucht?
Bringt der irgendwas? (soweit ich das sehe soll da ja das DVD Laufwerk angeschlossen werden, kann man dann davon booten? braucht das einen extra Treiber und ist der SATA hotplugfähig?)
würde ansonsten meine externe Festplatte die ich nur ab und zu für Backups benötige und mit normalem SATA nach außen geführt ist da anhängen oder eben das DVD Laufwerk bzw. gibt es ein eSATA auf SATA Kabel und funktioniert das einwandfrei?
Sata Belegung wäre dann:
1: SSD
2: F4
3: F3
4: F3
5: F1 (Spiegelung von der SSD)
6: DVD
Kann man eigentlich auch nur bestimmte SATA Stecker für Raid 1 nutzen und den Rest als AHCI? oder geht nur entweder oder?
Da kannst Du ganz normal booten und benötigst keine Extratreiber.
Wenn ich mal bedenke dass Bios 1902 schon am 17.2. fertig war...
...Da bleib ich lieber beim neueren Bios.
habe hier noch eine Creative Sound Blaster X-Fi Titanium Fatal1ty Pro Series, PCIe herumliegen.
Zahlt sich der Einbau aus oder ist die onboard-Lösung ziemlich gleichwertig?
was ich noch wissen wollte bevor ich das Board kaufe: kann ich den CPU Lüfter in % automatisch zwischen 2 Werten regeln lassen? 70-100% wäre für die H70.
Also der Onboardsound ist schon für mein Befinden ziemlich hochwertig. Weiß ja nicht wie empfindlich Dein Gehör ist und Deine Soundkarte kenne ich leider nicht. Ich würde sie erstmal nicht einbauen und dann beurteilen. Dann ziehste auch nicht so viel Saft aus der Dose.
Das Board liefert das TOOL AI Suite, bzw. EPU mit. Damit kannste die Lüftersteuerung automatisieren und eigene Werte eintragen. Aber die Lüfteranschlüsse sind alle 4pinnig. Kannste also alles automatisch regeln lassen.
Die Onboard-Lösung ist nur eine Software-Lösung , in Sachen X-FI...
Hab auch noch eine X-Fi Titanium Fatal1ty aus der Champion Series eingebaut...
es ist schon noch ein unterschied....
Hab sie übrigens ganz unten im letzten Slot stecken...
funktioniert tadellos...
Ich habe grad bei mir mal die 3,6 laufen... Bei 1.25v (Last) unter linx :fresse: Unter linx gönnt der sich mehr Spannung wie unter Prime.
Jo nicht nur mehr Spannung, auch
deutlich mehr an Stromverbrauch
Bei benches mit linx.
Hier mal ein Vergleich:
Prime Large: ca. 301 watt ( 4000Mhz)
Linx: ca. 340 Watt (4000Mhz)
Klar unter Last und gemessen mit
Tchibo Strommessgerät.
Gruss
Sent from my iPhone using Hardwareluxx app
irgendwie ist das komisch:
wenn ich die 510 ohne AHCI Treiber von AMD betreibe ist sie recht flink (415 read, 215 write).
sobald ich jedoch die AMD Treiber installiere fällt das ganze auf 300 read und 100 write.
habt ihr ähnliche Erfahrungen gemacht? bzw. bringt der Treiber sonst etwas?
welche von den ganzen anderen Asus Tools braucht man eigentlich sonst wirklich noch?
das meiste davon finde ich ja eher unnötig.
Bei mir ist es so:
Ich betreibe eine Crucial c300 64GB
ohne AHCI Treiber (im IDE Modus) habe ich : Read: 311MB/sec
mit MS AHCI Treiber(in Windows enthalten : Read: 355MB/sec
mit AMD AHCI Treiber : Read: 379MB/sec
der AHCI Treiber bringt außerdem "HotPlug"
dann sollen die Zugriffsbefehle so umsortiert werden, das sie in der optimalen Reihenfolge ausgeführt werden.Dadurch sol sich der Datendurchsatz verbessern...
Spürbar soll es hauptsächlich bei mehreren parallel arbeitenden Programmen mit vielen verstreuten Zugriffen sein...
In Sachen Tools...
Ich habe sie einfach alle installiert....
habe sie dann aber aus dem Autostart herausgenommen (mit Autoruns)...
falls ich die mal brauche kann ich sie ja dann manuell starten...
Bei mir ist es so:
Das heißt nicht hot plug, sondern native command queueing. Auch als NCQ bekannt. ;)
Hot plug ist wenn man im laufenden Betrieb Festplatten z.B. ein-/ausbauen kann UND diese von Windows auch korrekt erkannt werden . Im Endeffekt wie usb.
früher auch als plug&pray bekannt... ;)
...und man betet, dass es funktionierte ;)
weil ich ja mit meinen 56 Jahren total verkalkt bin, weiß ich zumindest wo ich suchen muß
Toms Hardware schreibt
Darüber hinaus ist mit AHCI auch problemlos der Betrieb anderer Geräte als Festplatten, also etwa DVD-Laufwerken, via Serial ATA möglich. Auch ist Serial ATA Hot-Plugging erst mit AHCI möglich. Windows XP unterstützt AHCI ab Service Pack 2; doch erst in Windows Vista ist die Unterstützung unseres Wissens wirklich problemlos.
nachzulesen hier
nichts für ungut...
@CH4F
Du kannst mich ja ruhig belehren...denn ich weiß bestimmt nicht alles...
aber dann auch nur wenn Du es wirklich besser weißt...
Du hattest hotplug mit ncq verwechselt.
CH4F hatte völlig recht. Das was Du beschrieben hast (von wegen optimale reihenfolge und datendurchsatz verbessert) ist tatsächlich NCQ, nicht Hotplug(ging). AHCI bringt auch Hotplug mit, das ist auch richtig. AHCI bringt nämlich beides mit.
Ich will da nicht streiten...
aber
zuerst habe ich geschrieben...
das ist dann eben "hot plugging"
und der nächste Satz heißt dann
Erst das wäre dann NCQ...
folglich waren dort beide Änderungen ,die AHCI mit sich bringt , von mir beschrieben...
Warum dann so viel Gift??...
war doch genauso wie zuletzt morbidmorgis sagt, von mir geschrieben...
Das sah so wie in einem Satz aus, als ob das mit dem Daten umsortieren sich auf HotPlug beziehen würde. Verzeih bitte.
nu ja , zugegeben,
war ja auch etwas blöd geschrieben...
ein Bindewort mit dem Namen
"und"
hätte das klarer erscheinen lassen...
"und" hätte ja auch nicht zu Missverständnissen geführt
Ja das wäre vielleicht hilfreich gewesen. Seis drum, wir wissen ja nun alle Bescheid :).
gibts mittlerweile was komfortableres als den phenom msr tweaker? der nervt ein wenig.
je nach bios einstellung muss ich das was ich bios-seitig addiere, beim tweaker wieder abziehn.
k10stat find ich recht schwach. gibts noch was?
jemand infos zu den bulldozern parat? datum oder so?
overdrive ist mir bekannt und taugt mir absolut nicht.
die letzte version ist immer noch die vom 1.7.2010.
