[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Das Board hat aber dennoch integriertes IDE, es ist nur kein Anschluss verbaut.
Wird wohl wie beim IV sein.
Beim IVer hab' ich das aber nicht gesehen, dass da noch ATA Channel 0 und 1 stand. Hast du vllt. mal 'nen Screenshot?
Weiß jemand von euch ob dieser Speicher auf dem Board läuft? Weil laut der Herstellerseite ist der Speicher für Intel optimiert.
Hardwareluxx - Preisvergleich
Ah das hört sich doch super an :) danke für die schnelle Antwort. Darf ich fragen was du für einen CPU Kühler drauf hast? Weiß nicht ob das mit dem Lüfter von meine CPU Kühler und der Speicher höhe klappt.
Hab auch welche für Intel optimierte drin. Läuft alles super.
wie kann es sein das von heut auf morgen das lan nich mehr geht, alles probiert scho treiber neu, windoof repair, systemwiederherstellung, dann im bios gschaut, ka es geht nich mehr.
Neues BIOS für ASUS Craosshair IV Formula -> 2002 vom 10.10.2011
ftp://ftp.asus.com.tw/pub/ASUS/mb/socketAM3/Crosshair_IV_Formula/
Auch schon auf der Homepage bei Asus eingetragen:
ASUSTeK Computer Inc. - Motherboards- ASUS Crosshair IV Formula
Crosshair IV Formula 2002 BIOS
1. Improve memory compatibility
2. Improve system stability
3. Support new CPUs. Please refer to our website at: ASUSTeK Computer Inc. -Support- CPU Support
grEEtz
fuzzy
Cool nach langer Zeit wieder ein Update. ;) "Support new CPU's" vielleicht der BD. :d
Schade das kein neuer Chipsatztreiber von Asus veröffentlicht wird, hab schon den von der AMD Seite genommen, weil der mir auf der HP von Asus einfach zu alt geworden ist.
Support new CPU's bezieht sich auf den PII x4 980 - Das mit improved System Stability gefällt mir. Hat schon einer OC-Erfahrungen?
Option "Improve system stability"
@CH4F
Wo hast du die Option ""Improve system stability"" gefunden?
Ich habe jetzt auch das CHIVF auf's 2002 geflasht, kann die Option aber nicht finden. :coolblue:
oki doki
fuzzy
Könntest du den bitte verlinken oder irgendwo hochladen? Danke
@CH4F
oki doki
fuzzy
:eek:
OmG "Improve System Stability" heißt nichts anderes als, das die System Stabilität verbessert wurde. :fresse: ;)
Das kannst du auch nicht im Bios finden, das wirst wohl nur spüren, wenn dein System besser läuft. :d
Aber nur wenn du mir deine deutsche Wetter Datei (ini) fürs Rainmeter zukommen läasst. :d ;)
So Bitte sehr, hier bekommst die SB und AHCI Treiber für unseren Chipsatz SB850:
Chipsatztreiber - PCTreiber.Net
MfG
Edit: Vergiss aber nicht, zuerst die alten vom System zu entfernen/ deinstallieren. ;)
nächste woche kommt eh ne neuen syshdd, werd da dann die neuen treiber reinmachen
Wann brauch ich eigentlich den RAID treiber?
Hat denn bereits einer das neue Bios drauf geflasht, was könnt ihr so berichten? Oder seid ihr alle mit eurem 1902 noch so zufrieden?! :d
Man muss dazu nun sagen, dass 1902 wirklich gut ist. :d
Man braucht schlicht und ergreifend weniger vCore im Hochfrequenzbereich ab 4Ghz.
Da gib ich dir recht, hab bisher kein Reboot, nichts mit gehabt, null Probz @3.8Ghz. :d Aber denke das das neue Bios auch einiges kann, weils ja lange kein Update kam. ;) Wurd bestimmt weiter entwickelt, und auf den BD angepasst?!
Aber bin erst mal froh das Board behalten zu haben, weil wenn ich die Benchmarks und Stromverbrauch vom BD sehe,:motz: bin ich mit meinem X6 1090 mehr als zufrieden und noch sehr gut mit bedient. :d
Wieviel vCore brauchst du für 3,8 @ Prime? Bei 3,7 bin ich genau auf meiner 1,3v VID @Prime. :fresse2:
3,8 Entsprächen ca. 1,325-1,332v @ Prime bei mir grob geschätzt.
Ich test das aber eben nochmal nach. xD
