[Sammelthread] Asus Crosshair IV Formula (AMD 890FX) [3]
Spezifikationen Spezifikationen
CPU
  • AMD Socket AM3 ;Phenom™II /Athlon™II /Sempron™ 100 Series Processors
  • AMD 140W CPU Support
  • AMD Cool 'n' Quiet™ Technology
  • Supports 45nm CPU
AMD Chipset
  • Northbridge:
    - AMD 890FX chipset
  • Southbridge:
    - AMD SB850
Memory
  • 4 x DIMM, Max. 16 GB, DDR3 2000(O.C.)/1800(O.C.)/1600(O.C.)/1333/1066 ECC,Non-ECC,Un-buffered Memory
    - Dual Channel memory architecture
Expansion Slots
  • 3 x PCIe 2.0 x16 ( dual @ x16, triple @x16 x8 x8 )
  • 1 x PCIe 2.0 x4
  • 2 x PCI 2.2
Multi-GPU Support
  • Support ATI CrossFire™X Technology graphics cards
Storage
  • SB850 Chipset
    - 6 xSATA 6.0 Gb/s ports Support RAID 0,1,5,10
  • JMicron® JMB363 PATA and SATA controller
    - 1 x SATA 3Gb/s port (Black)
    - 1 x External power SATA 3Gb/s port on rear (SATA On-the-Go)
Audio
  • SupremeFX X-Fi built-in 8-Channel High Definition Audio CODEC
    - EAX® Advanced™ HD 4.0
    - X-Fi CMSS®-3D
    - X-Fi Crystalizer™
    - Creative ALchemy
    - Supports Blu-ray audio layer content protection
    - Supports 1 Optical S/PDIF out port at back I/O
    - Supports 1 x S/PDIF out header
    - Supports Jack-detection, Multi-streaming, Front Panel Jack-retasking
LAN
  • Marvell 8059 Gigabit LAN controller
Internal I/O Connectors
  • 3 x USB 2.0 connectors supports additional 5 USB 2.0 ports
  • 6 x SATA 6Gb/s connectors (Red)
  • 1 x SATA 3Gb/s connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 7 x ProbeIt measurement points
  • 3 x Thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x SPDIF_out connector
  • 1 x 24-pin ATX power connector
  • 1 x 8-pin ATX 12V power connector
  • 1 x En/Dis-able Clr CMOS switch
  • 1 x Core unlocker switch
  • 1 x Turbo key II switch
  • 1 x Power on switch
  • 1 x Reset switch
  • 1 x OC Station Header
  • 1 x Go Button
  • System panel connector
Back Panel I/O Ports
  • 1 x External SATA
  • 1 x S/PDIF Out (Optical)
  • 1 x IEEE 1394a
  • 1 x LAN(RJ45) port
  • 8 -Channel Audio I/O
  • 1 x PS/2 Keyboard port(purple)
  • 2 x USB 3.0/2.0 ports
  • 7 x USB 2.0/1.1 ports (1 port is also for ROG Connect)
  • 1 x ROG Connect On/Off switch
  • 1 x Clr CMOS switch
Special Features
  • Turbo Key II
  • Core Unlocker
  • ASUS Q-Connector
  • ASUS Q-Shield
  • ASUS Q-Fan 2
  • ASUS EZ Flash 2
  • ASUS CrashFree BIOS 3
  • ASUS MyLogo 3
Accessories
  • User's manual
  • 1 x I/O Shield
  • 1 x ROG Connect Cable
  • 1 x 2-in-1 ASUS Q-Connector Kit
  • 1 x 2-in-1 SATA 6.0Gb/s Cables
  • 2 x 2-in-1 SATA 3.0Gb/s Signal Cables
  • 1 x 2-port USB2.0 + ESATA Module
  • 1 x Crossfire Cable
  • 1 x Cable Ties Pack
  • 1 x ROG Theme Label
  • 1 x 12-in-1 ROG Cable Label
BilderBilder
Das Mainboard
(Quelle: AwardFabrik.de)
Die Verpackung und das Zubehör
Das BiosDas Bios
(Quelle: AwardFabrik.de)​
DownloadsDownloads
Bios Downloads
  • Bios 0505
    - First release Bios
  • Bios 0602
    - Update strings "CPB Control" to "AMD Turbo CORE technology" in BIOS.
  • Bios 0701
    - Improve the stability of certain hard drives.
  • Bios 0707 (BETA)
    - Enable SATA down mode support to fix the Samsung SATA2 HDD issue.
    - Enhance gaming performance.
    - Enable the support of DDRIII-2000 under full 4 DIMM configuration when using Thuban processor.
    - Enhance SATA6G performance
    - Enable fix CPU multiplier for 6-core processor when disabling [Cool and Quiet] in BIOS.
  • Bios 0801
    - Improve memory compatibility
  • Bios 0905 (BETA)
    - Fixed CPU/NB Voltage setting may be not be retained after pressing the reset button under OS.
    - Enable support of CPU ratio control for 6 core Thuban processor via OC Station
    - Enable ROG Connect and OC Station support under high HT Frequency.
    - Enable the support of CPU Level Up function for Phenom II X4 965
    - Enable the display of DRAM 1st Information and DRAM 2nd Information for the ease of DRAM Timing control
  • Bios 1005
    - Improve system stability
  • Bios 1102
    - Support new CPUs
    Das flashen geschieht auf eigene Gefahr!
WasserkühlerWasserkühler
Wenn du damit übertakten willst, immer.
deswegen überlege ich mir den wechsel ja. und für 99.-€ kann man da wohl nicht ganz so viel verkehrt machen, denke ich.
Auf jeden Fall.
Für 100€ würd ichs nochmal kaufen. :fresse2:
gut, dann wird es gekauft. mal sehen was machbar ist.und grad dann noch gesehen, dass des ja eh alles über Alternate läuft. Echte Schlingel sind des aber. ;-)
Dat kann ich nicht sagen O:-)
Du wirst halt wie oben schon erwähnt gute und stabile OC Ergebnisse erreichen und gute Ausstattung haste auch drauf.
MfG
wie sieht es denn mit dem Bulldozer aus? Ist der später funktionistüchtig? falls mal ein update rauskommen sollte.
Das Board hatte ich ja schonmal, kennen tu ich es ja schon ;). Damals hatte ich aber das problem, das die HP ziemlich warm war, so, das ich mir fast die Finger verbrannt hätte. Gleich wieder zurück geschickt und den Crosshair 3 geholt.
Werde es mir aber wieder holen, um nur zu sehen, ob die Wakü die ich von Liquid Extasy habe, drauf passt oder nicht.
Ich sag -> passt nich.
Ich bin, unerwarteterweise, an ein Crosshair V Formula gekommen. Was meint ihr, lohnt der Tausch? Was könnte man noch für das CHIV bekommen?
Wenn du früher oder später oder überhaupt auf BD umsteigst dann ja ;-)
Hast es Günstig bekommen ?
und für das cf4 bekommst wenns gut läft max. 100€
MfG
Das gabs ja erst vor kurzem neu für knapp 100€. Ich behalte meins als 2.Rechner. Verschenken will ich es nicht.
Hm, ok, also laut geizhals fängt das CHIV bei 120€ an und dann aufwärts... D.h., gebraucht könnte man wohl so 70-90€ bekommen?
Ja, hab' das CHV günstig bekommen, daher stehe ich nun vor der Wahl. ^^
Hm, grade festgestellt, dass der Mugen 2 aufgrund der Backplate gar nicht kompatibel mit dem Crosshair V Formula ist (2 Chips blockieren die Backplate). Ist der Mugen 3 kompatibel?
Nimm doch die Backplate vom Boxedkühler.
Könnte man machen, hatte ich auch schon dran gedacht, da müsste man allerdings die Löcher aufbohren... :/
Kann mir jemand sagen, warum da ATA-Channel 0 und 1 angezeigt werden? Das Board hat doch nichtmal IDE Anschlüsse. ^^
Doch, tun sie, habe extra im BIOS nachgeguckt... Sonst würde Windows doch auch gar nicht starten, oder? Hab' Windows nämlich im SATA / AHCI Modus installiert.
Hast du den aktuellen AHCI Treiber von AMD installiert?
Windows 7 hat mit dem Booten keine Probleme mehr. Unter XP war das noch anders...
---------- Beitrag hinzugefügt um 16:56 ---------- Vorheriger Beitrag war um 16:53 ----------
Bei mir sieht es so aus:
Ja, stimmt, so sah es bei mir mit dem Crosshair IV auch aus... Jetzt beim Crosshair V sieht's halt wie oben auf dem Screen aus. Neuester AMD SATA Treiber ist intsalliert und auch der neueste Asmedia SATA Treiber.
Ja, klar, die alten Treiber habe ich deinstalliert vorher. (Du beziehst dich doch jetzt auf die AMD-Treiber, oder?)
Yopp :)
(Aber auch wenn nicht, sollte Win7 trotzdem keine Probs haben. Nur muss man eben beim Boardwechsel manche Treiber nachinstallieren, was du ja gemacht hast. )
Ne, stimmt schon, Win7 macht keine Probleme, aber würd' das halt trotzdem gerne "weg"haben, falls es nicht so gehört. ^^
