[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
hi, ich muss mir n neuen ram kaufen will wieder 8gb nutzen und was würdet ihr empfehlen, vor allem was hat es mit ddr3 1866 und 2000 auf sich? wo ist der unterschied zum 1666 weil soweit ich weiss hat ne amd cpu immer 1333 gebraucht oder hat sich da was geändert
Der Unterschied ist nur der höhere Takt. Einen spürbaren Unterschied wirst du unter Windows kaum merken.
Ob die CPU dann den hohen Takt packt ist wieder eine andere Frage. Im Prinzip kannst du dir 1600 Ram kaufen und versuchen diesen hochzutakten.
ok und für dieses board welcher ram is empfehlbar
Die Wahl des RAM ist eigentlich fast egal beim CHVF. Empfehlen könnte man da bestimmt einige, die frage wäre eher was bist du bereit auszugeben.
Würde dir dann die Crucial Ballistix Tactical 1866 CL9 1.5v (40 Euro) empfehlen. Habe ich selbst auch im Einsatz. Wenn sie inzwischen keine andere Chips verbauen kannst du diese auch gut übertakten (Je nachdem was deine CPU zulässt). Meine laufen auf 2000 CL9-9-9 bei 1.5v
Und welche hast nun gekauft ;)
Solltest du sie auch mal übertakten, bin ich gespannt was deine schaffen :)
@Reous
Hab eben festgestellt das ich auch den Bug hab, dass beim drücken vom Gehäuse Reset Taster die MemOK Funktion kommt also bist nicht alleine ;)
Gut zu wissen. Hatte schon ein wenig Angst dass irgendwas defekt ist.
Was mich zur Zeit ärgert ist das sie für kein Board ein neues Bios rausbringen. Die schlafen wohl zur Zeit alle bei Asus...? Bin schon am überlegen ob ich das Z wieder verkaufe, denn momentan lohnt es sich nicht für mich.
Edit: Ok gestern ist endlich doch eine neue Bios Version erschienen: 0704 Improve system stability.
Kannst du mal testen ob der Bug damit weg ist und ob sich im allgemeinen was verändert hat?
Der Bug ist damit nicht weg aber an der Spannungsversorgung haben sie wohl gedreht ^^ mehr ist mir noch nicht aufgefallen
Was ich mich grad Frage. Was passiert eigentlich, wenn man dien MemOK Button drückt? Glaube bei mir ist damals gar nichts passiert?
Was wurde an der Spannungsversorgung geändert. Mehr Auswahl, stabiler?
Würde ja selbst testen aber dann müsste ich wieder alles aufbauen :d
Na ich finde sie stabiler aber große Änderungen sind mir nicht aufgefallen wobei ich ja zuvor die Beta drauf hatte ^^
Allerdings musste ich kein Bios reset machen nach dem Update, was sonst immer standart war ^^
Die I Rog firmware wurde auch upgedatet
Schon erstaunlich das nicht mehr das Z haben. Woran das wohl liegen mag?
Denke der übertriebene Preis schreckt die meisten ab.
Kann gut möglich sein, zumal es ja kaum wichtige änderungen zum normalen gibt. Wenn ich nicht schon genug Boards hätte, würde ich es mir vielleicht auch holen.
Also der memOK Button funktioniert bei mir , allerdings hab ich jetzt schon den 2. Tag das Problem das der Rechner Morgens nicht starten will erst nach einem Resett startet er und läuft dann normal auch mit der memok Taste startet er, nur directkey und normaler Start wollen nicht, da ist er nach 2 Sec wieder aus .
Zu sehr übertaktet oder auch ein Bug?
Sieht mir eher nach nem Bug aus hatte das beim normalen V auch mal aber nur nach einem neuen uefi nach dem Reset war das Problem immer weg das Interessante ist, dass er es nur Morgens macht beim ersten Start, danach lauft er ohne Probleme auch aus- und einschalten ist kein Problem.:wut:
zumal am OC kanns nicht liegen die cpu lauft seit Februar mit dem Takt
Also ich nicht, bin derzeit mit dem 1503 sehr zufrieden.
ich eben auch nicht, wollte auf erfahrungen warten.
ist ein update überhaupt nötig, wenn alles gut läuft?
denke mal, eher nein.
Nein muss man nicht. Ich habe auch keine Lust, ständig meine Profile neu einzustellen und diese zu Speichern, daher werde ich auch nicht wechseln.
Das 1605 läuft genauso gut/schlecht wie das 1503. Flashen ist also nicht nötig. Verwende das Board zwar nur für Testzwecke aber spürbare oder optische unterschiede habe ich keine festgestellt.
