[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Das "Z" hat mehr Sata Anschlüsse, kein PCI nur PCIe , es besitzt eine LED Debug Anzeige
Extreme Engine DIGI + II - neue MOSFET-ICs und DIGI + VRM Speicherchip
LN2 Modus-Schalter
BIOS Flashback
Leicht verändertes PCB-Layout
10 SATA 6Gbps-Ports: 8 intern, 2 eSATA
Fast Boot Schalter speziell für Win8
TB_Header
SupremeFX III
kein PCI-Steckplatz
Überarbeitete Southbridge Kühlkörper
GameFirst II
evtl hilft dir das weiter Crosshair V Formula-Z - Republic of Gamers
oder das CrossHair V Formula-Z (TweakTown) - Page 4
Also nix was der normaluser wirklich braucht.
Gesendet von meinem GT-I9000 mit der Hardwareluxx App
Normal ist relatif ;) der "normal" User kauft Kein Bord für 200€ oder 250 € das Cosshair V bzw das Z sind auch keine Bords für " Normal User " außer man muss unbedingt Geld loswerden .
Stimmt auch wieder ich hatte bisher alle Bretter aus dieser Serie und es gibt bestimmt 1000 Boards die auch gereicht hätten und weniger als die Hälfte gekostet haben.
Hallo, hab da mal ne frage wegen timings verändern? Kann mir jemand mal beschreiben wie ich das mache ? Hab das noch nie gemacht?
LN2 Modus-Schalter
BIOS Flashback
TB_Header
SupremeFX III
kein PCI-Steckplatz
GameFirst II
Danke für die Anwort.....muß man also nicht unbedingt haben :d
Mein ASUS Crosshair V hat Extreme Engine DIGI +.Wenn ich lese "Extreme Engine DIGI + II - neue MOSFET-ICs und DIGI + VRM Speicherchip" scheint ASUS was an der Spannungsversorgung gemacht zu haben.Könnte vielleicht entscheident sein bei den Dingen(Overclocking) die du vor hast. ;)
Hmm wenn man nicht übertaktet, frage ich mich wozu man dann solch ein Brett hat?
Weils mir gefallen hat und weil ich das Gefühl hatte, das nach dem Einbau mein Penis etwas länger wurde!
..........ne, Scherz beiseite, ich dachte, das ich schnell auf nen 8 Kern Buli umsteige. Der Gedanke sich ja aber erstaml in Rauch aufgelöst.
Zudem mag ich die quietschbunten Boards nicht mehr so und Militarylook ist auch nicht unbedingt meins.
Auserdem war ich schon immer etwas anders, als die breite Masse und sowas muß man ja auch in der Hardware zeigen.
Ich glaube auch, das ich der einzige hier im Forum bin, der noch einen NB TwinTec Kühler am laufen hat :fresse2:
P.S. ich habe heute den 1100T übertaktet, auf 3,5 Ghz, mußte ja mal schauen, was das neu aufgespielte Bios macht.......sollte Alibi genug sein :d
Jo Gut erklärt, da gibts keine weiteren Einwände von meiner Seite aus. Und ganz unter uns, ich nutze in meinem Surf System ja auch ein Crosshair IV Formula ;)
Mein Motto ist, einmal dem R.O.G. Virus verfallen ist, wird sich nur schwer wieder für etwas anderes begeistern.
Ich hoffe ja bald in den Genuss zu kommen, das C5F-Z testen zu dürfen. Mal sehen in wie weit es sich zum normalen verhält.
Ich musste heut feststellen, das 1301 BIOS ist für OC völlig ungeeignet. Habe jetzt mal auf das 1503 gewechselt.
Hat denn hier wer gleiche Feststellungen machen können?
Hatte auch das Gefühl dass es mit dem 1301 schlechter ging. Besonders viel hab ich aber auch nicht getestet.
Ich hatte Probleme RAM jenseits über 2400 MHz Stabil zu bekommen, mit dem neusten ging es jetzt aber.
Hast du zufällig Tridendx Ram. Wenn ja bekommst du den bei 1300+ stabil. Mit dem 1503 ist das bei mir noch nicht möglich.
Das Formula-Z ist zwar optisch etwas aufgemotzt aber für Ram OC ist es momentan auch nicht zu gebrauchen. Nur am rumzicken :(
Nein ich habe zur Zeit ADATA XPG™ Gaming v2.0 Series DDR3 2400MHz RAM. Bin mit dem aber nur bis 1300 gekommen und das auch nur um mal kurz nen AIDA Bench zu machen. Stabil hatte ich die bei 1282 MHz.
@ Reous, ich vermute mal du hast schon das Formula-Z?
Jop habe es gestern bekommen. Empfehlen würde ich es aber niemanden.
Geht jetzt ein Lichtstreifen durch das Board.
Oben:
Unten:
Kann ich mir eigentlich gar nicht vorstellen das es so schlecht sein soll. Wenn ich mir die Neuerungen so ansehe, müsste es doch eigentlich besser sein?
Jedoch könnte ich ja jetzt hier ein anderes ASUS Board präsentieren, das sehr gut für OC geeignet ist und dazu auch noch günstiger ist :d
Also ich würde auch nicht sagen das es besser ist als das Normale aber auch nicht unbedingt schlechter^^ es ist anders
Ich kann da leider noch nicht mitreden aber ich hoffe das ändert sich in nächster Zeit.
@Netboy.
Hast du auch den Bug, dass beim drücken vom Gehäuse Reset Taster die MemOK Funktion ausgeführt wird. Also alle oc Einstellung wieder auf Standard zurück gesetzt?
Der Reset Taster auf dem Board funktioniert komischerweise.
nein nicht das ich wüste welches bios hast du ? Allerdings hab ich leichte Spannungsschwankungen zb. ram 1,508 last 1,501 ohne Last eingestellt sind 1,510 gleiches bei der vcore
Solche Ram Schwankungen habe ich bei der Softwareauslese auch immer. Messe ich mit dem Multimeter nach ist die Spannung aber stabil.
Hab aktuell das 40x Bios. Das Beta ist noch wirklich Beta. Komme damit teilweise nicht ins Bios, einige Rams funktionieren nicht, schlecht für oc,...
Denke mal das Board wird sich erst ab Bios 90x lohnen. War beim normalen Crosshair auch ähnlich :)
Naja von dem Normalen hatte ich 3 Stück in 3 monaten von daher kann das Z nur besser werden ^^ wobei ich das mit dem Bios auch so sehe, momentan hab ich die Beta drauf .
was mich eher stört ist das mein wasserkühler vom normalen nicht auf das z passt ^^
Nett :). Hast du mal getestet wie hoch du mit deiner CPU/NB Takt kommst bei ca 1.45v Spannung?
Nein habe ich noch nie getestet da ich auch nicht so viel Spannung ansetze.
