[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
CPU ist der Sensor auf dem Bord.
Das andere sind die Temperaturwerte in der CPU selbst, aber die kannst du vergessen bei den FX Cpu´s sind die Sensoren alle defekt
CPU - Sensoren bei ALLEN FXes defekt?
Woher hast du die "sichere" Information dass bei den FX - CPUs ALLE Sensoren defekt sind? Beweis, Link? ;)
Deiner Aussage nach ALLE Buldozer und Visheras? Das würde mich aber wundern! :confused: :grrr:
Hat jemand anderes die gleichen Informationen oder kann das bestätigen? :shake:
grEEtz :coffee:
fuzzy
Defekt ist vielleicht der falsche Ausdruck. Verwende ich aber selbst auch :d. Die Werte werden nur falsch ausgelesen. Je höher die Kerntemps steigen, desto genauer werden sie wieder. Als Richtwert bleibt aber eben nur die Mainobard CPU Temp.
grEEtz :coffee:
fuzzy
Vielleicht erinnerste Dich an die Athlon 64 X2 in 65nm - bei denen waren bei allen (!) die Sensoren auch nicht funktionstüchtig. Idletemps von teilweise 10 Grad unter der Raumtemperatur wurden da angezeigt. Soll wohl bei den Bulldozern/Visheras auch so sein.
Ich hab noch von keiner Bulldozer/Vishera CPU gehört, gelesen oder eine gesehen, bei der die Temperatursensoren richtige Werte ausgeben!
Und da sie numal dafür gedacht sind, ist das für mich ein defekt ;)
Besonders gespannt waren wir bei Bulldozer außerdem auf die Umsetzung der Temperatursensoren, denn diese gaben bei den Vorgängergeneration in Form des Athlon II und Phenom II stets Anlass zur Kritik und auch Llano macht es hier nicht besser. Insofern war unsere Hoffnung groß, dass AMD die Probleme gelöst hat und vielleicht gar für jeden Kern separate Werte ausgibt. Doch leider muss man Stand heute festhalten, dass wiederum keine Software in der Lage ist, die Temperaturen auch nur annähernd richtig auszulesen. Erneut wird nur ein Wert für alle Module/ Kerne ausgegeben, und dieser liegt im Idle bei unserem Testsample bei gerade einmal bei wenigen Grad. Hoffnung auf Besserung haben wir dabei keine, denn auch AMDs eigenes Overdrive-Tool liest unrealistische Werte aus. Schade, dass es AMD noch immer nicht für notwendig erachtet, eine Lösung für dieses Problem anzubieten.
AMD FX-8150 - Bulldozer im ausführlichen Test - Takt, Temperaturen & Spannungen (Seite 22) - HT4U.net
Neues Bios behebt einen weiteren Reset Bug. ==>Siehe Punkt 1<==
ist es normal, dass beim diesem board die HDDled ständig blinkt. die tut das im sekundenrythmus.
da mich das genervt hat hat, und m.m. nach unnormal ist, hab ich das asus M4A785TD-V EVO eingebaut, und die HDDaktivität ist wieder im normalen rahmen.
habe schon in einem anderen board gefragt, einige sagen, das ist normal, andere ist nicht normal, ist auch meine ansicht, aber lösung gabs keine.
hab schon das aktuelle bios drauf, andere HDD versucht usw.-es blinkt.
PS: ist das ohne Z
Ist nicht normal, bei mir blinkt nix ständig.
Kann ich dir aus der ferne nicht sagen.
Liegt es vielleicht auch nur an Windows? Mal im Taskmanager geschaut ob ein Programm aktiver als normal ist?
hätte mich auch sehr gewundert.
aber warum, was kann das sein?
Hast du mal unter -> Computer/auf dem Desktop -> Laufwerke -> die Eigenschaften der einzelnen LWs kontrolliert?
Evtl. wird eines z.B. LW C: bereinigt, oder die Option für LW komprimieren, oder Zulassen dass für Dateien ...... sind aktiviert.
Womöglich auch irgendein Partitionierungs- oder Formatierungs-Tool im Hintergrund aktiv.
Hast du vielleicht Acronis True Image drauf das dann inkrementelle Sicherungen schreibt o. ä.?
Es gibt so viele Möglichkeiten, es ist schwierig genau zu lokalisieren wer dieses Blinken verursacht.
good luck :coffee:
fuzzy
Die PC Zusammenbauer - und Supporterliste
AMD OverDrive zegt mir für jeden Kern eigene Temps und ASUS AI Suite zeigt aber nur die von CPU ganz und die ist meistens 10°C höher
Ich habe selber das Crosshair V zuhause und aktuell ein H80 verbaut.
Ich überlege aber ob ich wieder zurück zu einem reinen Luftkühler wechsel. Leider habe ich nur einen Prolimatech Black Series Megahalems, der aber nicht vertikal eingebaut werden kann wie hier:
http://homepage.ntlworld.com/pauld.dalton/tj073.jpg
Das Problem ist die Halterung die mit dem Kühler vom MB kollidiert. Habt ihr eine Kühlerempfehlung für mich?
Warum kannst du den nicht so wie auf dem Bild einbauen und warum willst du die H80 wieder raus nehmen?
Wenn ich mich nicht völlig irre passt das mit der halterung nicht. Kann aber auch sein das ich mich damit vertan habe.
Ich meine das die haltung vom cpu kühler mit dem kühlblock vom mb kollidiert.
Also mein Prolimatech ist auf nem Crosshair IV drauf (Siehe Signatur AMD Sys) und dort habe ich keine Probleme. Auch alle andere Kühler die ich je auf meinem Crosshair V drauf hatte, konnte ich normal montieren, ohne Probleme zu bekommen.
P.s. wenn man nen Prolimatech auf nem AMD Sys drauf machen will, muss man sich nur das Retention Modul dazu kaufen, jedenfalls musste ich es damals kaufen.
Nabend
Wie läuft den bei euch das Formula-Z so? Habs mir eben Spontan bestellt.
Den ganzen Winter hab ich mich beim oc geärgert weil(Fxa ud3 1.0 ohne llc), da musste ich jetzt in die vollen gehn.
Ab 4,2 -4,3 Ghz war immer Feierabend oder mehr halt mit viel zuviel Vcore. Ich freue mich alleine schon aufs UEFI.
Hoffe doch es wird dann besser laufen.
Gruss
Ich bin einst von einem Fxa ud5 auf das Crosshair V und dann auf das "Z" umgestiegen. Die Gigabyte Bord´s und die Croshair V Bord´s sind Welten ;)du wirst es lieben :bigok:
Was ist an dem Z denn anders. Das sich der Umstieg von dem normalen lohnt?
Gesendet von meinem GT-N7000 mit der Hardwareluxx App
Unter normalen Umständen lohnt der Umstieg nicht, aber ich hatte 4 Normale in 7 Wochen da war meine Schmerzgrenze erreicht ;) Drauf hin dann das Z, läuft jetzt seit Oktober.
Kann man sagen, dass es sowas ist wie eine neue revesion?
Läuft das board besser als das normale.
Wenn das normale läuft, nehmen sich die beiden nicht viel würd ich sagen
Dem kann ich mich nur anschließen. Habe zwar sie zwar nur für CPU und RAM OC genutzt aber sind praktisch identlich.
Moins,
bevor ich jetzt hier 21 Seiten lese, kann mir wer auf die Schnelle einen leistungsfähigen leisen und nach Möglichkeit günstigen Kühler für das Crosshair Formula V empfehlen? Wollte grad nen Macho 120 draufbauen. Der passt nicht. :( Ich brauch nämlich kurzfristig einen, mein Hauptsystem hat sich zerlegt und ich habe bis auf einen Kühler alles zusammen für ein neues System. Dreck halt, das der Kühler nicht passt :(
Prozzessor ist erst einmal ein Phenom II X6 1075T
