[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Bei mir brauchte getgoods auch 1 Woche um auf eine Email zu antworten. Lass ihnen also noch ein wenig Zeit.
Ob es auch direkt über Asus geht ist mir nicht bekannt aber wenn ja würde ich es lassen. Meist dauert es länger und du musst die Versandkosten selbst tragen.
Danke für die Antwort. Dann warte ich noch ein bisschen ab. Noch läuft das System einigermaßen stabil.
Moin Leute,
will mir auch ein ASUS Crosshair V Formula bestellen. Welchen Speicher sollte ich dazu nehmen denke da so an 8 oder sogar 16 GB Speicher nur ist die Frage wie zickig ist das Board bei Speicher. Möchte keine Benchmarkrekorde aufstellen OC ja für CPU und Speicher aber nichts extremes.
Wer kann also "stabilen" Speicher empfehelen?
Meiner Erfahrung her ist das Board nicht besonders zickig was Speicher anbelangt. Mit GSkill, Crucial oder TeamGroup solltest du auf der sicheren Seite sein.
Empfohlene Speicher [DDR3RAM]
Dem kann ich nur beipflichten.
Einsetzen kannst du aber auch Kingston! Siehe meine Sig. (16GB/4*4GB)
PnP | Kingston
PnP - 8GB Kit* (2x4GB) - DDR3 1866MHz CL11 DIMM
Part Number: KHX1866C11D3P1K2/8G
Specs: DDR3, 1866MHz, CL11, 1.5V, Unbuffered, Spec Sheet PDF: http://www.kingston.com/datasheets/KHX1866C9D3K2_8GX.pdf
Timings: 1866MHz, 11-11-11, 1.5V
Frohe Pfingsten @ all
:coffee:
fuzzy
Na das klingt ja schon mal sehr gut und wenn ich 16 GB nehme lieber auf 2x8 Riegel setzen oder 4x4?
Wenn du später erweitern möchtest auf 4*8GB -> klar 2*8GB
Wenn dir 16GB reichen und nicht nachgerüstet werden wird -> 4*4GB
Vergleiche mal die Preise für 2*4GB x 2 Kits = 16GB gegenüber 2*8GB x 1 Kit = 16GB
Vielleicht fällt dir die Entscheidung dann etwas leichter. :)
oki doki :coffee:
fuzzy
Mh ja Preise vergleichen ist schon klar aber gerade bei Speicher gibbet so viele Parameter......ehrlich gesagt da ich mich nur alle 4-5 Jahre dazu bewege meinen PC aufzurüsten(außer Graka vielleicht) bin ich mittlerweile echt raus aus dem ganzen HW Gewusel.
Normal würde ich zu 16 GB(2x8) tendieren wird wohl von der Menge her reichen und soll so um die 100€ kosten. Denke an max 1866 Mhz Speed mehr macht wohl wenig Sinn.
Laufen wird auf dem Board auch zunächst noch mein alter PII und wenn man so glaubt das AMD wohl noch einen neuen Prozzi für AM3+ anbieten wird im nächsten Jahr hat der Sockel auch noch etwas Zukunft.
Ich hab hier ein Athlon II X2 260 bei den ich keine 1600 bzw 800MHz beim RAM einstellen kann, da startet er nicht. Board ist ein Asus Crosshair V Formula. Ist sowas bekannt oder kann ich das irgendwie mit ner Spannung beheben?
Wenn er bei 1333 startet würde ich einfach mal behaupten der imc ist am Ende.
wäre die erste CPU die ich habe/hatte die bei 1600 schon ihr limit erreicht hätte
also ich habe auch 1866 drin
8GB-Kit G.Skill Sniper PC3-14900U CL9-10-9-28
sind ihn der liste von asus drin
. die sind am Anfang auch nur mit 1600 erkannt worden . nicht mal die Einstellung wo er die Timing selber erkennt hat gestimmt , nachdem ich die Timing manuell eingegeben hatte war erst alles ok .
die RAM die ich vorher hatte 2000 damit habe ich nur Probleme gehabt und die wollten einfach nicht höher als 1600 und da gab es auch ab und zu ein Bluescreen irgendwann hatte ich einfach keine Lust mehr und hab mir dann einfach die 16 gb G.Skill geholt
System:
CPU:FX-8350 8x4.6GHz Thermalright IFX-14
GPU:2X SAPPHIRE Radeon HD 7970 VAPOR X
MB:CROSSHAIR V FORMULA-Z RAM:2X8GB-Kit G.Skill Sniper PC3-14900U CL9-10-9-28
Coolermaster Stacker BTX
be quiet! Dark Power Pro 750
Monitor:Iiyama 27 zoll 1ms
---------- Post added at 22:54 ---------- Previous post was at 22:53 ----------
System:
Ging mir genauso als ich nach den Unterschieden gesucht hatte. Ist aber auch schon eine Weile her...
auch komisch,
das das "Z" Board gute 25-30 preiswerter ist , als das "normale" Crosshair V...
dabei sollte diese "Sonder-Edition" doch nochmal richtig Geld in die Kassen spülen...
Was mich dabei interessiert, was mit den neuen Bulldozern wird, die kommen sollen...
Die passen doch so nicht aufs Crosshair V , ob nun "Z" oder nicht
220 Watt Verlustleistung sollen die haben...(AMD scheint tatsächlich Bulldozer-Prozessoren mit 5 GHz zu bringen | 3DCenter.org
mfG
Achim
Gigabyte hat ja praktisch bestätigt, dass hochgezüchtete FX-Prozessoren kommen und die eine hohe TDP haben werden - wie hoch die aber genau ausfällt, ist noch nicht endgültig geklärt. Die 220 Watt geisterten durch die Gerüchteküche, sind afaik aber noch nicht gesichert.
Sagen wir das mal so. Ich hatte das 990FXA UD7. Jetzt habe ich das Crosshair V Formula-Z. Der Unterschied in der Stromversorgung der mir aufgefallen ist, ist der, dass das ASUS einen 8Pin ATX 12v UND einen weiteren 4Pin ATX 12V hat. Das Gigabyte jedoch nur einen 8Pin 12V ATX Stecker. Somit denke ich das die Energieversorgung auch beim ASUS gewährleistet ist.
Ich nutze einen übertakteten FX 8150 mit Wasserkühlung nd kann mich über die Temps nicht beklagen. Das Bord wird bestimmt auch mit den neuen CPUs keine Probleme haben.
anders rum, hat schon jemand versucht ein BIOS Chip vom Z auf das normale Crroshair zu installieren? ich weis ist ne verrückte frage :banana:
was erhoffst du dir davon?
Hat jemand schon Erfahrung mit den Bios Chips für Mainboards die man bei Ebay kaufen kann?
Funktioniert das und kann man da kaufen? Brauche für mein Crosshair V ein neuen Chip, da sich das Bios aufgehangen hat. Nach einem CMOS Clear sehe ich den roten ASUS Startbildschirm, dann gehts aber nicht mehr weiter.
@Audi_driver
Ja, die kann man beruhigt kaufen. Bei Kauf angeben welche BIOS/UEFI - Version geflasht werden soll, bzw. die entspr. Datei als Zip einschicken.
Ich habe mir mal vor längerer Zeit einen Chip für mein damaliges ASUS A7N8X-E Deluxe über ebay gekauft und hatte keine Probleme.
Bestell dir am besten auch gleich die entsprechende Zange [PLCC Extractor]dazu, das erleichert dir den Wechsel ungemein.
oki doki :coffee:
fuzzy
Ok habs mal bestellt. Dumm nur ich hatte die Zange mal, war mal bei DFI Boards mit dabei, aber weggeschmissen weil ich mit dem Teil nix anfangen konnte :d
Ich hoffe das Board läuft dann wieder...
