[Sammelthread] ASUS Crosshair V Formula (AMD 990FX)
Crosshair V Formula
Spezifikationen
Prozessor / Sockel
  • AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
  • Supports AM3+ 32 nm CPU
  • Supports CPU up to 8 cores
  • Supports CPU up to 140 W
  • AMD Cool 'n' Quiet™ Technology
Chipsatz
  • AMD 990FX/SB950
Arbeitsspeicher
  • 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
Multi-GPU Support
  • Supports NVIDIA® 3-Way SLI™ Technology
  • Supports AMD 3-Way CrossFireX™ Technology
Erweiterungsschächte
  • 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
  • 1 x PCIe 2.0 x16 (x4 mode)
  • 1 x PCIe 2.0 x1
  • 1 x PCI
Storage
  • AMD SB950 controller:
    6 x SATA 6Gb/s port(s), red
    Support Raid 0, 1, 5, 10
  • ASMedia® ASM1061 controller:
    1 x SATA 6Gb/s port(s), red
    1 x eSATA 6Gb/s port(s), red
LAN
  • Intel®, 1 x Gigabit LAN Controller(s)
Audio
  • SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
    - Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking
  • Audio Feature:
    - X-Fi® Xtreme Fidelity™
    - EAX® Advanced™ HD 5.0
    - THX® TruStudio PRO™
    - Creative ALchemy
    - Blu-ray audio layer Content Protection
    - Optical S/PDIF out port(s) at back panel
USB Ports
  • ASMedia® USB 3.0 controller:
    6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board)
    12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
Übertaktung
  • ROG Connect:
    - RC Diagram
    - RC Remote
    - RC Poster
    - GPU TweakIt
  • Extreme Engine Digi+:
    - 8 + 2 phase power design
  • UEFI BIOS features:
    - ROG BIOS Print
    - GPU.DIMM Post
  • GameFirst
  • iROG
  • Extreme Tweaker
  • Overclocking Protection:
    - COP EX (Component Overheat Protection - EX)
    - Voltiminder LED
    - ASUS C.P.R.(CPU Parameter Recall)
Besondere Features
  • ASUS TPU:
    - CPU Level Up
  • Core Unlocker
  • ASUS Exclusive Features:
    - MemOK!
    - Ai Charger+
  • ASUS Quiet Thermal Solution:
    - ASUS Fan Xpert
  • ASUS EZ DIY:
    - ASUS Q-Shield
    - ASUS O.C. Profile
    - ASUS EZ Flash 2
    - ASUS MyLogo 3
  • ASUS Q-Design:
    - ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
    - ASUS Q-Connector
Anschlüsse (Rückseite)
  • 1 x PS/2 keyboard/mouse combo port(s)
  • 1 x eSATA 6Gb/s
  • 1 x LAN (RJ45) port(s)
  • 4 x USB 3.0
  • 8 x USB 2.0 (white port can be switched to ROG Connect)
  • 1 x Optical S/PDIF out
  • 6 x Audio jack(s)
  • 1 x Clear CMOS button(s)
Interne Anschlüsse
  • 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
  • 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
  • 7 x SATA 6Gb/s connector(s)
  • 2 x CPU Fan connector(s)
  • 3 x Chassis Fan connector(s)
  • 3 x Optional Fan connector(s)
  • 1 x S/PDIF out header(s)
  • 1 x 24-pin EATX Power connector(s)
  • 1 x 8-pin ATX 12V Power connector(s)
  • 1 x 4-pin ATX 12V Power connector(s)
  • 1 x Front panel audio connector(s) (AAFP)
  • 1 x System panel(s)
  • 8 x ProbeIt Measurement Points
  • 3 x Thermal sensor connector(s)
  • 1 x En/Dis-able Clr CMOS header(s)
  • 1 x EZ Plug connector(s) (4-pin Molex power connector)
  • 1 x Power-on button(s)
  • 1 x Reset button(s)
  • 1 x CPU Level Up button(s)
  • 1 x ROG Connect switch(es)
  • 1 x Go Button(s)
BIOS
  • UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
  • Version 1703 [AKTUELLLSTE VERSION]
    - Improve system stability
    - Support new CPUs
  • Version 1605
    - Improve system stability.
    - Enhance compatibility with some USB devices.
  • Version 1503
  • Version 1402
  • Version 1301
  • Version 1102
  • Version 1003
    - Improve memory compatibility
  • Version 0903
    - Update CPU Level up function
  • Version 0813
    - Supports new CPUs
  • Version 0705
    - Fix USB 7/8 not work issue
    - Fix system may hang when use with Adaptec ASR-5805 Raid card
    - Add Spanish and Russian to BIOS steup.
    - Support new CPUs
  • Version 0506
  • Version 0404
    - First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
Ich hab mit dem Noctua NH-D14 gute Erfahrungen gemacht. Ist leider etwas teuer.
Etwas ist gut :fresse:
:d Der Promlimatech Panther passt ebenfalls. Dort weiß ich aber nicht wie der Lüfter ist. Notfalls kann man den ja austauschen.
Ich frage mich warum der Macho 120 nicht passen soll, kann ich mir eigentlich nicht vorstellen. Hatte auf meinem CH5F schon nen Scythe Mine 2 und nen Thermaltake Frio Extreme drauf und die dürften nicht kleiner sein.
Solange ich da nicht dran rumfeile passt es nicht. Unten ist ein SMD-Teil im Weg, oben der Kühlkörper. Hier auch ein Beitrag mit dem passenden Bild dazu. Und ehrlich gesagt habe ich keine Lust da nun an dem Kühler rumzufeilen. Dann verkauf ich ihn lieber wieder.
Und hier an dem Kühlkörper passt die Metalplatte nicht vorbei. Da fehlen auch nur zwei Millimeter oder so :(
Also der Scythe Mine 2 passt, man kann dann nur keine Vollbestückung an RAM nutzen.
Auch nicht bei Low Profile? Hab leider nämlich 4x4 GB die verbaut werden wollen
RAM mit flachen Heatspreader könnten noch passen.
Hi Leute,
ich wollte mal nachfragen ob einer von Euch das Phänomen kennt, dass der Rechner nicht runterfahren will.
Die HDD LED leuchtet dann die ganze Zeit, der "Windows wird heruntergefahren" Bildschirm erscheint aber er fährt nicht runter. Das Gleiche beim Neustarten. Aber nicht immer. Dieser Verhalten ist für mich auch nicht reproduzierbar.
Ab und zu kommt es auch vor, dass der Rechner, wenn er mehrere Stunden im leerlauf war einfach einfriert...
OS: Windows 7 HP 64Bit
BIOS: 1402
Hardware sieht man ja in meiner Signatur.
Wäre cool wenn mir jemand helfen könnte
Grüße
locomat
Ist irgendwas übertaktet oder undervoltet?
Undervoltet nicht. Übertaktet ja. Jedoch tritt das auch auf wenn alles auf Standard läuft
Hallo Leute,
finde hier ja schon viele brauchbare Sachen aber über Treiber habe ich noch nix gefunden.
Ich finde auf der Asus Homepage ist es oft verwirrend für mich.
Vielleicht könnt ihr mir ja helfen.
Was ist denn der Unterschied zwischen dem
AMD Chipset Driver V8.973 (8.0.877.0) for Windows XP/Vista/7 32bit & 64bit.(WHQL)
AMD Chipset Driver V8.981 (8.0.881.0) for Windows 8 32bit & 64bit.(WHQL)
und dem
AMD Chipset Driver V3.0.829.0 for Windows 32bit XP.(WHQL)
AMD Chipset Driver V3.0.820.0 for Windows 32bit Vista & 32bit 7.(WHQL)
AMD Chipset Driver V3.0.825.0 for Windows 64bit XP & 64bit Vista & 64bit 7.(WHQL)
von V3 zu V8 ?
da kann ich nicht folgen bei anderen Treibern ähnlich.:stupid:
Greetz HerrZ
Kann man sagen, dass es sowas ist wie eine neue revesion?
Läuft das board besser als das normale.
Gesendet von meinem GT-N7000 mit der Hardwareluxx App
Habe dir mal was raus gesucht. Ist zwar auf englisch, sollte aber kein Problem sein denke ich.
- Improvements for AMD’s existing FX ‘Bulldozer’ and future ‘Piledriver’ architecture, there are feature revisions:
- Improved memory performance through higher attainable frequencies – even when using 4-DIMM. The term 2400MHz has been bandied about…
- The improved Extreme Engine “Digi+II” which allows for an improved control over the CPU and memory for precision overclocking.
- Improved high definition sound.
- Improved Ethernet setup features with gamers in mind.
- Windows 8 Ready with a Directkey Button/DRCT header, TPM header and FastBoot Switch.
- A new and improved UEFI Bios containing a new 64MB worth of ROM and is Windows Fastboot Enabled which if I’ve read correctly, can launch you into the OS in around 2 seconds on the latest SSD’s.
- OEM activation within BIOS.
Quelle ist diese hier What is the difference? Crosshair V Formula » Crosshair V Formula-Z - Motherboards - Motherboards
Die PCI-E 16x Slots 2 und 3 Teilen sich ja die Lanes, ist es dann egal in welchen ich die 2. Graka einbaue?
3 x PCIe 2.0 x16 (dual x16 or x16/x8/x8)
Slot 1 PCIe 2.0 x16
Slot 3 PCIe 2.0 x16
PCIe 2.0 x8 wenn Slot 2 auch genutzt wird, da sich Slot 2 und 3 die 16 Lanes teilen.
Also bei 2 Gakas Slot 1 und Slot 3 nutzen da dann beide x16 haben
Slot 1 PCIe 2.0 x16
Slot 3 PCIe 2.0 x16
Also bei 2 Grakas Slot 1 und Slot 3 nutzen da dann beide x16 haben
Genau so ist es!
Für SLI die Slots PCIe_1 und PCIe_3 (je x16) benutzen. So steht's auch im Handbuch, siehe
oki doki :coffee:
fuzzy
hallo ich bin neu hier
ich hätte da folgende frage ich hatte vor dem CROSSHAIR V FORMULA-Z das CROSSHAIR IV hab jetzt erst neu gewechselt . da waren überall LED für Festplatte und so jetzt fehlt mir bei dem aber auf der hat nur kurz nach dem Start paar LED da wo man Netzteil einsteckt(24pin) danach ist keine LED mehr an . im BIOS ist es aktiviert . ist das normal ????
System:
CPU:FX-8350 8x4.6GHz Thermalright IFX-14
GPU:2X SAPPHIRE Radeon HD 7970 VAPOR X
MB:CROSSHAIR V FORMULA-Z RAM:Mushkin 2000mhz 4x2GB laufen auf 1600mhz
Coolermaster Stacker BTX
be quiet! Dark Power Pro 750
Monitor:Iiyama 27 zoll 1ms
Das ist völlig normal...
Nur wenn die jeweiligen LEDs weiter leuchten, wäre ein Fehler , der dadurch angezeigt wird......
Also , nochmals im einzelnen....
die LEDs leuchten beim einschalten (als sogenannter Selbsttest (POST))
wenn die jeweilige Funktion OK ist (CPU , Speicher usw) dann geht die LED aus...
also kein Grund zur Sorge
MfG
Achim
Das Crosshair Z hat auch eine HDD LED. Direkt links neben dem obersten Sata Ports. Soweit ich mich erinnern kann blinkt diese aber Gelb/Orange und auch nicht all zu hell.
Früher war halt alles besser :d
@Reous
diese LED gab es aber auch schon am Crosshair IV...
Aber am Formula Z gibt es ja diese LED Beleuchtung rund um den Sounchip...
die man (Frau auch) an und ausmachen kann (über BIOS)
Achim
Stimmt die Linienbeleuchtung hab ich schon wieder vergessen. Mir persönlich gefällt die rote Farbe aber nicht.
die Linien Beleuchtung ist echt super aber wenn man 2 Grafikkarten einbaut siecht man die Beleuchtung gar nicht ,wenigsten sind jetzt die Power knöpfe links und nicht mehr oben (CROSSHAIR IV) bei 2 Grafikkarten verdeckte die obere Karte immer die knöpfe.
was ich jetzt auch Blödsinn finde das CROSSHAIR IV hatte oben 3 USB Steckplätze das CROSSHAIR V nur 2 . jetzt hängt ein Kabel immer im lose .
ok der eine oder andere wird sagen der hat ja jetzt den usb3 Port auf dem Bord nur hab ich jetzt noch kein schönes fromt-panel für vorne gefunden was mir gefällt.
ist einen eigentlich aufgefallen das, das CROSSHAIR V nur manchmal beim hochfahren piepst also so ist das bei mir
Ein gewisses Eigenleben kann ich meinem Bord auch nicht abspechen, da ist das Piepsen noch das wenigste.
Ist mir noch garnicht aufgefallen, das mit dem Piepsen...
habe seit dem CrosshairIV keinen Speaker mehr angeschlossen...
und vermisse es auch nicht, weil ja die LEDs mir sagen wenn was nicht stimmt...
Aber mein Gehäuse selbst besitzt kein Speaker mehr...
war nur ein Piezo mit bei gewesen, den ich aber nach Kauf des des FormulaZ,
mit meinem alten CrosshairIV abgegeben hab, weil der Käufer das unbedingt haben wollte...
Ich vermisse das aber nicht.....
Das mit dem "fiepen" ist bei meinem Mainboard auch der Fall. Ich dachte erst, es sei die Festplatte bzw. Grafikkarte. Inzwischen ist das fiepen lauter geworden und ich kann definitiv Festplatte, Grafikkarte oder sonstwas ausschließen. Das Geräusch kommt direkt von den Spannungswandlern über der CPU. Da direkt darüber ein Lüfter die warme Luft ausbläst, ist das Geräusch natürlich sehr störend.
Nach einem Monat Benutzung ist mein ganzes System mit dem lauteren "fiepen" instabil geworden. Windows 8 hängt sich beim Login-Screen regelmäßig auf (Es liegt nicht an einer Spannungsunterversorgung der CPU). Ebenso stockt/zittert die Audio-Ausgabe manchmal ein paar Minuten am Stück.
Ich werde jetzt RMA beantragen. So etwas darf einem so angeblich hochwertigem Mainboard nicht passieren. Besonders nicht mit diesen "handausgelesenen" 8 High-Class-Phasenwandler.
Zur RMA: Soweit ich gesehen habe, muss man diese über den Händler abwickeln. Gibt es evtl. doch einen Weg direkt über Asus? getgoods.de scheint nicht auf meine E-Mails antworten zu wollen. Danke!
