Crosshair V Formula
Prozessor / Sockel
- AMD AM3+ FX™/Phenom™ II/Athlon™ II/Sempron™ 100 Series Processors
- Supports AM3+ 32 nm CPU
- Supports CPU up to 8 cores
- Supports CPU up to 140 W
- AMD Cool 'n' Quiet™ Technology
AMD 990FX/SB950
- 4 x DIMM, Max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 Hz ECC, Non-ECC, Un-buffered Memory Dual Channel Memory Architecture
- Supports NVIDIA® 3-Way SLI™ Technology
- Supports AMD 3-Way CrossFireX™ Technology
- 3 x PCIe 2.0 x16 (dual x16 or x16, x8, x8)
- 1 x PCIe 2.0 x16 (x4 mode)
- 1 x PCIe 2.0 x1
- 1 x PCI
- AMD SB950 controller:
6 x SATA 6Gb/s port(s), red
Support Raid 0, 1, 5, 10 - ASMedia® ASM1061 controller:
1 x SATA 6Gb/s port(s), red
1 x eSATA 6Gb/s port(s), red
- Intel®, 1 x Gigabit LAN Controller(s)
- SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
- Supports: Jack-detection, Multi-streaming, Front Panel Jack-retasking - Audio Feature:
- X-Fi® Xtreme Fidelity™
- EAX® Advanced™ HD 5.0
- THX® TruStudio PRO™
- Creative ALchemy
- Blu-ray audio layer Content Protection
- Optical S/PDIF out port(s) at back panel
- ASMedia® USB 3.0 controller:
6 x USB 3.0 port(s) (4 at back panel, blue, 2 at mid-board) - AMD SB950 controller:
12 x USB 2.0 port(s) (8 at back panel, black+white, 4 at mid-board)
- ROG Connect:
- RC Diagram
- RC Remote
- RC Poster
- GPU TweakIt - Extreme Engine Digi+:
- 8 + 2 phase power design - UEFI BIOS features:
- ROG BIOS Print
- GPU.DIMM Post - GameFirst
- iROG
- Extreme Tweaker
- Overclocking Protection:
- COP EX (Component Overheat Protection - EX)
- Voltiminder LED
- ASUS C.P.R.(CPU Parameter Recall)
- ASUS TPU:
- CPU Level Up - Core Unlocker
- ASUS Exclusive Features:
- MemOK!
- Ai Charger+ - ASUS Quiet Thermal Solution:
- ASUS Fan Xpert - ASUS EZ DIY:
- ASUS Q-Shield
- ASUS O.C. Profile
- ASUS EZ Flash 2
- ASUS MyLogo 3 - ASUS Q-Design:
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Connector
- 1 x PS/2 keyboard/mouse combo port(s)
- 1 x eSATA 6Gb/s
- 1 x LAN (RJ45) port(s)
- 4 x USB 3.0
- 8 x USB 2.0 (white port can be switched to ROG Connect)
- 1 x Optical S/PDIF out
- 6 x Audio jack(s)
- 1 x Clear CMOS button(s)
- 1 x USB 3.0 connector(s) support(s) additional 2 USB 3.0 port(s)
- 2 x USB 2.0 connector(s) support(s) additional 4 USB 2.0 port(s)
- 7 x SATA 6Gb/s connector(s)
- 2 x CPU Fan connector(s)
- 3 x Chassis Fan connector(s)
- 3 x Optional Fan connector(s)
- 1 x S/PDIF out header(s)
- 1 x 24-pin EATX Power connector(s)
- 1 x 8-pin ATX 12V Power connector(s)
- 1 x 4-pin ATX 12V Power connector(s)
- 1 x Front panel audio connector(s) (AAFP)
- 1 x System panel(s)
- 8 x ProbeIt Measurement Points
- 3 x Thermal sensor connector(s)
- 1 x En/Dis-able Clr CMOS header(s)
- 1 x EZ Plug connector(s) (4-pin Molex power connector)
- 1 x Power-on button(s)
- 1 x Reset button(s)
- 1 x CPU Level Up button(s)
- 1 x ROG Connect switch(es)
- 1 x Go Button(s)
UEFI BIOS
Impressionen
Mainboard
Verpackung und Zubehör
UEFI BIOS
(Quelle aller Bilder: AwardFabrik)
BIOS Historie
- Version 1703 [AKTUELLLSTE VERSION]
- Improve system stability
- Support new CPUs
- Version 1605
- Improve system stability.
- Enhance compatibility with some USB devices.
- Version 1503
- Version 1402
- Version 1301
- Version 1102
- Version 1003
- Improve memory compatibility
- Version 0903
- Update CPU Level up function
- Version 0813
- Supports new CPUs
- Version 0705
- Fix USB 7/8 not work issue
- Fix system may hang when use with Adaptec ASR-5805 Raid card
- Add Spanish and Russian to BIOS steup.
- Support new CPUs
- Version 0506
- Version 0404
- First release Bios.
Reviews
Hartware.net
AwardFabrik
Planet 3DNow!
guru3d
Downloads
BIOS, Treiber und Ultilities
Nützliche Links
Liste der unterstützten Arbeitsspeicher
Liste der unterstützten CPUs
Geizhals
