BIOS 0907
CPU Ratio Control : 7
FSB Frequency : 500
FSB Strap to North Bridge : 333
PCI-E Frequency: 100
DRAM Frequency: 1003
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency : 4
RAS# to CAS# Delay : 4
RAS# Precharge : 4
RAS# ActivateTime : 12
RAS# to RAS# Delay : 3
Row Refresh Cycle Time : 42
Write Recovery Time : 6
Read to Precharge Time : 3
Read to Write Delay (S/D) : 8
Write to Read Delay (S) : 3
Write to Read Delay (D) : 5
Read to Read Delay (S) : 4
Read to Read Delay (D) : 6
Write to Write Delay (S) : 4
Write to Write Delay (D) : 6
DRAM Static Read Control: Auto
Ai Clock Twister : Light
Transaction Booster : Disable
Relax 1
CPU Voltage : 1.3625V
CPU PLL Voltage : 1,50V
North Bridge Voltage : 1,35V
DRAM Voltage : 2,24V
FSB Termination Voltage : 1,30V
South Bridge Voltage : 1.050V
Loadline Calibration : Enabled
CPU GTL Reference : Auto
North Bridge GTL Reference : Auto
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage :1,50V
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU Volt
Voltiminder LED : Enabled
CPU Spread Spectrum : Disabled
PCIE Spread Spectrum : Disabled
So habe ich es für FSB500 eingestellt.
Aber was ich mich immernoch frage, was ist DRAM Static Read Control:?
Auf was sollte man das stellt?
