[Sammelthread] Asus Maximus II Formula R.o.G. (Intel P45) [2]
devic
Semiprofi
  • Spezifikationen
  • Bilder
  • BIOS
  • Wichtige Informationen
  • Wichtige Links / Downloads
CPU:
  • Intel Socket 775 Processors for Intel® Core™2 Extreme / Core™2 Quad / Core™2 Duo / Pentium® dual-core/Celeron® dual-core /Celeron® Processors
  • Support Intel® next generation 45nm Multi-Core CPU
  • Compatible with Intel® 06/05B/05A processors
Chipsatz:
  • Intel P45 Chipsatz
  • Intel ICH10R Southbridge
Speicher:
  • 4 x240-pin DIMM, Max. 16 GB, DDR2 1200/1066/800/667 Non-ECC,Un-buffered Memory
  • Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors Lidts).
  • When installing total memory of 4GB capacity or more, Windows® 32-bit operation system may only recognize less than 3GB. Hence, a total installed memory of less than 3GB is recommended.
QVL-Liste siehe Wichtige Links / Downloads
Erweiterungs-Slots:
  • 2 x PCIe 2.0 x16 (single max @16,dual @ x8 speed)
  • 3 x PCIe x1 ( the PCIEx1_1 (black) is compatible with audio slot)
  • 2 x PCI 2.2
Multi-GPU Unterstützung:
  • Unterstützt ATI CrossFireX™
Storage:
  • 6 xSATA 3 Gb/s ports Intel Matrix Storage Technology supports Support RAID 0,1,5,10 Marvell® 88SE6121 controller
  • 1 x UltraDMA 133/100/66/33 for up to 2 PATA devices
  • 1 x External SATA 3.0 Gb/s port (SATA On-the-Go)
  • Silicon Image Sil5723
  • 2 x SATA 3.0 Gb/s ports
  • Supports RAID 0, 1
Audio:
  • SupremeFX X-Fi Audio Card
    - ADI® AD2000B 8-channel High Definition Audio CODEC
    - Creative X-Fi capability
    - X-Fi interface
  • Coaxial/Optical S/PDIF out ports
LAN:
  • Dual Gigabit LAN, both featuring AI NET2
  • Support Teaming Technology
Interne IO-Anschlüsse:
  • 3 x USB 2.0 connectors supports additional 6 USB 2.0 ports
  • 1 x Floppy disk drive connector
  • 1 x IDE connector for two devices
  • 6 x SATA connectors (Blue)
  • 2 x Speeding HDD connectors (Black)
  • 8 x Fan connectors: 1 x CPU / 1 x PWR / 3 x Chassis / 3 x Optional
  • 3 x thermal sensor connectors
  • 1 x IEEE1394a connector
  • 1 x Chassis Intrusion connector
  • 24-pin ATX Power connector
  • 8-pin ATX 12V Power connector
  • 1 x En/Dis-able Clr CMOS
  • 1 x LCD Poster connector
  • 1 x ROG connector
  • 1 x Power-on switch
  • 1 x Reset switch
  • System panel connector
externe IO-Anschlüsse:
  • 1 x PS/2 Keyboard port(purple)
  • 1 x eSATA port
  • 2 x LAN (RJ45) ports
  • 6 x USB 2.0/1.1 ports
  • 1 x IEEE1394a port
  • 1 x Clr CMOS switch
Lieferumfang:
  • LCD Poster
  • ASUS Optional Fan
  • 3 in 1 ASUS Q-Connector Kit
  • UltraDMA 133/100/66 cable
  • Floppy disk drive cable
  • SATA cables
  • SATA power cables
  • 2-port USB2.0 + IEEE 1394a module
  • Q-Shield
  • Cable Ties
  • User's manual
Quelle = OCXtreme
Quelle: XtremeSystems.org
Kompatible Kühler:
  • Alpenfön Groß Clock'ner (nur mit leichtem Verbiegen der Lamellen!)
  • Arctic Freezer 7 Pro
  • Asus Silent Night 1+2
  • Asus Triton 79
  • Coolermaster Hyper 212
  • Noctua NH-U-12P
  • Scythe Mugen / Infinity
  • Thermalright IFX-14 (HR-10 passt nur mit Bearbeitung)
  • Thermalright Ultra 120 eXtreme / True Black
  • Thermaltake Sonic Tower
  • Xigmatek HDT-S1283 / Red Scorpion
  • Zalman CNPS 9500AT
  • ZHEROtherm Nirvana NV 120
Wobei hier zu sagen ist, dass man von wenigen inkompatiblem Kühlern ausgeht, weil das Mainboard durch die flache Heatpipe sehr Kühler-freundlich ausgelegt ist
__________
Kompatibler RAM:
  • 2x 1GB A-DATA Vitesta Extreme DDR2-800
  • 2x 1GB Corsair XMS2 DHX DDR2-800
  • 2x 1GB Aeneon XTune DDR2-1066
  • 2x 1GB Patriot Viper DDR2-1150
  • 2x 1GB CompuStocx Diablo DDR2-1200
  • 2x 1GB OCZ Flex XLC DDR2-1200
  • 4x 1GB Crucial Ballistix (Tracer) DDR2-1066
  • 4x 1GB Corsair Dominator DDR2-1066
  • 2x 2GB Corsair DHX DDR2-800
  • 2x 2GB OCZ XTC Platinum DDR2-1000
  • 2x 2GB Apogee GT DDR2-1066
  • 2x 2GB Transcend aXeram DDR2-1066
  • 2x 2GB Corsair Dominator DDR2-1066
  • 2x 2GB G.Skill F2 4GBPK DDR2-1066
  • 2x 2GB G.Skill F2 4GBPI DDR2-1066
  • 2x 2GB G.Skill F2-4GBPI DDR2-1100
  • 2x 2GB Mushkin XP2 DDR2-1100
  • 2x 2GB OCZ Flex II DDR2-1150
  • 2x 2GB Chaintech Apogee GT DDR2-1150
  • 4x 2GB Transcend JetRam DDR2-800
  • 4x 2GB Corsair Dominator DDR2-1066
  • 4x 2GB OCZ Platinum XTC DDR2-1066
__________
Die GTL-Einstellung:
Die GTL ist ein Teiler. Sie ergibt mit der VTT multipliziert einen Wert in mV. Bei den meisten Board benutzt man den Teiler um auf einen höheren/niedrigeren (eben für die CPU perfekte) Endvoltage zu kommen. Beim Maximus II Formula wird dieser Teiler jedoch gefixt und dafür vom Endwert in mV abgezogen. Das hat den Vorteil, dass sich der Endwert bei gleicheingestellter GTL nicht durch die variable VTT ändert.
Beispiel mit Asus P5Q Deluxe und vielen anderen Boards:
VTT x GTL = mV
1,1V x 0,63V = 693mV
Beispiel mit Asus Maximus II Formula:
VTT x fixed GTL = mV - mV
1,1V x 0,677 = 744,7mV - 50mV
Beide Beispiele kommen auf etwa das gleiche raus ;)
Dickgedruckt = Jeweils im BIOS einstellbare Werte
__________
Northbridge Temperaturproblem beheben:
Um die zu hohen Temperaturen der Northbridge zu senken, muss der Anpressdruck des Kühlsystems verstärkt werden. Dazu muss das Board ausgebaut und umgedreht werden. Daraufhin werden unter die Schrauben, die die Heatpipekühlung auf der Northbridge halten einfach zwei Unterlegscheiben (0,5 - 1mm) gelegt. Das erhöht den Anpressdruck und senkt gleichzeitig die Temperaturen der Northbridge.
__________
Messpunkte:
Quelle: Awardfabrik.de (@arne)
__________
Nein. LLC bringt einen unstabilen Betrieb mit sich. Also nicht zu empfehlen, da dieser unstabile Betrieb mit höherer vCore wieder ausgeglichen werden muss!
Die Leute haben sich bei einem vCore-Drop schon was gedacht, nämlich einen stabilen Betrieb.
lol warum sollte ich mich nicht trauen, versuchs ja schon die ganze zeit!
hab jetzt mehrere male diese einstellungen versucht:
das system will ums verecken nich booten,lcd poster bleibt immer auf det dram stehen!
hier die specs meines speichers:
kann aber einfach nicht glauben das es am speicher liegt!
hats was damit zu tun das ich nur einen riegel hab, würde es was bringen wenn ich mal nen weissen ram slot benutze???
Probiere es mal auf allen Slots aus. Mein einer Ballistix-Riegel wollte bei meinem P5Q Dlx mit ersten BIOS auch nur in einem Slot :rolleyes:
Hast du das neuste BIOS drauf?
Wenn nicht entschärfe mal die Subtimings auf 5-5-5-18-8-45-6-3, die sind nämlich relativ scharf.
Und wenn das alles nichts geholfen hat, haust du mal 1,375V drauf. Keine Angst, dabei kommen durch den vCore Drop viel weniger raus ;)
möchte nicht noch jemand nen tipp abgeben bevor ich wieder 10 min weg bin, wisst schon wegen ram slots durchtesten.
also es liegt bestimmt nicht daran das du nur einen riegel hast, sonst würde das board auch mit standart settings net wollen...
probier doch mal bitte ob 6x500 und 7x500 gehen...
für die sechs blauen -> intel chipsatz treiber
für die zwei schwarzen -> kein treiber benötigt
für esata und ide -> marvell treiber
!Gute Info > Post 1 für Neulinge ;)
Es gibt doch hier soviel Ungereimtheiten die mit reinspielen können.
Die Signalqualität vom Netzteil, oder Schwankungen in der Produktion.
Hab ja die gleiche Config wie du. Vielleicht test ich auch mal? ;)
Denke nochmal drüber nach, stimmt nämlich nicht unbedingt! Muss ja keine Inkompatibilität sein...
gut ich würde jetzt nicht meine hand dafür ins feuer legen, aber plausibel erscheint mir das doch nicht!
zumal das ja auch ein 8500U speicher ist...
genau, ich würde sagen am speicher liegt es nicht!!!
ich denke einfach das ich ne richtige gurke von einem e8400 erwischt!!!
ich könnt echt ausrasten, hab mir echt mehr erwartet!
p.s. soll ich jetzt 500x6 und 500x7 probieren?
hatte ja gestern schonmal 555x6 probiert und da hat ds system wenigstens gebootet, also am board liegt es nicht wenn du den verdacht hast!
das ist auch ein ganz guter beweis das es nicht am speicher liegt.
wie man sieht läuft der ja mit 1110mhz!!!
also da hast du wirklich keinen oc-meister erwischt!
welche batch hat denn dein e8400?
tja das ist auch ne ganz interessante geschichte, hab in vielen ami foren gelesen das nur die 7er batches auf 4ghz laufen.
ich hab aber nen 8erbatch:
das stimmt net, ich hatte einen Q807er der lief auch auf 4ghz bis ihn mysteriöserweise das zeitliche segnete...
kennst du deine vid?
wie kühlst du? luft? wasser?
was meinste mit vid?
gekühlt wird mit kluft?
p.s. was hat das mit der kühlung zu tun wenn die temps doch ok sind?
ist noch der 45nm boxed kühler auf max drehzahl:
Trust13 schrieb:
Hab mir heute nen E8400 mit Batch Q818A131 zugelegt, in der Hoffnung was besseres als meinen E8500 zu erwischen..
Der startet bei 3.8 GHz mit 1.3v im Bios net mal ins Windows
wird gleich wieder verkauft...
also Finger weg von Q818 ...
Ich würde es aufgeben...
da du mit luft kühlst ist die kühlleistung begrenzt!
cpu's mit kleiner vid sind bei hohen frequenzen, und den damit verbundenen höheren spannungen sehr schwer mit luft zu kühlen. gerade oben raus werden die sehr heiß.
ich denke mal das eventuell hier das problem liegt...aber sicher kann ich dir das erst sagen wenn du mir deine vid nennst ;)
wo steht die?
war ne tray, also keine packung, kann da nur auf das bild meiner cpu weiter oben verweisen!
Hast du das neuste CPU-Z? Wenn nicht lade es runter. Da wirst du es zu sehen bekommen!
Ich würde sagen, dass eher das 818 nach dem Q das Problem ist :d :(
vid bekommst du mit core temp angezeigt!
wüsste nicht wie man mit cpu-z die vid auslesen kann? devic lass uns mal an deinem wissen teilhaben...
Meinte doch CoreTemp. Werde doch nicht gleich aufdringlich :rolleyes:
für luftkühlung eigentlich eher gut...hast ne hohe vid!
aslo dann liegt es echt an der 818er batch...
Gut :d
Hast eigentlich die perfekte VID für ein LuKü-System. Wie schnell drehen deine Lüfter? Was hast du für eien vCore bei dem Screen drauf? Ist er im Idle-Betrieb gemacht worden?
Q818 soll nicht gut gehen. Daran kann man leider nichts ändern. Schade, dass du keinen E0 erwischt hast... Mein E8400 E0 kommt anfang nächster Woche...
abwarten leute!
vielleicht wird morgen mein E0er losgeschickt.
aber das versteh ich wirklich nicht devic, wozu nen E8400 E0, wenn man doch schon nen E8600 E0 hat???
ich hoffe echt für dich das du nen guten bekommst!
bekommst du die 400x9 vom screen oben prime stable?
langt ja dicke für 24/7 ;)
